| 0015886 | ParaView | (No Category) | public | 2015-12-16 15:53 | 2016-01-05 10:17 | ||||
| Product Version | 5.0 | ||||||||
| Target Version | 5.0 | Fixed in Version | 5.0 | ||||||
| Summary | 0015886: 5.0.0-RC2 crashes on Windows | ||||||||
| Description | The Kitware download of 5.0.0-RC2 fails on Windows. I am pretty sure it is due to my graphics card. Must not crash, should run. I got no output at all, unless I ran the executable in cygwin. Doing so gives the following (which may be misleading - appears to be Mesa?): > $ ./paraview.exe > > ERROR: In > C:\bbd\5105004d\source-paraview\VTK\Rendering\OpenGL2\vtkShaderProgram.cxx, line 369 > > > ERROR: In > C:\bbd\5105004d\source-paraview\VTK\Rendering\OpenGL2\vtkShaderProgram.cxx, line 370 > > vtkShaderProgram (000000000EFC1E90): 0(50) : error C7531: global > variable gl_PrimitiveID requires "#extension GL_EXT_gpu_shader4 : > enable" before use > > ERROR: In > C:\bbd\5105004d\source-paraview\VTK\Rendering\OpenGL2\vtkOpenGLPolyDat > aMapper2D.cxx, > line 329 > > vtkOpenGLPolyDataMapper2D (000000000EFC33D0): Error setting 'vertexWC' > in shader program. > > > Segmentation fault > > $ glxinfo > > > OpenGL vendor string: VMware, Inc. > > OpenGL renderer string: Gallium 0.4 on llvmpipe (LLVM 3.5, 128 bits) > > OpenGL version string: 3.0 Mesa 11.0.3 > > OpenGL shading language version string: 1.30 > > OpenGL context flags: (none) > | ||||||||
| Project | TBD | ||||||||
| Topic Name | |||||||||
| Attached Files | |||||||||
| Relationships | ||||||
| Relationships |
| Notes | |
(0035628) Alan Scott (manager) 2016-01-04 22:09 |
Tested Windows, master. This is fixed. |
(0035629) Utkarsh Ayachit (administrator) 2016-01-05 10:17 |
Tested and verified by Alan. |
| Notes |
| Issue History | |||
| 2015-12-16 15:53 | Alan Scott | New Issue | |
| 2015-12-16 15:53 | Alan Scott | Target Version | => 5.0 |
| 2015-12-16 16:06 | Alan Scott | Relationship added | related to 0015842 |
| 2016-01-04 22:09 | Alan Scott | Note Added: 0035628 | |
| 2016-01-05 10:17 | Utkarsh Ayachit | Status | backlog => customer review |
| 2016-01-05 10:17 | Utkarsh Ayachit | Fixed in Version | => 5.0 |
| 2016-01-05 10:17 | Utkarsh Ayachit | Resolution | open => fixed |
| 2016-01-05 10:17 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
| 2016-01-05 10:17 | Utkarsh Ayachit | Note Added: 0035629 | |
| 2016-01-05 10:17 | Utkarsh Ayachit | Status | customer review => closed |
| Issue History |
