0002561VTK(No Category)public2005-12-05 16:052005-12-07 11:09
ReporterBrad King
Assigned ToBrad King
PriorityurgentSeveritymajorReproducibilityalways
StatusclosedResolutionfixed
PlatformOSOS Version
Product Version
Summary0002561: vtkXMLWriter::ReserveAttributeSpace does not reserve enough
DescriptionThe original version of vtkXMLWriter::ReserveAttributeSpace was intended to write the empty space for an XML attribute value that will be a 32-bit integer. Since then uses of the method have been added for 64-bit integers and double-precision floating-point values. The method no longer reserves enough space. It should be re-written to have an interface that allows specification of the longest possible value.
TagsNo tags attached.
Project
Type
 Relationships
  Notes
(0003358)
Brad King (developer)
2005-12-05 16:08
I\'m assigning this bug to myself because I originally wrote the method and discovered the bug when trying to save some data from ParaView.
I\'m adding Ken and Mathieu on CC because they made changes related to this problem.
(0003360)
2005-12-06 10:25
The following changes fix this bug:
/cvsroot/VTK/VTK/IO/vtkXMLWriter.cxx,v <-- vtkXMLWriter.cxx
new revision: 1.61; previous revision: 1.60
/cvsroot/VTK/VTK/IO/vtkXMLWriter.h,v <-- vtkXMLWriter.h
new revision: 1.24; previous revision: 1.23
(0003361)
2005-12-06 11:59
I'm assigning this bug to Dave to merge to the VTK 5.0 branch.
(0003369)
David Cole (developer)
2005-12-07 10:37
Merged into the VTK-5-0 branch. Assigning back to Brad for closure...
(0003371)
2005-12-07 11:09
This fix has also been ported to the ParaView 2.4 branch. I'm now closing the bug.
 Issue History
