0002187 | VTK | (No Category) | public | 2005-08-24 21:49 | 2012-12-12 12:13 | ||||
Reporter | Simon Warfield | ||||||||
Assigned To | David Gobbi | ||||||||
Target Version | Fixed in Version | 5.6.0 | |||||||
Summary | 0002187: vtkImageBlend sets input on port 1 instead of connection 1 | ||||||||
Description | vtkImageAlgorithm has an AddInput method and a SetInput method which are intended to add or set the input at a particular index. These methods in turn call vtkAlgorithm AddInputConnection and SetInputConnection, but translate the index into a port. The upshot of this is that an attempt to set the second input at index 1 on port 0 instead sets index 0 on port 1. vtkImageBlend uses port 1 exclusively for vtkImageStencil data and the result is a runtime failure with a type mismatch. Basically the bug is that these are incompatible: void vtkImageAlgorithm::SetInput(int index, vtkDataObject* input) void vtkAlgorithm::SetInputConnection(int port, vtkAlgorithmOutput* input) Also, the workaround of calling SetInputConnection directly is difficult to discern as the pipeline documentation is not completely clear. Basically a sequence like the following is necessary: vtkImageData *input1; vtkImageData *input2; vtkImageData *input3; blend->SetStencil(stencil); blend->AddInputConnection(0, input1->GetProducerPort()); blend->AddInputConnection(0, input2->GetProducerPort()); // THERE IS NO REMOVEINPUT - WOULD BE GOOD TO HAVE IT blend->RemoveInput( input1->GetProducerPort()); // UNDESIRABLE blend->SetInput(0, 0); // Removes all inputs ???? blend->RemoveInputConnection(0,input2->GetProducerPort()); // seems to do the job.... // Not immediately obvious that calling GetProducerPort() generates a vtkAlgorithmOutput *. blend->AddInputConnection(0, input3->GetProducerPort()); | ||||||||
(0002959) Brad King (developer) 2005-08-25 08:57 |
I've changed the version number for this bug to "Devel" because it is not a VTK 4.x problem. Most of the problem here is in the documentation. I've committed the following changes to make this more clear: /cvsroot/VTK/VTK/Filtering/vtkAlgorithm.h,v <-- vtkAlgorithm.h new revision: 1.25; previous revision: 1.24 /cvsroot/VTK/VTK/Filtering/vtkDataObjectAlgorithm.h,v <-- vtkDataObjectAlgorithm.h new revision: 1.4; previous revision: 1.3 /cvsroot/VTK/VTK/Filtering/vtkDataSetAlgorithm.h,v <-- vtkDataSetAlgorithm.h new revision: 1.11; previous revision: 1.10 /cvsroot/VTK/VTK/Filtering/vtkGenericDataSetAlgorithm.h,v <-- vtkGenericDataSetAlgorithm.h new revision: 1.4; previous revision: 1.3 /cvsroot/VTK/VTK/Filtering/vtkHierarchicalDataSetAlgorithm.h,v <-- vtkHierarchicalDataSetAlgorithm.h new revision: 1.7; previous revision: 1.6 /cvsroot/VTK/VTK/Filtering/vtkImageAlgorithm.h,v <-- vtkImageAlgorithm.h new revision: 1.14; previous revision: 1.13 /cvsroot/VTK/VTK/Filtering/vtkPiecewiseFunctionAlgorithm.h,v <-- vtkPiecewiseFunctionAlgorithm.h new revision: 1.3; previous revision: 1.2 /cvsroot/VTK/VTK/Filtering/vtkPointSetAlgorithm.h,v <-- vtkPointSetAlgorithm.h new revision: 1.6; previous revision: 1.5 /cvsroot/VTK/VTK/Filtering/vtkPolyDataAlgorithm.h,v <-- vtkPolyDataAlgorithm.h new revision: 1.20; previous revision: 1.19 /cvsroot/VTK/VTK/Filtering/vtkRectilinearGridAlgorithm.h,v <-- vtkRectilinearGridAlgorithm.h new revision: 1.5; previous revision: 1.4 /cvsroot/VTK/VTK/Filtering/vtkStructuredGridAlgorithm.h,v <-- vtkStructuredGridAlgorithm.h new revision: 1.5; previous revision: 1.4 /cvsroot/VTK/VTK/Filtering/vtkUnstructuredGridAlgorithm.h,v <-- vtkUnstructuredGridAlgorithm.h new revision: 1.6; previous revision: 1.5 |
(0002960) Brad King (developer) 2005-08-25 09:11 |
I'm assigning this bug to Ken because he wrote vtkImageAlgorithm and converted vtkImageBlend to the new pipeline. The problem now is that vtkImageAlgorithm::SetInput transforms its index to a port number and states in its documentation that subclasses should not override it. I think we should change the policy to say that subclasses may override it but only to change the mapping to something backward-compatible for that subclass. In this case we want vtkImageBlend::SetInput to translate its index to a connection index on port 0. |
(0026189) David Gobbi (developer) 2011-04-15 17:31 |
This bug was fixed on Wed Apr 5 18:43:32 2006 -0400 commit 3f2dc76e776810d85624ed27587c63748b9da490 |
2008-02-06 10:17 | Jeff Baumes | Assigned To | => Berk Geveci |
2011-02-26 10:38 | David Gobbi | Assigned To | Berk Geveci => David Gobbi |
2011-04-15 17:31 | David Gobbi | Note Added: 0026189 | |
2011-04-15 17:31 | David Gobbi | Status | tabled => @80@ |
2011-04-15 17:31 | David Gobbi | Resolution | open => fixed |
2012-12-12 12:13 | David Gobbi | Status | customer review => closed |
2012-12-12 12:13 | David Gobbi | Fixed in Version | => 5.6.0 |
