WrappedPython_XArrayCFReader_XArrayCFReader.h
1 // Loadable modules
2 //
3 // Generated by /builds/gitlab-kitware-sciviz-ci/build/bin/vtkProcessXML-pv6.2
4 //
5 #ifndef WrappedPython_XArrayCFReader_XArrayCFReader_h
6 #define WrappedPython_XArrayCFReader_XArrayCFReader_h
7
8 #include <cstring>
9 #include <cassert>
10 #include <algorithm>
11
12
13 // From file /builds/gitlab-kitware-sciviz-ci/Plugins/XArrayCFReader/XArrayCFReader.py
15 "import os.path\n"
16 "from paraview.util.vtkAlgorithm import *\n"
17 "from vtkmodules.util.xarray_support import vtkXArrayCFReader\n"
18 "from vtkmodules.vtkCommonExecutionModel import vtkStreamingDemandDrivenPipeline\n"
19 "\n"
20 "@smproxy.reader(name=\"XArrayCFReader\", label=\"XArrayCF Reader\",\n"
21 " extensions=\"nc h5 zgroup grib\", file_description=\"XArray files\")\n"
22 "class XArrayCFReader(vtkXArrayCFReader):\n"
23 " '''Reads data from a file using the XArray readers and then connects\n"
24 " the XArray data to the vtkNetCDFCFREader (using zero-copy when\n"
25 " possible). At the moment, data is copied for coordinates (because\n"
26 " they are converted to double in the reader) and for certain data\n"
27 " that is subset either in XArray or in VTK. Lazy loading in XArray\n"
28 " is respected, that is data is accessed only when it is needed.\n"
29 " Time is passed to VTK either as an int64 for datetime64 or\n"
30 " timedelta64, or as a double (using cftime.toordinal) for cftime.\n"
31 " '''\n"
32 " def __init__(self):\n"
33 " super().__init__()\n"
34 "\n"
35 " @smproperty.stringvector(name=\"FileName\")\n"
36 " @smdomain.filelist()\n"
37 " @smhint.filechooser(extensions=\"nc,h5,zgroup,grib\", file_description=\"XArray files\")\n"
38 " def SetFileName(self, name):\n"
39 " \"\"\"Specify filename for the file to read.\"\"\"\n"
40 " if os.path.basename(name) == '.zgroup':\n"
41 " super().SetFileName(os.path.dirname(name))\n"
42 " else:\n"
43 " super().SetFileName(name)\n"
44 "\n"
45 "\n"
46 " @smproperty.stringvector(name=\"DimensionInfo\", information_only=\"1\")\n"
47 " @smdomain.xml(\"\"\"<StringArrayHelper />\"\"\")\n"
48 " def GetAllDimensions(self):\n"
49 " # cannot use super(). see https://stackoverflow.com/questions/12047847/super-object-not-calling-getattr\n"
50 " all_dims = self._reader.GetAllDimensions()\n"
51 " return all_dims\n"
52 "\n"
53 "\n"
54 " @smproperty.stringvector(name=\"Dimensions\", number_of_elements=\"1\")\n"
55 " @smdomain.xml(\\\n"
56 " \"\"\"<StringListDomain name=\"array_list\">\n"
57 " <RequiredProperties>\n"
58 " <Property name=\"DimensionInfo\" function=\"ArrayList\"/>\n"
59 " </RequiredProperties>\n"
60 " </StringListDomain>\n"
61 " <Documentation>Load the grid with the given dimensions. Any arrays that\n"
62 " conform to these dimensions will be loaded.</Documentation>\n"
63 " \"\"\")\n"
64 " def SetDimensions(self, dims):\n"
65 " # cannot use super(). see https://stackoverflow.com/questions/12047847/super-object-not-calling-getattr\n"
66 " if dims != 'None':\n"
67 " self._reader.SetDimensions(dims)\n"
68 " self.Modified()\n"
69 "\n"
70 "\n"
71 " @smproperty.intvector(name=\"SphericalCoordinates\", number_of_elements=\"1\",\n"
72 " default_values=\"1\")\n"
73 " @smdomain.xml(\\\n"
74 " \"\"\"<BooleanDomain name=\"bool\" />\n"
75 " <Documentation>If on, then data with latitude/longitude dimensions will\n"
76 " be read in as curvilinear data shaped like spherical coordinates. If\n"
77 " false, then the data will always be read in Cartesian\n"
78 " coordinates.</Documentation>\n"
79 " \"\"\")\n"
80 " def SetSphericalCoordinates(self, spherical):\n"
81 " # cannot use super(). see https://stackoverflow.com/questions/12047847/super-object-not-calling-getattr\n"
82 " self._reader.SetSphericalCoordinates(spherical)\n"
83 " self.Modified()\n"
84 "\n"
85 " @smproperty.doublevector(name=\"VerticalScale\", number_of_elements=\"1\",\n"
86 " default_values=\"1\")\n"
87 " @smdomain.xml(\\\n"
88 " \"\"\"<DoubleRangeDomain name=\"range\" />\n"
89 " <Documentation>The scale of the vertical component of spherical\n"
90 " coordinates. It is common to write the vertical component with respect\n"
91 " to something other than the center of the sphere (for example, the\n"
92 " surface). In this case, it might be necessary to scale and/or bias the\n"
93 " vertical height. The height will become height*scale + bias. Keep in\n"
94 " mind that if the positive attribute of the vertical dimension is down,\n"
95 " then the height is negated. The scaling will be adjusted if it results\n"
96 " in invalid (negative) vertical values.</Documentation>\n"
97 " \"\"\")\n"
98 " def SetVerticalScale(self, scale):\n"
99 " # cannot use super(). see https://stackoverflow.com/questions/12047847/super-object-not-calling-getattr\n"
100 " self._reader.SetVerticalScale(scale)\n"
101 " self.Modified()\n"
102 "\n"
103 "\n"
104 " @smproperty.doublevector(name=\"VerticalBias\", number_of_elements=\"1\",\n"
105 " default_values=\"0\")\n"
106 " @smdomain.xml(\\\n"
107 " \"\"\"<DoubleRangeDomain name=\"range\" />\n"
108 " <Documentation>The bias of the vertical component of spherical\n"
109 " coordinates. It is common to write the vertical component with respect\n"
110 " to something other than the center of the sphere (for example, the\n"
111 " surface). In this case, it might be necessary to scale and/or bias the\n"
112 " vertical height. The height will become height*scale + bias. Keep in\n"
113 " mind that if the positive attribute of the vertical dimension is down,\n"
114 " then the height is negated. The scaling will be adjusted if it results\n"
115 " in invalid (negative) vertical values.</Documentation>\n"
116 " \"\"\")\n"
117 " def SetVerticalBias(self, bias):\n"
118 " # cannot use super(). see https://stackoverflow.com/questions/12047847/super-object-not-calling-getattr\n"
119 " self._reader.SetVerticalBias(bias)\n"
120 " self.Modified()\n"
121 "\n"
122 " @smproperty.intvector(name=\"ReplaceFillValueWithNan\", number_of_elements=\"1\",\n"
123 " default_values=\"0\")\n"
124 " @smdomain.xml(\\\n"
125 " \"\"\"<BooleanDomain name=\"bool\" />\n"
126 " <Documentation>If on, any float or double variable read that has a\n"
127 " _FillValue attribute will have that fill value replaced with a\n"
128 " not-a-number (NaN) value. The advantage of setting these to NaN values\n"
129 " is that, if implemented properly by the system and careful math\n"
130 " operations are used, they can implicitly be ignored by calculations\n"
131 " like finding the range of the values. That said, this option should be\n"
132 " used with caution as VTK does not fully support NaN values and\n"
133 " therefore odd calculations may occur.</Documentation>\n"
134 " \"\"\")\n"
135 " def SetReplaceFillValueWithNan(self, replace):\n"
136 " # cannot use super(). see https://stackoverflow.com/questions/12047847/super-object-not-calling-getattr\n"
137 " self._reader.SetReplaceFillValueWithNan(replace)\n"
138 " self.Modified()\n"
139 "\n"
140 " @smproperty.intvector(name=\"OutputType\", number_of_elements=\"1\",\n"
141 " default_values=\"-1\")\n"
142 " @smdomain.xml(\\\n"
143 " \"\"\"<EnumerationDomain name=\"enum\">\n"
144 " <Entry text=\"Automatic\"\n"
145 " value=\"-1\" />\n"
146 " <Entry text=\"Image\"\n"
147 " value=\"6\" />\n"
148 " <Entry text=\"Rectilinear\"\n"
149 " value=\"3\" />\n"
150 " <Entry text=\"Structured\"\n"
151 " value=\"2\" />\n"
152 " <Entry text=\"Unstructured\"\n"
153 " value=\"4\" />\n"
154 " </EnumerationDomain>\n"
155 " <Documentation>Specifies the type of data that the reader creates. If\n"
156 " Automatic, the reader will use the most appropriate grid type for the\n"
157 " data read. Note that not all grid types support all data. A warning is\n"
158 " issued if a mismatch occurs.</Documentation>\n"
159 " \"\"\")\n"
160 " def SetOutputType(self, output_type):\n"
161 " # cannot use super(). see https://stackoverflow.com/questions/12047847/super-object-not-calling-getattr\n"
162 " self._reader.SetOutputType(output_type)\n"
163 " self.Modified()\n"
164 "\n"
165 "\n"
166 " @smproperty.doublevector(name=\"TimestepValues\", information_only=\"1\", si_class=\"vtkSITimeStepsProperty\")\n"
167 " def GetTimestepValues(self):\n"
168 " information = self.GetOutputInformation(0)\n"
169 " if information.Has(vtkStreamingDemandDrivenPipeline.TIME_STEPS()):\n"
170 " times = information.Get(vtkStreamingDemandDrivenPipeline.TIME_STEPS())\n"
171 " return times\n"
172 " else:\n"
173 " return []\n"
174 "\n";
175 // Get single string
177 {
178
179  const size_t len0 = strlen(module_XArrayCFReader_XArrayCFReader_string0);
180  size_t len = ( 0
181  + len0 );
182  char* res = new char[ len + 1];
183  size_t offset = 0;
185  assert(offset == len);
186  res[offset] = 0;
187  return res;
188 }
189
190
191
192 #endif
offset
char * module_XArrayCFReader_XArrayCFReader_source()
static const char *const module_XArrayCFReader_XArrayCFReader_string0
