0014725 | VTK | (No Category) | public | 2014-05-12 19:04 | 2014-05-14 18:05 | ||||
Reporter | Andras Lasso 2 | ||||||||
Assigned To | David Gobbi | ||||||||
Target Version | Fixed in Version | 6.2.0 | |||||||
Summary | 0014725: Incorrect null-pointer check in vtkBSplineTransform causes incorrect ForwardTransformPoint result | ||||||||
Description | There is a typo in vtkBSplineTransform::ForwardTransformPoint(const double inPoint[3], double outPoint[3]) that prevents proper computation of the transformed point position. The first line of the method should be if (!this->GridPointer || !this->CalculateSpline) instead it is if (this->GridPointer || !this->CalculateSpline) See: https://github.com/Kitware/VTK/blob/master/Filters/Hybrid/vtkBSplineTransform.cxx#L461 [^] | ||||||||
Project | TBD | ||||||||
(0032625) David Gobbi (developer) 2014-05-13 08:25 |
Thanks for the report, I've pushed a fix to gerrit (http://review.source.kitware.com/15429 [^]) but still need to improve the test coverage. The fix will go into VTK 6.2. |
(0032626) Andras Lasso 2 (reporter) 2014-05-13 09:36 |
Great, thanks! |
(0032631) David Gobbi (developer) 2014-05-14 18:05 |
Merged along with more tests, commit ddf898ae |
2014-05-12 19:04 | Andras Lasso 2 | New Issue | |
2014-05-13 08:25 | David Gobbi | Note Added: 0032625 | |
2014-05-13 08:25 | David Gobbi | Assigned To | => David Gobbi |
2014-05-13 08:25 | David Gobbi | Status | backlog => gerrit review |
2014-05-13 09:36 | Andras Lasso 2 | Note Added: 0032626 | |
2014-05-14 18:05 | David Gobbi | Note Added: 0032631 | |
2014-05-14 18:05 | David Gobbi | Status | gerrit review => closed |
2014-05-14 18:05 | David Gobbi | Resolution | open => fixed |
2014-05-14 18:05 | David Gobbi | Fixed in Version | => 6.2.0 |
