| 0009515 | ParaView | Bug | public | 2009-09-09 15:53 | 2009-09-22 21:51 | ||||
| Priority | high | Severity | minor | Reproducibility | always | ||||
| Product Version | |||||||||
| Target Version | 3.6.2 | Fixed in Version | 3.6.2 | ||||||
| Summary | 0009515: Selecting multiple cells doesn't work with ParaView 3.6 | ||||||||
| Description | ParaView 3.6.0, local server, XP. Sources/ sphere. Apply. Select Cells On, select a call. Select Cells On, hold down the <CTRL> key, select another cell. <<BUG>> - Both cells should be selected. Needs to be fixed for 3.6.2. | ||||||||
| Project | |||||||||
| Topic Name | |||||||||
| Type | |||||||||
| Attached Files | |||||||||
| Relationships | ||||||
| Relationships |
| Notes | |
(0017360) Utkarsh Ayachit (administrator) 2009-09-09 16:16 edited on: 2009-09-09 16:23 |
/cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMSelectionHelper.cxx,v <-- Servers/ServerManager/vtkSMSelectionHelper.cxx new revision: 1.21; previous revision: 1.20 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMSelectionHelper.cxx,v <-- Servers/ServerManager/vtkSMSelectionHelper.cxx new revision: 1.20.4.1; previous revision: 1.20 |
(0017368) Utkarsh Ayachit (administrator) 2009-09-10 09:37 |
Now it's possible to expand global-id based selections as well. We convert the new id-based selection to global-id based if needed so that the expansion is possible. /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMSelectionHelper.h,v <-- Servers/ServerManager/vtkSMSelectionHelper.h new revision: 1.8; previous revision: 1.7 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMSelectionHelper.cxx,v <-- Servers/ServerManager/vtkSMSelectionHelper.cxx new revision: 1.22; previous revision: 1.21 /cvsroot/ParaView3/ParaView3/Qt/Core/pqRenderView.cxx,v <-- Qt/Core/pqRenderView.cxx new revision: 1.47; previous revision: 1.46 |
(0017369) Utkarsh Ayachit (administrator) 2009-09-10 09:44 |
/cvsroot/ParaView3/ParaView3/Qt/Core/pqRenderView.cxx,v <-- Qt/Core/pqRenderView.cxx new revision: 1.46.2.1; previous revision: 1.46 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMSelectionHelper.cxx,v <-- Servers/ServerManager/vtkSMSelectionHelper.cxx new revision: 1.20.4.2; previous revision: 1.20.4.1 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMSelectionHelper.h,v <-- Servers/ServerManager/vtkSMSelectionHelper.h new revision: 1.7.4.1; previous revision: 1.7 |
(0017717) Alan Scott (manager) 2009-09-22 21:51 |
Tested local server, trunk. |
| Notes |
| Issue History | |||
| 2009-09-09 15:53 | Alan Scott | New Issue | |
| 2009-09-09 15:55 | Alan Scott | Summary | Selecting multiple objects doesn't work with ParaView 3.6 => Selecting multiple cells doesn't work with ParaView 3.6 |
| 2009-09-09 16:16 | Utkarsh Ayachit | Note Added: 0017360 | |
| 2009-09-09 16:23 | Utkarsh Ayachit | Note Edited: 0017360 | |
| 2009-09-10 09:37 | Utkarsh Ayachit | Note Added: 0017368 | |
| 2009-09-10 09:44 | Utkarsh Ayachit | Note Added: 0017369 | |
| 2009-09-10 09:44 | Utkarsh Ayachit | Status | backlog => @80@ |
| 2009-09-10 09:44 | Utkarsh Ayachit | Fixed in Version | => 3.6.2 |
| 2009-09-10 09:44 | Utkarsh Ayachit | Resolution | open => fixed |
| 2009-09-10 09:44 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
| 2009-09-22 21:51 | Alan Scott | Note Added: 0017717 | |
| 2009-09-22 21:51 | Alan Scott | Status | @80@ => closed |
| 2009-09-25 16:46 | Alan Scott | Relationship added | has duplicate 0009472 |
| Issue History |
