| function | paraview_generate_translation_header () |
| Generate a C++ header with input XML labels and UI strings that can be parsed by Qt Linguist tools. More... | |
| function | paraview_create_translation () |
| Generate a Qt translation source file from the given source files. More... | |
| function paraview_generate_translation_header | ( | ) |
It is using a python utility at Utilities/Localization/XML_translations_header_generator.py
TARGET: (Required) The name of the target that generate the translation header file.INPUT_FILES: (Required) The absolute path of the input files.RESULT_FILE: (Required) The absolute path of the desired result file. Definition at line 20 of file ParaViewTranslations.cmake.
| function paraview_create_translation | ( | ) |
TARGET: (Required) The name of the target that generate the translation source file.INPUT_FILES: (Required) The source files to search translatable strings in.OUTPUT_TS: (Required) The absolute path of the desired result file. Definition at line 70 of file ParaViewTranslations.cmake.
