Public Types | Public Member Functions | Static Public Member Functions | Static Public Attributes | Protected Member Functions | Friends | List of all members
paraview_protobuf::Message Class Referencefinal
#include <vtkPVMessage.pb.h>
Inherits Message.
enum  : int {
  kGlobalIdFieldNumber = 1, kLocationFieldNumber = 2, kShareOnlyFieldNumber = 3, kReqDefFieldNumber = 4,
  kClientIdFieldNumber = 5
 Message ()
 ~Message () override
constexpr Message (::PROTOBUF_NAMESPACE_ID::internal::ConstantInitialized)
 Message (const Message &from)
 Message (Message &&from) noexcept
Message & operator= (const Message &from)
Message & operator= (Message &&from) noexcept
const ::PROTOBUF_NAMESPACE_ID::UnknownFieldSet & unknown_fields () const
inline ::PROTOBUF_NAMESPACE_ID::UnknownFieldSet * mutable_unknown_fields ()
void Swap (Message *other)
void UnsafeArenaSwap (Message *other)
Message * New (::PROTOBUF_NAMESPACE_ID::Arena *arena=nullptr) const final
void CopyFrom (const Message &from)
void MergeFrom (const Message &from)
PROTOBUF_ATTRIBUTE_REINITIALIZES void Clear () final
bool IsInitialized () const final
size_t ByteSizeLong () const final
const char * _InternalParse (const char *ptr, ::PROTOBUF_NAMESPACE_ID::internal::ParseContext *ctx) final
uint8_t * _InternalSerialize (uint8_t *target, ::PROTOBUF_NAMESPACE_ID::io::EpsCopyOutputStream *stream) const final
int GetCachedSize () const final
const ::PROTOBUF_NAMESPACE_ID::Message::ClassData * GetClassData () const final
::PROTOBUF_NAMESPACE_ID::Metadata GetMetadata () const final
bool has_global_id () const
void clear_global_id ()
uint64_t global_id () const
void set_global_id (uint64_t value)
bool has_location () const
void clear_location ()
uint32_t location () const
void set_location (uint32_t value)
bool has_share_only () const
void clear_share_only ()
bool share_only () const
void set_share_only (bool value)
bool has_req_def () const
void clear_req_def ()
bool req_def () const
void set_req_def (bool value)
bool has_client_id () const
void clear_client_id ()
uint32_t client_id () const
void set_client_id (uint32_t value)
template<typename _proto_TypeTraits , ::PROTOBUF_NAMESPACE_ID::internal::FieldType _field_type, bool _is_packed>
bool HasExtension (const ::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< Message, _proto_TypeTraits, _field_type, _is_packed > &id) const
void ClearExtension (const ::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< Message, _proto_TypeTraits, _field_type, _is_packed > &id)
int ExtensionSize (const ::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< Message, _proto_TypeTraits, _field_type, _is_packed > &id) const
_proto_TypeTraits::Singular::ConstType GetExtension (const ::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< Message, _proto_TypeTraits, _field_type, _is_packed > &id) const
_proto_TypeTraits::Singular::MutableType MutableExtension (const ::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< Message, _proto_TypeTraits, _field_type, _is_packed > &id)
void SetExtension (const ::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< Message, _proto_TypeTraits, _field_type, _is_packed > &id, typename _proto_TypeTraits::Singular::ConstType value)
void SetAllocatedExtension (const ::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< Message, _proto_TypeTraits, _field_type, _is_packed > &id, typename _proto_TypeTraits::Singular::MutableType value)
void UnsafeArenaSetAllocatedExtension (const ::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< Message, _proto_TypeTraits, _field_type, _is_packed > &id, typename _proto_TypeTraits::Singular::MutableType value)
PROTOBUF_NODISCARD _proto_TypeTraits::Singular::MutableType ReleaseExtension (const ::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< Message, _proto_TypeTraits, _field_type, _is_packed > &id)
_proto_TypeTraits::Singular::MutableType UnsafeArenaReleaseExtension (const ::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< Message, _proto_TypeTraits, _field_type, _is_packed > &id)
_proto_TypeTraits::Repeated::ConstType GetExtension (const ::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< Message, _proto_TypeTraits, _field_type, _is_packed > &id, int index) const
_proto_TypeTraits::Repeated::MutableType MutableExtension (const ::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< Message, _proto_TypeTraits, _field_type, _is_packed > &id, int index)
void SetExtension (const ::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< Message, _proto_TypeTraits, _field_type, _is_packed > &id, int index, typename _proto_TypeTraits::Repeated::ConstType value)
_proto_TypeTraits::Repeated::MutableType AddExtension (const ::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< Message, _proto_TypeTraits, _field_type, _is_packed > &id)
void AddExtension (const ::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< Message, _proto_TypeTraits, _field_type, _is_packed > &id, typename _proto_TypeTraits::Repeated::ConstType value)
const _proto_TypeTraits::Repeated::RepeatedFieldType & GetRepeatedExtension (const ::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< Message, _proto_TypeTraits, _field_type, _is_packed > &id) const
_proto_TypeTraits::Repeated::RepeatedFieldType * MutableRepeatedExtension (const ::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< Message, _proto_TypeTraits, _field_type, _is_packed > &id)
static const ::PROTOBUF_NAMESPACE_ID::Descriptor * descriptor ()
static const ::PROTOBUF_NAMESPACE_ID::Descriptor * GetDescriptor ()
static const ::PROTOBUF_NAMESPACE_ID::Reflection * GetReflection ()
static const Message & default_instance ()
static const Message * internal_default_instance ()
static constexpr int kIndexInFileMessages
static const ClassData _class_data_
 Message (::PROTOBUF_NAMESPACE_ID::Arena *arena, bool is_message_owned=false)
Friends
class ::PROTOBUF_NAMESPACE_ID::internal::AnyMetadata
template<typename T >
class ::PROTOBUF_NAMESPACE_ID::Arena::InternalHelper
struct ::TableStruct_vtkPVMessage_2eproto
void swap (Message &a, Message &b)
Definition at line 958 of file vtkPVMessage.pb.h.
◆ anonymous enum
anonymous enum : int
Enumerator
kReqDefFieldNumber
Definition at line 1086 of file vtkPVMessage.pb.h.
◆ Message() [1/5]
paraview_protobuf::Message::Message ( )
inline
Definition at line 961 of file vtkPVMessage.pb.h.
◆ ~Message()
paraview_protobuf::Message::~Message ( )
override
◆ Message() [2/5]
constexpr paraview_protobuf::Message::Message ( ::PROTOBUF_NAMESPACE_ID::internal::ConstantInitialized  )
explicit
◆ Message() [3/5]
paraview_protobuf::Message::Message ( const Message &  from)
◆ Message() [4/5]
paraview_protobuf::Message::Message ( Message &&  from)
inlinenoexcept
Definition at line 966 of file vtkPVMessage.pb.h.
◆ Message() [5/5]
paraview_protobuf::Message::Message ( ::PROTOBUF_NAMESPACE_ID::Arena *  arena,
bool  is_message_owned = false
explicitprotected
◆ operator=() [1/2]
Message& paraview_protobuf::Message::operator= ( const Message &  from)
inline
Definition at line 971 of file vtkPVMessage.pb.h.
◆ operator=() [2/2]
Message& paraview_protobuf::Message::operator= ( Message &&  from)
inlinenoexcept
Definition at line 975 of file vtkPVMessage.pb.h.
◆ unknown_fields()
const ::PROTOBUF_NAMESPACE_ID::UnknownFieldSet& paraview_protobuf::Message::unknown_fields ( ) const
inline
Definition at line 989 of file vtkPVMessage.pb.h.
◆ mutable_unknown_fields()
inline ::PROTOBUF_NAMESPACE_ID::UnknownFieldSet* paraview_protobuf::Message::mutable_unknown_fields ( )
inline
Definition at line 992 of file vtkPVMessage.pb.h.
◆ descriptor()
static const ::PROTOBUF_NAMESPACE_ID::Descriptor* paraview_protobuf::Message::descriptor ( )
inlinestatic
Definition at line 996 of file vtkPVMessage.pb.h.
◆ GetDescriptor()
static const ::PROTOBUF_NAMESPACE_ID::Descriptor* paraview_protobuf::Message::GetDescriptor ( )
inlinestatic
Definition at line 999 of file vtkPVMessage.pb.h.
◆ GetReflection()
static const ::PROTOBUF_NAMESPACE_ID::Reflection* paraview_protobuf::Message::GetReflection ( )
inlinestatic
Definition at line 1002 of file vtkPVMessage.pb.h.
◆ default_instance()
static const Message& paraview_protobuf::Message::default_instance ( )
inlinestatic
Definition at line 1005 of file vtkPVMessage.pb.h.
◆ internal_default_instance()
static const Message* paraview_protobuf::Message::internal_default_instance ( )
inlinestatic
Definition at line 1008 of file vtkPVMessage.pb.h.
◆ Swap()
void paraview_protobuf::Message::Swap ( Message *  other)
inline
Definition at line 1018 of file vtkPVMessage.pb.h.
◆ UnsafeArenaSwap()
void paraview_protobuf::Message::UnsafeArenaSwap ( Message *  other)
inline
Definition at line 1031 of file vtkPVMessage.pb.h.
Message* paraview_protobuf::Message::New ( ::PROTOBUF_NAMESPACE_ID::Arena *  arena = nullptr) const
inlinefinal
Definition at line 1039 of file vtkPVMessage.pb.h.
◆ CopyFrom()
void paraview_protobuf::Message::CopyFrom ( const Message &  from)
◆ MergeFrom()
void paraview_protobuf::Message::MergeFrom ( const Message &  from)
◆ Clear()
PROTOBUF_ATTRIBUTE_REINITIALIZES void paraview_protobuf::Message::Clear ( )
final
◆ IsInitialized()
bool paraview_protobuf::Message::IsInitialized ( ) const
final
◆ ByteSizeLong()
size_t paraview_protobuf::Message::ByteSizeLong ( ) const
final
◆ _InternalParse()
const char* paraview_protobuf::Message::_InternalParse ( const char *  ptr,
::PROTOBUF_NAMESPACE_ID::internal::ParseContext *  ctx
final
◆ _InternalSerialize()
uint8_t* paraview_protobuf::Message::_InternalSerialize ( uint8_t *  target,
::PROTOBUF_NAMESPACE_ID::io::EpsCopyOutputStream *  stream
) const
final
◆ GetCachedSize()
int paraview_protobuf::Message::GetCachedSize ( ) const
inlinefinal
Definition at line 1056 of file vtkPVMessage.pb.h.
◆ GetClassData()
const ::PROTOBUF_NAMESPACE_ID::Message::ClassData* paraview_protobuf::Message::GetClassData ( ) const
final
◆ GetMetadata()
::PROTOBUF_NAMESPACE_ID::Metadata paraview_protobuf::Message::GetMetadata ( ) const
final
◆ has_global_id()
bool paraview_protobuf::Message::has_global_id ( ) const
inline
Definition at line 5244 of file vtkPVMessage.pb.h.
◆ clear_global_id()
void paraview_protobuf::Message::clear_global_id ( )
inline
Definition at line 5247 of file vtkPVMessage.pb.h.
◆ global_id()
uint64_t paraview_protobuf::Message::global_id ( ) const
inline
Definition at line 5254 of file vtkPVMessage.pb.h.
◆ set_global_id()
void paraview_protobuf::Message::set_global_id ( uint64_t  value)
inline
Definition at line 5262 of file vtkPVMessage.pb.h.
◆ has_location()
bool paraview_protobuf::Message::has_location ( ) const
inline
Definition at line 5272 of file vtkPVMessage.pb.h.
◆ clear_location()
void paraview_protobuf::Message::clear_location ( )
inline
Definition at line 5275 of file vtkPVMessage.pb.h.
◆ location()
uint32_t paraview_protobuf::Message::location ( ) const
inline
Definition at line 5282 of file vtkPVMessage.pb.h.
◆ set_location()
void paraview_protobuf::Message::set_location ( uint32_t  value)
inline
Definition at line 5290 of file vtkPVMessage.pb.h.
◆ has_share_only()
bool paraview_protobuf::Message::has_share_only ( ) const
inline
Definition at line 5300 of file vtkPVMessage.pb.h.
◆ clear_share_only()
void paraview_protobuf::Message::clear_share_only ( )
inline
Definition at line 5303 of file vtkPVMessage.pb.h.
◆ share_only()
bool paraview_protobuf::Message::share_only ( ) const
inline
Definition at line 5310 of file vtkPVMessage.pb.h.
◆ set_share_only()
void paraview_protobuf::Message::set_share_only ( bool  value)
inline
Definition at line 5318 of file vtkPVMessage.pb.h.
◆ has_req_def()
bool paraview_protobuf::Message::has_req_def ( ) const
inline
Definition at line 5328 of file vtkPVMessage.pb.h.
◆ clear_req_def()
void paraview_protobuf::Message::clear_req_def ( )
inline
Definition at line 5331 of file vtkPVMessage.pb.h.
◆ req_def()
bool paraview_protobuf::Message::req_def ( ) const
inline
Definition at line 5338 of file vtkPVMessage.pb.h.
◆ set_req_def()
void paraview_protobuf::Message::set_req_def ( bool  value)
inline
Definition at line 5346 of file vtkPVMessage.pb.h.
◆ has_client_id()
bool paraview_protobuf::Message::has_client_id ( ) const
inline
Definition at line 5356 of file vtkPVMessage.pb.h.
◆ clear_client_id()
void paraview_protobuf::Message::clear_client_id ( )
inline
Definition at line 5359 of file vtkPVMessage.pb.h.
◆ client_id()
uint32_t paraview_protobuf::Message::client_id ( ) const
inline
Definition at line 5366 of file vtkPVMessage.pb.h.
◆ set_client_id()
void paraview_protobuf::Message::set_client_id ( uint32_t  value)
inline
Definition at line 5374 of file vtkPVMessage.pb.h.
◆ HasExtension()
bool paraview_protobuf::Message::HasExtension ( const ::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< Message, _proto_TypeTraits, _field_type, _is_packed > &  id) const
inline
Definition at line 1162 of file vtkPVMessage.pb.h.
◆ ClearExtension()
void paraview_protobuf::Message::ClearExtension ( const ::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< Message, _proto_TypeTraits, _field_type, _is_packed > &  id)
inline
Definition at line 1172 of file vtkPVMessage.pb.h.
◆ ExtensionSize()
int paraview_protobuf::Message::ExtensionSize ( const ::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< Message, _proto_TypeTraits, _field_type, _is_packed > &  id) const
inline
Definition at line 1182 of file vtkPVMessage.pb.h.
◆ GetExtension() [1/2]
_proto_TypeTraits::Singular::ConstType paraview_protobuf::Message::GetExtension ( const ::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< Message, _proto_TypeTraits, _field_type, _is_packed > &  id) const
inline
Definition at line 1192 of file vtkPVMessage.pb.h.
◆ MutableExtension() [1/2]
_proto_TypeTraits::Singular::MutableType paraview_protobuf::Message::MutableExtension ( const ::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< Message, _proto_TypeTraits, _field_type, _is_packed > &  id)
inline
Definition at line 1203 of file vtkPVMessage.pb.h.
◆ SetExtension() [1/2]
void paraview_protobuf::Message::SetExtension ( const ::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< Message, _proto_TypeTraits, _field_type, _is_packed > &  id,
inline
Definition at line 1214 of file vtkPVMessage.pb.h.
◆ SetAllocatedExtension()
void paraview_protobuf::Message::SetAllocatedExtension ( const ::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< Message, _proto_TypeTraits, _field_type, _is_packed > &  id,
inline
Definition at line 1225 of file vtkPVMessage.pb.h.
◆ UnsafeArenaSetAllocatedExtension()
void paraview_protobuf::Message::UnsafeArenaSetAllocatedExtension ( const ::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< Message, _proto_TypeTraits, _field_type, _is_packed > &  id,
inline
Definition at line 1236 of file vtkPVMessage.pb.h.
◆ ReleaseExtension()
PROTOBUF_NODISCARD _proto_TypeTraits::Singular::MutableType paraview_protobuf::Message::ReleaseExtension ( const ::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< Message, _proto_TypeTraits, _field_type, _is_packed > &  id)
inline
Definition at line 1249 of file vtkPVMessage.pb.h.
◆ UnsafeArenaReleaseExtension()
_proto_TypeTraits::Singular::MutableType paraview_protobuf::Message::UnsafeArenaReleaseExtension ( const ::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< Message, _proto_TypeTraits, _field_type, _is_packed > &  id)
inline
Definition at line 1260 of file vtkPVMessage.pb.h.
◆ GetExtension() [2/2]
_proto_TypeTraits::Repeated::ConstType paraview_protobuf::Message::GetExtension ( const ::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< Message, _proto_TypeTraits, _field_type, _is_packed > &  id,
int  index
) const
inline
Definition at line 1271 of file vtkPVMessage.pb.h.
◆ MutableExtension() [2/2]
_proto_TypeTraits::Repeated::MutableType paraview_protobuf::Message::MutableExtension ( const ::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< Message, _proto_TypeTraits, _field_type, _is_packed > &  id,
int  index
inline
Definition at line 1282 of file vtkPVMessage.pb.h.
◆ SetExtension() [2/2]
int  index,
inline
Definition at line 1293 of file vtkPVMessage.pb.h.
◆ AddExtension() [1/2]
_proto_TypeTraits::Repeated::MutableType paraview_protobuf::Message::AddExtension ( const ::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< Message, _proto_TypeTraits, _field_type, _is_packed > &  id)
inline
Definition at line 1304 of file vtkPVMessage.pb.h.
◆ AddExtension() [2/2]
void paraview_protobuf::Message::AddExtension ( const ::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< Message, _proto_TypeTraits, _field_type, _is_packed > &  id,
inline
Definition at line 1316 of file vtkPVMessage.pb.h.
◆ GetRepeatedExtension()
const _proto_TypeTraits::Repeated::RepeatedFieldType& paraview_protobuf::Message::GetRepeatedExtension ( const ::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< Message, _proto_TypeTraits, _field_type, _is_packed > &  id) const
inline
Definition at line 1329 of file vtkPVMessage.pb.h.
◆ MutableRepeatedExtension()
_proto_TypeTraits::Repeated::RepeatedFieldType* paraview_protobuf::Message::MutableRepeatedExtension ( const ::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< Message, _proto_TypeTraits, _field_type, _is_packed > &  id)
inline
Definition at line 1340 of file vtkPVMessage.pb.h.
◆ ::PROTOBUF_NAMESPACE_ID::internal::AnyMetadata
friend class ::PROTOBUF_NAMESPACE_ID::internal::AnyMetadata
friend
Definition at line 1065 of file vtkPVMessage.pb.h.
◆ ::PROTOBUF_NAMESPACE_ID::Arena::InternalHelper
friend class ::PROTOBUF_NAMESPACE_ID::Arena::InternalHelper
friend
Definition at line 1357 of file vtkPVMessage.pb.h.
◆ ::TableStruct_vtkPVMessage_2eproto
friend struct ::TableStruct_vtkPVMessage_2eproto
friend
Definition at line 1367 of file vtkPVMessage.pb.h.
◆ swap
void swap ( Message &  a,
Message &  b
friend
Definition at line 1015 of file vtkPVMessage.pb.h.
◆ kIndexInFileMessages
constexpr int paraview_protobuf::Message::kIndexInFileMessages
Initial value:
3
Definition at line 1012 of file vtkPVMessage.pb.h.
◆ _class_data_
const ClassData paraview_protobuf::Message::_class_data_
Definition at line 1077 of file vtkPVMessage.pb.h.
