| 0005631 | ParaView | (No Category) | public | 2007-08-30 14:49 | 2016-08-12 09:57 | ||||
| Reporter | Ken Moreland | ||||||||
| Assigned To | Eric Stanton | ||||||||
| Priority | normal | Severity | minor | Reproducibility | always | ||||
| Status | closed | Resolution | moved | ||||||
| Product Version | |||||||||
| Summary | 0005631: Allow fast-path temporal plots through array calculator | ||||||||
| Description | Right now you can do "fast-path" temporal plots (plot cell/point/field over time) if the respective filter is connected directly to the exodus reader. This should also work if the array calculator is in between the reader and plotting filter. To do this, the array calculator has to be aware of the special convention for passing this array of data over time. | ||||||||
| Project | |||||||||
| Topic Name | |||||||||
| Type | |||||||||
| Attached Files | |||||||||
| Relationships | |||||||||||
| Relationships |
| Notes | |
(0037532) Kitware Robot (administrator) 2016-08-12 09:57 |
| Notes |
| Issue History | |||
| 2007-08-30 14:49 | Ken Moreland | New Issue | |
| 2007-08-30 14:49 | Ken Moreland | Relationship added | child of 0004941 |
| 2007-08-30 14:49 | Ken Moreland | Assigned To | => Eric Stanton |
| 2007-08-30 14:49 | Ken Moreland | Status | backlog => tabled |
| 2007-08-30 14:52 | Ken Moreland | Relationship added | related to 0005632 |
| 2008-04-15 09:32 | Berk Geveci | Category | => 3.6 |
| 2009-02-16 16:04 | Ken Moreland | Category | 3.6 => 3.8 |
| 2009-05-13 13:41 | Utkarsh Ayachit | Target Version | => 3.8 |
| 2011-06-16 13:10 | Zack Galbreath | Category | => (No Category) |
| 2016-08-12 09:57 | Kitware Robot | Note Added: 0037532 | |
| 2016-08-12 09:57 | Kitware Robot | Status | expired => closed |
| 2016-08-12 09:57 | Kitware Robot | Resolution | open => moved |
| Issue History |
