| 0016112 | ParaView | (No Category) | public | 2016-05-06 16:50 | 2016-07-25 21:44 | ||||
| Reporter | Sujin Philip | ||||||||
| Assigned To | Cory Quammen | ||||||||
| Product Version | |||||||||
| Target Version | Fixed in Version | 5.2 | |||||||
| Summary | 0016112: Unhelpfull warning message: "No prominent values for consumer." | ||||||||
| Description | To get this error message: 1) Open disk_out_ref.ex2. Apply. 2) Coloring should be by vtkBlockColors field data 3) Add slice filter. Apply. Note that coloring is still by vtkBlockColors. 4) Change cylinder center to 8,0,0. Apply. The warning message should pop-up. I haven’t been able to reproduce this with field or cell data. The warning is produced in function: vtkSMTransferFunctionProxy::ComputeAvailableAnnotations. | ||||||||
| Project | Sandia | ||||||||
| Topic Name | |||||||||
| Attached Files | |||||||||
| Relationships | ||||||
| Relationships |
| Notes | |
(0035939) Alan Scott (manager) 2016-05-09 14:29 |
May be OK to show these types of warnings in debug mode, but NOT OK to show in release mode! Only reason it would ever be OK is if algorithms fall apart, and then the algorithm should be fixed. |
(0036083) Cory Quammen (developer) 2016-06-19 07:23 |
I could not reproduce this in master. |
(0036084) Cory Quammen (developer) 2016-06-19 07:26 |
Oops, scratch that. The warning message appears as described in the initial report. |
(0036096) Utkarsh Ayachit (administrator) 2016-06-21 22:22 edited on: 2016-06-21 22:24 |
Cory, can you take a look at this? I think that warning should just be removed. It happens because the code is trying to reset range, but the dataset ended up having empty output. It's not a error/issue to enounter such a case. The code should handle it by not resetting any color range, which is what it currently does anyways. See this: https://gitlab.kitware.com/paraview/paraview/blob/master/ParaViewCore/ServerManager/Rendering/vtkSMTransferFunctionProxy.cxx#L420 [^] |
(0036112) Cory Quammen (developer) 2016-06-27 13:21 |
Fix merged in master. |
(0036576) Alan Scott (manager) 2016-07-25 21:00 |
I tested it tonight, it looks good. OK to close. |
| Notes |
| Issue History | |||
| 2016-05-06 16:50 | Sujin Philip | New Issue | |
| 2016-05-06 16:50 | Sujin Philip | Assigned To | => Utkarsh Ayachit |
| 2016-05-06 16:52 | Sujin Philip | Relationship added | related to 0015984 |
| 2016-05-09 14:29 | Alan Scott | Note Added: 0035939 | |
| 2016-06-19 07:23 | Cory Quammen | Note Added: 0036083 | |
| 2016-06-19 07:23 | Cory Quammen | Status | backlog => gatekeeper review |
| 2016-06-19 07:23 | Cory Quammen | Resolution | open => fixed |
| 2016-06-19 07:26 | Cory Quammen | Note Added: 0036084 | |
| 2016-06-19 07:26 | Cory Quammen | Status | gatekeeper review => backlog |
| 2016-06-19 07:26 | Cory Quammen | Resolution | fixed => reopened |
| 2016-06-21 22:22 | Utkarsh Ayachit | Note Added: 0036096 | |
| 2016-06-21 22:22 | Utkarsh Ayachit | Assigned To | Utkarsh Ayachit => Cory Quammen |
| 2016-06-21 22:24 | Utkarsh Ayachit | Note Edited: 0036096 | |
| 2016-06-26 08:50 | Cory Quammen | Status | backlog => active development |
| 2016-06-27 13:21 | Cory Quammen | Note Added: 0036112 | |
| 2016-06-27 13:21 | Cory Quammen | Status | active development => gatekeeper review |
| 2016-06-27 13:21 | Cory Quammen | Resolution | reopened => fixed |
| 2016-06-27 13:24 | Cory Quammen | Fixed in Version | => 5.2 |
| 2016-07-25 21:00 | Alan Scott | Note Added: 0036576 | |
| 2016-07-25 21:44 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
| 2016-07-25 21:44 | Utkarsh Ayachit | Status | customer review => closed |
| Issue History |
