| 0009501 | ParaView | Bug | public | 2009-09-07 04:42 | 2016-08-12 09:57 | ||||
| Reporter | jkomin | ||||||||
| Assigned To | Kitware Robot | ||||||||
| Priority | normal | Severity | minor | Reproducibility | always | ||||
| Status | closed | Resolution | moved | ||||||
| Product Version | 3.6 | ||||||||
| Summary | 0009501: (probably a general VTK error) non-convex quads are drawn incorrectly | ||||||||
| Description | ParaView draws non-convex, non self-intersecting quads incorrectly. It seems that the problem is the following: to draw a quad, it splits it into two triangles, but since the quad is non-convex there is only one correct way of doing it. It seems that ParaView (or VTK) sometimes makes the wrong decision. From what I can tell, ParaView takes the quad (a, b, c, d) and makes triangles (a, b, c) and (a, c, d), without checking for convexity. Because the description of class vtkQuad does not mention convexity, this is a bug. | ||||||||
| Project | |||||||||
| Topic Name | |||||||||
| Type | |||||||||
| Attached Files | |||||||||
| Relationships | |
| Relationships |
| Notes | |
(0037699) Kitware Robot (administrator) 2016-08-12 09:57 |
| Notes |
| Issue History | |||
| 2009-09-07 04:42 | jkomin | New Issue | |
| 2016-08-12 09:57 | Kitware Robot | Note Added: 0037699 | |
| 2016-08-12 09:57 | Kitware Robot | Status | expired => closed |
| 2016-08-12 09:57 | Kitware Robot | Resolution | open => moved |
| 2016-08-12 09:57 | Kitware Robot | Assigned To | => Kitware Robot |
| Issue History |
