| 0009671 | ParaView | Feature | public | 2009-10-07 11:21 | 2010-01-20 18:28 | ||||
| Reporter | Ken Moreland | ||||||||
| Priority | high | Severity | minor | Reproducibility | have not tried | ||||
| Product Version | |||||||||
| Target Version | 3.8 | Fixed in Version | 3.8 | ||||||
| Summary | 0009671: Plugin Manager should list plugins compiled/distributed with ParaView | ||||||||
| Description | When ParaView is compiled or installed, any plugin located in ParaView3/Plugins and is compiled should be listed in the Plugin Manager by default even though they are not loaded by default. This makes it easier for users to find these plugins and enable them. | ||||||||
| Project | |||||||||
| Topic Name | |||||||||
| Type | |||||||||
| Attached Files | |||||||||
| Relationships | ||||||
| Relationships |
| Notes | |
(0018719) Alan Scott (manager) 2009-12-07 16:34 |
This is going to be required for the Prism plugin for 3.8.0, so I am making it a higher priority. Needs to be in PV 3.8.0. |
(0018804) Utkarsh Ayachit (administrator) 2009-12-10 15:29 |
Added support for a ".plugins" xml file that is provided next to the paraview executable that lists the packaged plugins which are listed by the plugin manager by default. /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMPluginManager.h,v <-- Servers/ServerManager/vtkSMPluginManager.h new revision: 1.5; previous revision: 1.4 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMPluginManager.cxx,v <-- Servers/ServerManager/vtkSMPluginManager.cxx new revision: 1.9; previous revision: 1.8 /cvsroot/ParaView3/ParaView3/Qt/Core/pqApplicationCore.h,v <-- Qt/Core/pqApplicationCore.h new revision: 1.43; previous revision: 1.42 /cvsroot/ParaView3/ParaView3/Qt/Core/pqApplicationCore.cxx,v <-- Qt/Core/pqApplicationCore.cxx new revision: 1.95; previous revision: 1.94 /cvsroot/ParaView3/ParaView3/Qt/ApplicationComponents/pqParaViewBehaviors.cxx,v <-- Qt/ApplicationComponents/pqParaViewBehaviors.cxx new revision: 1.3; previous revision: 1.2 /cvsroot/ParaView3/ParaView3/Plugins/CMakeLists.txt,v <-- Plugins/CMakeLists.txt new revision: 1.50; previous revision: 1.49 /cvsroot/ParaView3/ParaView3/CMake/ParaViewPlugins.cmake,v <-- CMake/ParaViewPlugins.cmake new revision: 1.59; previous revision: 1.58 /cvsroot/ParaView3/ParaView3/Applications/ParaView/CMakeLists.txt,v <-- Applications/ParaView/CMakeLists.txt new revision: 1.2; previous revision: 1.1 /cvsroot/ParaView3/ParaView3/CMakeLists.txt,v <-- CMakeLists.txt new revision: 1.120; previous revision: 1.119 |
(0018806) Utkarsh Ayachit (administrator) 2009-12-10 17:07 |
Issues still exist on mac locating the plugins from build directory. So reopening this. |
(0019008) Utkarsh Ayachit (administrator) 2009-12-29 11:18 |
Fixed mac issues. Simply run ParaView with -dr option to see if the plugin list is loaded correctly. |
(0019231) Alan Scott (manager) 2010-01-20 18:28 |
Assuming it works, since I don't have a mac. |
| Notes |
| Issue History | |||
| 2009-10-07 11:21 | Ken Moreland | New Issue | |
| 2009-12-07 16:34 | Alan Scott | Note Added: 0018719 | |
| 2009-12-07 16:34 | Alan Scott | Priority | normal => high |
| 2009-12-09 09:48 | Utkarsh Ayachit | Relationship added | related to 0010005 |
| 2009-12-10 15:27 | Utkarsh Ayachit | Status | backlog => tabled |
| 2009-12-10 15:27 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
| 2009-12-10 15:29 | Utkarsh Ayachit | Note Added: 0018804 | |
| 2009-12-10 15:29 | Utkarsh Ayachit | Status | tabled => @80@ |
| 2009-12-10 15:29 | Utkarsh Ayachit | Fixed in Version | => 3.8 |
| 2009-12-10 15:29 | Utkarsh Ayachit | Resolution | open => fixed |
| 2009-12-10 17:07 | Utkarsh Ayachit | Note Added: 0018806 | |
| 2009-12-10 17:07 | Utkarsh Ayachit | Status | @80@ => tabled |
| 2009-12-29 11:18 | Utkarsh Ayachit | Note Added: 0019008 | |
| 2009-12-29 11:18 | Utkarsh Ayachit | Status | tabled => @80@ |
| 2010-01-20 18:28 | Alan Scott | Note Added: 0019231 | |
| 2010-01-20 18:28 | Alan Scott | Status | @80@ => closed |
| 2011-06-16 13:10 | Zack Galbreath | Category | Feature Request => Feature |
| Issue History |
