| 0014762 | ParaView | (No Category) | public | 2014-05-29 12:58 | 2014-08-29 11:00 | ||||
| Reporter | Cory Quammen | ||||||||
| Assigned To | Cory Quammen | ||||||||
| Priority | high | Severity | minor | Reproducibility | have not tried | ||||
| Product Version | git-master | ||||||||
| Target Version | 4.2 | Fixed in Version | 4.2 | ||||||
| Summary | 0014762: Enable saving color legend properties as default | ||||||||
| Description | Color legend settings should be savable between sessions. | ||||||||
| Project | Sandia | ||||||||
| Topic Name | 14762_save_color_legend_settings | ||||||||
| Type | feature | ||||||||
| Attached Files | |||||||||
| Relationships | ||||||
| Relationships |
| Notes | |
(0032755) Cory Quammen (developer) 2014-06-05 23:49 |
Merged into next. commit 4b05cb56d4669fa100e459fa836bd3670165f145 Author: Cory Quammen <cory.quammen@kitware.com> Date: Thu Jun 5 14:01:55 2014 -0400 Add buttons to pqProxyWidgetDialog Added a button to save currently applied settings as property defaults and a button to restore the application defaults. Removed QDialogButtonBox and replaced with simple QPushButtons. Updated tests that involve the pqProxyWidgetDialog. Change-Id: Iedc7684af5741b0854470ace3dcb459e5d523999 |
(0032756) Cory Quammen (developer) 2014-06-06 00:02 |
To test: 1. Add Cylinder source 2. Change variable to color by to TCoords 3. Click Edit Color Map tool button 4. Click "Edit color legend properties" in the Color Map Editor 5. Change the Title Font Size to 9. 6. Uncheck the "Draw Tick Marks" checkbox. 7. Click Apply. Observe the changes to the color map. 8. Click the disk icon with the down arrow. This saves the settings as the new defaults. 9. Click OK to close the "Edit Color Legend Parameters" dialog 10. Create a Plane source 11. Change variable to color by TextureCoordinates 12. Click "Edit color legend properties" in the Color Map Editor 13. Note that the color legend has the new default properties set in step 8. 14. Now click on the leftmost button in the Color Map Editor with the refresh icon 15. Note that the settings return to the application defaults. The color legend does not change at this point. Click Apply. The color legend will now change back to the original defaults. |
(0032762) Utkarsh Ayachit (administrator) 2014-06-06 05:08 |
SUMMARY --------------------------------------------- Topics merged into master: 14573-deprecate-legacy-panels 14772_CTH_Tracers_on_by_default AddSideBySideHorizStereoModeToSaveDialogs FixGeometryFilterProxy FixPluginPathSeparatorIssue data-download-without-testing discretize_color manual-ParaViewData-option (VTK) refactor-piece-and-extent (VTK) refactor-piece-and-extent-2 static-plugins |
(0032798) Cory Quammen (developer) 2014-06-09 08:55 |
Re-issued for gatekeeper review because of a workflow no no on my part. commit 6b645ec33fe0485e3408ec55d1977d73cd2d679e Author: Cory Quammen <cory.quammen@kitware.com> Date: Thu Jun 5 14:01:55 2014 -0400 Add buttons to pqProxyWidgetDialog Added a button to save currently applied settings as property defaults and a button to restore the application defaults. Removed QDialogButtonBox and replaced with simple QPushButtons. Updated tests that involve the pqProxyWidgetDialog. Change-Id: Iedc7684af5741b0854470ace3dcb459e5d523999 |
(0032815) Utkarsh Ayachit (administrator) 2014-06-10 07:38 |
SUMMARY --------------------------------------------- Topics merged into master: 14762_save_color_legend_settings 14787_fix_matplotlib_xml cleaning_point_sprite fix-transferfunction-applycolormap-text static-plugin-loading (VTK) use-broadcast-rmi-trigger use-gatherv-in-collect-information |
(0032828) Alan Scott (manager) 2014-06-10 21:22 |
Tested master, remote server, Linux. |
| Notes |
| Issue History | |||
| 2014-05-29 12:58 | Cory Quammen | New Issue | |
| 2014-05-29 12:58 | Cory Quammen | Assigned To | => Cory Quammen |
| 2014-05-29 12:58 | Cory Quammen | Relationship added | child of 0014679 |
| 2014-05-29 12:59 | Cory Quammen | Status | backlog => active development |
| 2014-06-05 23:49 | Cory Quammen | Note Added: 0032755 | |
| 2014-06-06 00:02 | Cory Quammen | Topic Name | => 14762_save_color_legend_settings |
| 2014-06-06 00:02 | Cory Quammen | Note Added: 0032756 | |
| 2014-06-06 00:02 | Cory Quammen | Status | active development => gatekeeper review |
| 2014-06-06 00:02 | Cory Quammen | Fixed in Version | => git-next |
| 2014-06-06 00:02 | Cory Quammen | Resolution | open => fixed |
| 2014-06-06 05:07 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
| 2014-06-06 05:08 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
| 2014-06-06 05:08 | Utkarsh Ayachit | Note Added: 0032762 | |
| 2014-06-06 14:02 | Utkarsh Ayachit | Status | customer review => gatekeeper review |
| 2014-06-09 08:53 | Cory Quammen | Status | gatekeeper review => active development |
| 2014-06-09 08:54 | Cory Quammen | Status | active development => gatekeeper review |
| 2014-06-09 08:54 | Cory Quammen | Fixed in Version | git-master => git-next |
| 2014-06-09 08:55 | Cory Quammen | Note Added: 0032798 | |
| 2014-06-10 07:37 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
| 2014-06-10 07:38 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
| 2014-06-10 07:38 | Utkarsh Ayachit | Note Added: 0032815 | |
| 2014-06-10 21:22 | Alan Scott | Note Added: 0032828 | |
| 2014-06-10 21:22 | Alan Scott | Status | customer review => closed |
| 2014-06-17 09:21 | Utkarsh Ayachit | Target Version | => 4.2 |
| 2014-08-29 11:00 | Utkarsh Ayachit | Fixed in Version | git-master => 4.2 |
| Issue History |
