| 0015377 | ParaView | (No Category) | public | 2015-03-12 10:57 | 2015-09-06 12:17 | ||||
| Product Version | |||||||||
| Target Version | 4.4 | Fixed in Version | 4.4 | ||||||
| Summary | 0015377: Surface selection broken for AMR datasets | ||||||||
| Description | Steps to reproduce: + Create HierarchicalFractal, Apply + Extract Surface, Apply + Select surface cells -- they are often incorrect. The issue seems to be the fact that the CompositeID returned by the selection is incorrect. | ||||||||
| Project | Sandia | ||||||||
| Topic Name | |||||||||
| Attached Files | |||||||||
| Relationships | ||||||
| Relationships |
| Notes | |
(0034591) Utkarsh Ayachit (administrator) 2015-06-22 09:13 |
This was fixed by BUG 0015437. |
(0034615) Alan Scott (manager) 2015-06-25 21:53 |
Note - Following Utkarsh's fix, this appears incorrect parallel server. |
(0034730) Alan Scott (manager) 2015-07-09 20:58 |
See e-mail notes sent to Utkarsh. |
(0034774) Alan Scott (manager) 2015-07-14 12:49 |
There are two issues here - is the AMR selection fixed, and is the Hierarchical Fractal working correctly in parallel. We believe there is a problem with the Hierarchical fractal code in parallel. This isn't this bug. We believe that the AMR selection is fixed (which is this bug). From an e-mail from Utkarsh: So the issue is weird. It so happens that the Hierarchical Fractals produces incorrect image extents on the last rank when running in parallel. Consequently, when ExtractSurface it applied, it produces the lowest res grid to cover all partitions on the last rank (see attached image). When selecting, the last process wins and hence it selects the lower-res cell from the rank #3 (I was running 4 procs here, but same is true for 2 procs). If you don't apply "Extract Surface" but directly switch to "Surface" representation on the Fractal itself and then select it doesn't run into this issue. Closing the bug. |
| Notes |
| Issue History | |||
| 2015-03-12 10:57 | Utkarsh Ayachit | New Issue | |
| 2015-03-12 10:57 | Utkarsh Ayachit | Target Version | => 4.4 |
| 2015-06-22 09:13 | Utkarsh Ayachit | Relationship added | related to 0015437 |
| 2015-06-22 09:13 | Utkarsh Ayachit | Note Added: 0034591 | |
| 2015-06-22 09:13 | Utkarsh Ayachit | Status | backlog => customer review |
| 2015-06-22 09:13 | Utkarsh Ayachit | Fixed in Version | => git-master |
| 2015-06-22 09:13 | Utkarsh Ayachit | Resolution | open => fixed |
| 2015-06-22 09:13 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
| 2015-06-25 21:53 | Alan Scott | Note Added: 0034615 | |
| 2015-07-09 20:58 | Alan Scott | Note Added: 0034730 | |
| 2015-07-09 20:58 | Alan Scott | Status | customer review => todo |
| 2015-07-14 12:49 | Alan Scott | Note Added: 0034774 | |
| 2015-07-14 12:49 | Alan Scott | Status | todo => closed |
| 2015-09-06 12:17 | Utkarsh Ayachit | Fixed in Version | git-master => 4.4 |
| Issue History |
