| 0006779 | ParaView | (No Category) | public | 2008-04-09 17:25 | 2011-01-13 17:00 | ||||
| Reporter | Ken Moreland | ||||||||
| Product Version | |||||||||
| Target Version | 3.4 | Fixed in Version | 3.4 | ||||||
| Summary | 0006779: Cannot save Exodus as anything | ||||||||
| Description | Open an exodus file (like disk_out_ref or can). Then try to save the data. ParaView gives no choice for the file type and raises an error if you try to select a file to save to. | ||||||||
| Project | |||||||||
| Topic Name | |||||||||
| Type | |||||||||
| Attached Files | |||||||||
| Relationships | ||||||||||||||||
| Relationships |
| Notes | |
(0012216) Utkarsh Ayachit (administrator) 2008-06-03 11:04 |
It can be saved as vtm. There's another bug for fixing the exodus writer to write multiblock datasets. |
(0012244) Alan Scott (manager) 2008-06-04 16:21 |
vtm doesn't work. Try the following: Client/server, 6 servers. Open up disk_out_ref.exo. All variables on. Apply. Save as junk.vtm. Edit/Delete all. File/ Open/ junk.vtm. Apply. Output is as follows: ERROR: In C:\alan\paraviewNightlyTrunk\src\ParaView3\VTK\IO\vtkDataReader.cxx, line 763 vtkPolyDataReader (0A527038): Unsupported cell attribute type: ² for file: (Null FileName) Should we keep this bug open, or close it and open another for vtm files? |
(0012245) Alan Scott (manager) 2008-06-04 16:23 |
One more note, after the bug listed above, you cannot color junk.vtm by anything. |
(0012858) Utkarsh Ayachit (administrator) 2008-07-29 13:02 |
Fixing the vtm reading problem. /cvsroot/ParaView3/ParaView3/VTK/IO/vtkXMLReader.cxx,v <-- VTK/IO/vtkXMLReader.cxx new revision: 1.53; previous revision: 1.52 |
(0012865) Alan Scott (manager) 2008-07-29 14:09 |
We need a vtm fix. |
(0012866) Alan Scott (manager) 2008-07-29 14:10 |
Woops, I didn't see that Utkarsh had already fixed it. |
(0012962) Alan Scott (manager) 2008-08-07 16:14 |
This is giving me troubles still, using can.exo. client/server, but I suspect that doesn't matter. Open can.exo. All variables on (but shouldn't matter) Save as junk.vtm. Delete all Open junk.vtm. Output is as listed below, Unsupported cell attribute type: give me a call if you think I am in error. |
(0013077) Utkarsh Ayachit (administrator) 2008-08-19 15:20 |
The issue is due to the fact that vtm writers cannot write in parallel correctly. BUG 0006698 captures that issue, hence I am making this resolved (since the original bug is indeed resolved). |
(0013080) Alan Scott (manager) 2008-08-19 15:28 |
The issue i was having is that the vtm writer is not parallel. It works serial. Closed. |
| Notes |
| Issue History | |||
| 2008-04-09 17:25 | Ken Moreland | New Issue | |
| 2008-04-09 17:25 | Ken Moreland | Status | backlog => tabled |
| 2008-04-09 17:25 | Ken Moreland | Assigned To | => Berk Geveci |
| 2008-04-09 17:27 | Ken Moreland | Relationship added | related to 0006780 |
| 2008-06-03 11:04 | Utkarsh Ayachit | Status | tabled => @80@ |
| 2008-06-03 11:04 | Utkarsh Ayachit | Resolution | open => no change required |
| 2008-06-03 11:04 | Utkarsh Ayachit | Note Added: 0012216 | |
| 2008-06-04 16:21 | Alan Scott | Status | @80@ => @20@ |
| 2008-06-04 16:21 | Alan Scott | Resolution | no change required => reopened |
| 2008-06-04 16:21 | Alan Scott | Note Added: 0012244 | |
| 2008-06-04 16:23 | Alan Scott | Note Added: 0012245 | |
| 2008-07-09 10:48 | Utkarsh Ayachit | Status | @20@ => tabled |
| 2008-07-09 10:48 | Utkarsh Ayachit | Assigned To | Berk Geveci => Utkarsh Ayachit |
| 2008-07-24 13:57 | Utkarsh Ayachit | Relationship added | duplicate of 0006885 |
| 2008-07-24 13:57 | Utkarsh Ayachit | Duplicate ID | 0 => 6885 |
| 2008-07-24 13:57 | Utkarsh Ayachit | Status | tabled => @80@ |
| 2008-07-24 13:57 | Utkarsh Ayachit | Resolution | reopened => duplicate |
| 2008-07-29 13:02 | Utkarsh Ayachit | Status | @80@ => @20@ |
| 2008-07-29 13:02 | Utkarsh Ayachit | Resolution | duplicate => reopened |
| 2008-07-29 13:02 | Utkarsh Ayachit | Status | @20@ => @80@ |
| 2008-07-29 13:02 | Utkarsh Ayachit | Resolution | reopened => fixed |
| 2008-07-29 13:02 | Utkarsh Ayachit | Note Added: 0012858 | |
| 2008-07-29 13:02 | Utkarsh Ayachit | Duplicate ID | 6885 => 0 |
| 2008-07-29 14:09 | Alan Scott | Status | @80@ => @20@ |
| 2008-07-29 14:09 | Alan Scott | Resolution | fixed => reopened |
| 2008-07-29 14:09 | Alan Scott | Note Added: 0012865 | |
| 2008-07-29 14:10 | Alan Scott | Status | @20@ => @80@ |
| 2008-07-29 14:10 | Alan Scott | Resolution | reopened => fixed |
| 2008-07-29 14:10 | Alan Scott | Note Added: 0012866 | |
| 2008-08-07 16:14 | Alan Scott | Status | @80@ => @20@ |
| 2008-08-07 16:14 | Alan Scott | Resolution | fixed => reopened |
| 2008-08-07 16:14 | Alan Scott | Note Added: 0012962 | |
| 2008-08-19 15:18 | Utkarsh Ayachit | Relationship added | related to 0006698 |
| 2008-08-19 15:20 | Utkarsh Ayachit | Status | @20@ => @80@ |
| 2008-08-19 15:20 | Utkarsh Ayachit | Resolution | reopened => fixed |
| 2008-08-19 15:20 | Utkarsh Ayachit | Note Added: 0013077 | |
| 2008-08-19 15:28 | Alan Scott | Status | @80@ => closed |
| 2008-08-19 15:28 | Alan Scott | Note Added: 0013080 | |
| 2009-05-13 13:58 | Utkarsh Ayachit | Target Version | => 3.4 |
| 2009-05-13 13:59 | Utkarsh Ayachit | Fixed in Version | => 3.4 |
| 2011-01-13 17:00 | Source_changeset_attached | => VTK master a2bd8391 | |
| 2011-01-13 17:00 | Source_changeset_attached | => VTK master 020ef709 | |
| 2011-06-16 13:10 | Zack Galbreath | Category | => (No Category) |
| Issue History |
