| 0005512 | ParaView | (No Category) | public | 2007-08-15 17:55 | 2007-08-21 12:13 | ||||
| Reporter | Ken Moreland | ||||||||
| Assigned To | Clinton Stimpson | ||||||||
| Priority | high | Severity | minor | Reproducibility | always | ||||
| Product Version | |||||||||
| Summary | 0005512: Deleted track space not consumed | ||||||||
| Description | When you delete a track from the animation view (which right now you can only do by removing all of the keyframes within the animation inspector), the space that it was taken up by the tracks is not consumed by the panel. The current time line still descends down to where the track used to be. If there was a scroll bar, it scrolls down to empty space where the track used to be. | ||||||||
| Project | |||||||||
| Topic Name | |||||||||
| Type | |||||||||
| Attached Files | |||||||||
| Relationships | ||||||
| Relationships |
| Notes | |
(0008496) Clinton Stimpson (developer) 2007-08-16 19:15 |
Partial fix. /cvsroot/ParaView3/ParaView3/Qt/Widgets/pqAnimationModel.cxx,v <-- pqAnimationModel.cxx new revision: 1.21; previous revision: 1.20 Still need to remove scrollbars when shrinking scene. |
(0008515) Clinton Stimpson (developer) 2007-08-20 13:33 |
/cvsroot/ParaView3/ParaView3/Qt/Widgets/pqAnimationWidget.cxx,v <-- pqAnimationWidget.cxx new revision: 1.8; previous revision: 1.7 |
| Notes |
| Issue History | |||
| 2007-08-15 17:55 | Ken Moreland | New Issue | |
| 2007-08-15 17:55 | Ken Moreland | Relationship added | related to 0003340 |
| 2007-08-15 17:55 | Ken Moreland | Assigned To | => Clinton Stimpson |
| 2007-08-15 17:55 | Ken Moreland | Priority | normal => high |
| 2007-08-15 17:55 | Ken Moreland | Status | backlog => tabled |
| 2007-08-16 19:15 | Clinton Stimpson | Note Added: 0008496 | |
| 2007-08-20 13:33 | Clinton Stimpson | Status | tabled => @80@ |
| 2007-08-20 13:33 | Clinton Stimpson | Resolution | open => fixed |
| 2007-08-20 13:33 | Clinton Stimpson | Note Added: 0008515 | |
| 2007-08-21 12:13 | Ken Moreland | Status | @80@ => closed |
| 2011-06-16 13:10 | Zack Galbreath | Category | => (No Category) |
| Issue History |
