| 0015528 | ParaView | (No Category) | public | 2015-06-09 14:31 | 2015-09-06 12:17 | ||||
| Product Version | git-master | ||||||||
| Target Version | 4.4 | Fixed in Version | 4.4 | ||||||
| Summary | 0015528: Clear selection interaction mode with "Esc" | ||||||||
| Description | Steps: + Start ParaView + Click "Select Cells On" to ensure selection mode in the Render View + Hit "Esc" key. This should have caused the application to come out of selection mode. It doesn.t | ||||||||
| Project | TBD | ||||||||
| Topic Name | |||||||||
| Attached Files | |||||||||
| Relationships | ||||||
| Relationships |
| Notes | |
(0034596) Utkarsh Ayachit (administrator) 2015-06-22 10:06 |
merge request: https://gitlab.kitware.com/paraview/paraview/merge_requests/177 [^] |
(0034602) Utkarsh Ayachit (administrator) 2015-06-22 12:32 |
merged in master. |
(0034617) Alan Scott (manager) 2015-06-26 12:36 |
This fails testing on Linux, local server, master. |
(0034657) Utkarsh Ayachit (administrator) 2015-07-03 10:18 |
Merge request: https://gitlab.kitware.com/paraview/paraview/merge_requests/191 [^] |
(0034660) Utkarsh Ayachit (administrator) 2015-07-04 10:43 |
merged. |
(0034727) Alan Scott (manager) 2015-07-09 17:27 |
Still fails (sometimes). Utkarsh replicated it. Here is what we did: Linux, master, local server (Utkarsh used OSX) Can, all vars, apply. Rotate the can so you can see the block and cylinder. Place the cursor on the block. Hit "b" (for Block select). (don't click with the mouse). Hit escape. The selection cursor will not clear. |
(0034745) Utkarsh Ayachit (administrator) 2015-07-10 15:17 |
Merge request: https://gitlab.kitware.com/paraview/paraview/merge_requests/210 [^] |
(0034763) Utkarsh Ayachit (administrator) 2015-07-12 12:28 |
Merged another change. This time, it seems more robust. Let's see if you can find a case where it doesn't work again :). |
(0034799) Alan Scott (manager) 2015-07-16 21:35 |
I tried, trust me I tried. Worked every time. Tested Linux, master, local server. |
| Notes |
| Issue History | |||
| 2015-06-09 14:31 | Utkarsh Ayachit | New Issue | |
| 2015-06-09 14:32 | Utkarsh Ayachit | Target Version | => 4.4 |
| 2015-06-22 09:34 | Utkarsh Ayachit | Relationship added | related to 0015547 |
| 2015-06-22 10:06 | Utkarsh Ayachit | Note Added: 0034596 | |
| 2015-06-22 10:06 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
| 2015-06-22 10:06 | Utkarsh Ayachit | Resolution | open => fixed |
| 2015-06-22 10:06 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
| 2015-06-22 12:32 | Utkarsh Ayachit | Note Added: 0034602 | |
| 2015-06-22 12:32 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
| 2015-06-22 12:32 | Utkarsh Ayachit | Fixed in Version | => git-master |
| 2015-06-25 23:24 | Utkarsh Ayachit | Status | customer review => todo |
| 2015-06-25 23:24 | Utkarsh Ayachit | Status | todo => backlog |
| 2015-06-26 12:36 | Alan Scott | Note Added: 0034617 | |
| 2015-07-03 10:18 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
| 2015-07-03 10:18 | Utkarsh Ayachit | Note Added: 0034657 | |
| 2015-07-04 10:43 | Utkarsh Ayachit | Note Added: 0034660 | |
| 2015-07-04 10:43 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
| 2015-07-09 17:27 | Alan Scott | Note Added: 0034727 | |
| 2015-07-09 17:27 | Alan Scott | Status | customer review => todo |
| 2015-07-10 15:17 | Utkarsh Ayachit | Note Added: 0034745 | |
| 2015-07-10 15:17 | Utkarsh Ayachit | Status | todo => gatekeeper review |
| 2015-07-12 12:28 | Utkarsh Ayachit | Note Added: 0034763 | |
| 2015-07-12 20:49 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
| 2015-07-16 21:35 | Alan Scott | Note Added: 0034799 | |
| 2015-07-16 21:35 | Alan Scott | Status | customer review => closed |
| 2015-09-06 12:17 | Utkarsh Ayachit | Fixed in Version | git-master => 4.4 |
| Issue History |
