0008157 | VTK | (No Category) | public | 2008-11-24 19:30 | 2016-08-12 09:55 | ||||
Reporter | Michael Halle | ||||||||
Summary | 0008157: vtkOBJExporter doesn't scale its colors by the appropriate factors | ||||||||
Description | vtkOBJExporter creates a material file (.mtl) with information about the material properties of each actor. When the exporter accesses the ambient, specular, and diffuse colors, it fails to multiply the values by the ambient, specular, and diffuse scaling coefficients like it should. Since the ambient, specular, and diffuse colors are by default (1, 1, 1), having all of them at 100% produces very bright default output. Fix is to just scale the tempd[0..2] values by the appropriate constant for the three colors. | ||||||||
(0037042) Kitware Robot (administrator) 2016-08-12 09:55 |
Resolving issue as `moved`. This issue tracker is no longer used. Further discussion of this issue may take place in the current VTK Issues page linked in the banner at the top of this page. |
2008-11-24 19:30 | Michael Halle | New Issue | |
2016-08-12 09:55 | Kitware Robot | Note Added: 0037042 | |
2016-08-12 09:55 | Kitware Robot | Status | expired => closed |
2016-08-12 09:55 | Kitware Robot | Resolution | open => moved |
2016-08-12 09:55 | Kitware Robot | Assigned To | => Kitware Robot |
