| 0014687 | ParaView | (No Category) | public | 2014-04-11 20:38 | 2014-08-29 11:00 | ||||
| Assigned To | Cory Quammen | ||||||||
| Product Version | git-master | ||||||||
| Target Version | 4.2 | Fixed in Version | 4.2 | ||||||
| Summary | 0014687: color legend - zero is mis-sized | ||||||||
| Description | When the color legend goes from a negative number to a positive number, it crosses zero. If the tick labels on the right side shrink (due to size constraints for the numbers), the 0 does not also shrink - but seems to follow the font size of the min, max and title. This needs to be fixed. | ||||||||
| Project | Sandia | ||||||||
| Topic Name | 14679_color_legend_bugs | ||||||||
| Attached Files | ![]() | ||||||||
| Relationships | ||||||
| Relationships |
| Notes | |
(0032682) Cory Quammen (developer) 2014-05-29 12:42 |
- Create sphere source - Add calculator to sphere source. Set Result Array Name to X and the expression to coordsX - Click the Edit Color Map button - Note the 0 label on the color scale matches the font size for the rest of the labels - Stretch the color scale by grabbing on it's left "handle" and pulling it to the left. Note that the 0 stays the same size as the other labels. - Click the "Edit color legend properties" and change the "Text/Annotation Font Properties" so that the size is 10. Again, the 0 label matches the other labels in size. |
(0032691) Utkarsh Ayachit (administrator) 2014-05-30 08:14 |
SUMMARY --------------------------------------------- Topics merged into master: 14679_color_legend_bugs 14734-GoodDefaultSizeForpqProxyWidgetDialog cleanup-cmake fix_assembly_render_view fix_fragment_large_scale fix_plugin_loading_order fix_qt_modules remove-unused-directory --------------------------------------------- Topics reverted from next: 14673_fix_follow_data |
(0032701) Alan Scott (manager) 2014-05-30 22:05 |
Tested local server, master, Linux. |
| Notes |
| Issue History | |||
| 2014-04-11 20:38 | Alan Scott | New Issue | |
| 2014-04-11 20:38 | Alan Scott | Relationship added | child of 0014679 |
| 2014-04-11 20:39 | Alan Scott | File Added: colorLegendScreenshot.png | |
| 2014-04-12 22:07 | Utkarsh Ayachit | Target Version | => 4.2 |
| 2014-05-12 11:29 | Utkarsh Ayachit | Assigned To | => Cory Quammen |
| 2014-05-12 22:53 | Cory Quammen | Status | backlog => active development |
| 2014-05-29 12:42 | Cory Quammen | Topic Name | => 14679_color_legend_bugs |
| 2014-05-29 12:42 | Cory Quammen | Note Added: 0032682 | |
| 2014-05-29 12:42 | Cory Quammen | Status | active development => gatekeeper review |
| 2014-05-29 12:42 | Cory Quammen | Fixed in Version | => git-next |
| 2014-05-29 12:42 | Cory Quammen | Resolution | open => fixed |
| 2014-05-30 08:13 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
| 2014-05-30 08:14 | Utkarsh Ayachit | Note Added: 0032691 | |
| 2014-05-30 08:14 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
| 2014-05-30 22:05 | Alan Scott | Note Added: 0032701 | |
| 2014-05-30 22:05 | Alan Scott | Status | customer review => closed |
| 2014-08-29 11:00 | Utkarsh Ayachit | Fixed in Version | git-master => 4.2 |
| Issue History |
