#include <vtkPVMessage.pb.h>
Inherits Message.
| enum | : int { kNameFieldNumber = 2, kUserFieldNumber = 1, kIsMasterFieldNumber = 3, kFollowCamFieldNumber = 4, kDisableFurtherConnectionsFieldNumber = 5, kConnectIdFieldNumber = 6 } |
| ClientsInformation_ClientInfo () | |
| ~ClientsInformation_ClientInfo () override | |
| constexpr | ClientsInformation_ClientInfo (::PROTOBUF_NAMESPACE_ID::internal::ConstantInitialized) |
| ClientsInformation_ClientInfo (const ClientsInformation_ClientInfo &from) | |
| ClientsInformation_ClientInfo (ClientsInformation_ClientInfo &&from) noexcept | |
| ClientsInformation_ClientInfo & | operator= (const ClientsInformation_ClientInfo &from) |
| ClientsInformation_ClientInfo & | operator= (ClientsInformation_ClientInfo &&from) noexcept |
| const ::PROTOBUF_NAMESPACE_ID::UnknownFieldSet & | unknown_fields () const |
| inline ::PROTOBUF_NAMESPACE_ID::UnknownFieldSet * | mutable_unknown_fields () |
| void | Swap (ClientsInformation_ClientInfo *other) |
| void | UnsafeArenaSwap (ClientsInformation_ClientInfo *other) |
| ClientsInformation_ClientInfo * | New (::PROTOBUF_NAMESPACE_ID::Arena *arena=nullptr) const final |
| void | CopyFrom (const ClientsInformation_ClientInfo &from) |
| void | MergeFrom (const ClientsInformation_ClientInfo &from) |
| PROTOBUF_ATTRIBUTE_REINITIALIZES void | Clear () final |
| bool | IsInitialized () const final |
| size_t | ByteSizeLong () const final |
| const char * | _InternalParse (const char *ptr, ::PROTOBUF_NAMESPACE_ID::internal::ParseContext *ctx) final |
| uint8_t * | _InternalSerialize (uint8_t *target, ::PROTOBUF_NAMESPACE_ID::io::EpsCopyOutputStream *stream) const final |
| int | GetCachedSize () const final |
| const ::PROTOBUF_NAMESPACE_ID::Message::ClassData * | GetClassData () const final |
| ::PROTOBUF_NAMESPACE_ID::Metadata | GetMetadata () const final |
| bool | has_name () const |
| void | clear_name () |
| const std::string & | name () const |
| template<typename ArgT0 = const std::string&, typename... ArgT> | |
| void | set_name (ArgT0 &&arg0, ArgT... args) |
| std::string * | mutable_name () |
| PROTOBUF_NODISCARD std::string * | release_name () |
| void | set_allocated_name (std::string *name) |
| bool | has_user () const |
| void | clear_user () |
| uint32_t | user () const |
| void | set_user (uint32_t value) |
| bool | has_is_master () const |
| void | clear_is_master () |
| bool | is_master () const |
| void | set_is_master (bool value) |
| bool | has_follow_cam () const |
| void | clear_follow_cam () |
| bool | follow_cam () const |
| void | set_follow_cam (bool value) |
| bool | has_disable_further_connections () const |
| void | clear_disable_further_connections () |
| bool | disable_further_connections () const |
| void | set_disable_further_connections (bool value) |
| bool | has_connect_id () const |
| void | clear_connect_id () |
| uint32_t | connect_id () const |
| void | set_connect_id (uint32_t value) |
| template<typename ArgT0 , typename... ArgT> | |
| PROTOBUF_ALWAYS_INLINE void | set_name (ArgT0 &&arg0, ArgT... args) |
| static const ::PROTOBUF_NAMESPACE_ID::Descriptor * | descriptor () |
| static const ::PROTOBUF_NAMESPACE_ID::Descriptor * | GetDescriptor () |
| static const ::PROTOBUF_NAMESPACE_ID::Reflection * | GetReflection () |
| static const ClientsInformation_ClientInfo & | default_instance () |
| static const ClientsInformation_ClientInfo * | internal_default_instance () |
Static Public Attributes | |
| static constexpr int | kIndexInFileMessages |
| static const ClassData | _class_data_ |
| ClientsInformation_ClientInfo (::PROTOBUF_NAMESPACE_ID::Arena *arena, bool is_message_owned=false) | |
Friends | |
| class | ::PROTOBUF_NAMESPACE_ID::internal::AnyMetadata |
| template<typename T > | |
| class | ::PROTOBUF_NAMESPACE_ID::Arena::InternalHelper |
| struct | ::TableStruct_vtkPVMessage_2eproto |
| void | swap (ClientsInformation_ClientInfo &a, ClientsInformation_ClientInfo &b) |
Definition at line 4063 of file vtkPVMessage.pb.h.
| anonymous enum : int |
| Enumerator | |
| kNameFieldNumber | |
| kUserFieldNumber | |
| kIsMasterFieldNumber | |
| kFollowCamFieldNumber | |
| kDisableFurtherConnectionsFieldNumber | |
| kConnectIdFieldNumber | |
Definition at line 4191 of file vtkPVMessage.pb.h.
Definition at line 4066 of file vtkPVMessage.pb.h.
explicit |
| paraview_protobuf::ClientsInformation_ClientInfo::ClientsInformation_ClientInfo | ( | const ClientsInformation_ClientInfo & | from | ) |
inlinenoexcept |
Definition at line 4071 of file vtkPVMessage.pb.h.
explicitprotected |
Definition at line 4076 of file vtkPVMessage.pb.h.
inlinenoexcept |
Definition at line 4080 of file vtkPVMessage.pb.h.
Definition at line 4094 of file vtkPVMessage.pb.h.
Definition at line 4097 of file vtkPVMessage.pb.h.
inlinestatic |
Definition at line 4101 of file vtkPVMessage.pb.h.
inlinestatic |
Definition at line 4104 of file vtkPVMessage.pb.h.
inlinestatic |
Definition at line 4107 of file vtkPVMessage.pb.h.
inlinestatic |
Definition at line 4110 of file vtkPVMessage.pb.h.
inlinestatic |
Definition at line 4113 of file vtkPVMessage.pb.h.
Definition at line 4123 of file vtkPVMessage.pb.h.
Definition at line 4136 of file vtkPVMessage.pb.h.
inlinefinal |
Definition at line 4144 of file vtkPVMessage.pb.h.
| void paraview_protobuf::ClientsInformation_ClientInfo::CopyFrom | ( | const ClientsInformation_ClientInfo & | from | ) |
| void paraview_protobuf::ClientsInformation_ClientInfo::MergeFrom | ( | const ClientsInformation_ClientInfo & | from | ) |
final |
final |
final |
final |
final |
inlinefinal |
Definition at line 4161 of file vtkPVMessage.pb.h.
final |
final |
Definition at line 6522 of file vtkPVMessage.pb.h.
Definition at line 6525 of file vtkPVMessage.pb.h.
Definition at line 6529 of file vtkPVMessage.pb.h.
| void paraview_protobuf::ClientsInformation_ClientInfo::set_name | ( | ArgT0 && | arg0, |
| ArgT... | args | ||
Definition at line 6540 of file vtkPVMessage.pb.h.
Definition at line 6556 of file vtkPVMessage.pb.h.
Definition at line 6570 of file vtkPVMessage.pb.h.
Definition at line 6494 of file vtkPVMessage.pb.h.
Definition at line 6497 of file vtkPVMessage.pb.h.
Definition at line 6504 of file vtkPVMessage.pb.h.
Definition at line 6512 of file vtkPVMessage.pb.h.
Definition at line 6591 of file vtkPVMessage.pb.h.
Definition at line 6594 of file vtkPVMessage.pb.h.
Definition at line 6601 of file vtkPVMessage.pb.h.
Definition at line 6609 of file vtkPVMessage.pb.h.
Definition at line 6619 of file vtkPVMessage.pb.h.
Definition at line 6622 of file vtkPVMessage.pb.h.
Definition at line 6629 of file vtkPVMessage.pb.h.
Definition at line 6637 of file vtkPVMessage.pb.h.
Definition at line 6647 of file vtkPVMessage.pb.h.
Definition at line 6650 of file vtkPVMessage.pb.h.
Definition at line 6657 of file vtkPVMessage.pb.h.
Definition at line 6665 of file vtkPVMessage.pb.h.
Definition at line 6675 of file vtkPVMessage.pb.h.
Definition at line 6678 of file vtkPVMessage.pb.h.
Definition at line 6685 of file vtkPVMessage.pb.h.
Definition at line 6693 of file vtkPVMessage.pb.h.
Definition at line 6535 of file vtkPVMessage.pb.h.
friend |
Definition at line 4170 of file vtkPVMessage.pb.h.
friend |
Definition at line 4284 of file vtkPVMessage.pb.h.
friend |
Definition at line 4297 of file vtkPVMessage.pb.h.
friend |
Definition at line 4120 of file vtkPVMessage.pb.h.
Definition at line 4117 of file vtkPVMessage.pb.h.
Definition at line 4182 of file vtkPVMessage.pb.h.
