View Issue Details [ Jump to Notes ] [ Print ]
0009867ParaViewBugpublic2009-11-09 10:502010-03-03 21:36
ReporterStephane P
Assigned ToDavid Partyka
StatusclosedResolutionfixed
PlatformOSOS Version
Product VersionDevelopment
Target VersionFixed in Version3.8
Summary0009867: building server side plugin against install tree (with PARAVIEW_INSTALL_DEVELOPMENT ON) create unloadable plugins
Descriptionwhen building a plugin (a reader for instance) against the install tree of ParaView, the created plugins fails to load in ParaView with the message :
"MyPlugin.so is not a valid Qt Plugin"
ParaView must have been built with the option PARAVIEW_INSTALL_DEVELOPMENT set to ON
The same plugin loads correctly if built against the build tree of ParaView.
Additional InformationDuring the configuration process, cmake complains (warnings) that it cannot find safe path for the Qt libraries, which are availbale both from the system and from the ParaView install tree, it might be related.
TagsNo tags attached.
ProjectParaViS
Topic Name
Type
 Relationships
child of 0009998closedDavid Partyka Installation Issues
  Notes
(0019702)
2010-03-03 16:42
Stephane reports it has been fixed.
(0019705)
Alan Scott (manager)
2010-03-03 21:36
Reporter states that this has been fixed.
 Issue History
2009-11-09 10:50 Stephane P New Issue
2009-12-05 11:48 Utkarsh Ayachit Relationship added child of 0009998
2010-03-03 16:42 Utkarsh Ayachit Status backlog => tabled
2010-03-03 16:42 Utkarsh Ayachit Assigned To => David Partyka
2010-03-03 16:42 Utkarsh Ayachit Note Added: 0019702
2010-03-03 16:42 Utkarsh Ayachit Status tabled => @80@
2010-03-03 16:42 Utkarsh Ayachit Fixed in Version => 3.8
2010-03-03 16:42 Utkarsh Ayachit Resolution open => fixed
2010-03-03 21:36 Alan Scott Note Added: 0019705
2010-03-03 21:36 Alan Scott Status @80@ => closed
2011-06-23 11:44 Utkarsh Ayachit Project => ParaViS
