| 0014587 | ParaView | (No Category) | public | 2014-02-20 10:25 | 2016-08-24 08:25 | ||||
| Reporter | michiharu | ||||||||
| Assigned To | Ben Boeckel (Kitware) | ||||||||
| Priority | high | Severity | minor | Reproducibility | have not tried | ||||
| Product Version | 4.1 | ||||||||
| Target Version | 4.2 | Fixed in Version | 4.2 | ||||||
| Summary | 0014587: pvserver crash with PointSprite_Plugin | ||||||||
| Description | When using paraview locally, PointSprite_Plugin works fine. Using pvserver and connecting remotely, it loads cases without any issue but when I change the representation to Point Sprite it crash | ||||||||
| Project | Sandia | ||||||||
| Topic Name | point-sprite-plugin-crash | ||||||||
| Type | crash | ||||||||
| Attached Files | |||||||||
| Relationships | ||||||
| Relationships |
| Notes | |
(0032355) Alan Scott (manager) 2014-02-20 12:28 |
Thanks for reporting. My group found this yesterday - you beat me to writing a bug report! I am marking as project Sandia, since this will get the bug fixed sooner. |
(0032443) Utkarsh Ayachit (administrator) 2014-03-03 13:25 |
Developer notes: vtkPointSpriteRepresentation is a subclass of vtkGeometryRepresentation that changes the this->GeometryFilter class used. vtkGeometryRepresentation is assuming that this->GeometryFilter is always a vtkPVGeometryFilter (e.g at vtkGeometryRepresentation.cxx:407). That's causing the problem. You can fix line 407, by simply using vtkAlgorithm::SetInputData() API. You don't need to downcast is to anything. Also fix vtkGeometryRepresentation::SetupDefaults to do the PVGoemetryFilter defaults only if it is indeed of the right type. |
(0032450) Ben Boeckel (Kitware) (developer) 2014-03-03 17:27 |
Pushed onto stage as 'point-sprite-plugin-crash' and merged into next. |
(0032466) Utkarsh Ayachit (administrator) 2014-03-09 13:24 |
SUMMARY --------------------------------------------- Topics merged into master: 13794_fix_mp4py 14572-search-series-parameter-widget 14620_FixRulerCrash disabled-multiblock-pieces fix_example_qt5 optimize_amrconnectivity point-sprite-plugin-crash pvweb-visualizer remove-extra-resources (VTK) update-vtk-20140303 ------------------------------------------- |
(0032514) Alan Scott (manager) 2014-03-20 21:42 |
I don't think this is correct yet. I just did the following: Clean, fresh, nothing set .plugins both sides. Linux, remote server, 8 parallel pvservers, master. Load can.exo. Tools/ Manage Plugins. Add PointSprite remote. Add PointSprite local. Close. Now, try to change Representation Surface to PointSprite. It won't be in the pull down! |
(0032518) Utkarsh Ayachit (administrator) 2014-03-20 22:06 |
Alan, you need to load the plugin before opening the dataset. Alternatively, delete the view and create a new 3D view and then show the output from can.ex2 in it. |
(0032526) Alan Scott (manager) 2014-03-21 15:12 |
Tested remote server, Linux, master. |
| Notes |
| Issue History | |||
| 2014-02-20 10:25 | michiharu | New Issue | |
| 2014-02-20 12:28 | Alan Scott | Project | TBD => Sandia |
| 2014-02-20 12:28 | Alan Scott | Note Added: 0032355 | |
| 2014-02-20 12:28 | Alan Scott | Priority | normal => high |
| 2014-02-20 12:28 | Alan Scott | Assigned To | => Alan Scott |
| 2014-02-20 12:28 | Alan Scott | Assigned To | Alan Scott => |
| 2014-02-20 12:28 | Alan Scott | Status | backlog => todo |
| 2014-02-24 10:53 | Utkarsh Ayachit | Relationship added | related to 0014542 |
| 2014-03-03 13:22 | Utkarsh Ayachit | Assigned To | => Ben Boeckel (Kitware) |
| 2014-03-03 13:25 | Utkarsh Ayachit | Note Added: 0032443 | |
| 2014-03-03 17:27 | Ben Boeckel (Kitware) | Note Added: 0032450 | |
| 2014-03-03 17:27 | Ben Boeckel (Kitware) | Status | todo => gatekeeper review |
| 2014-03-09 13:22 | Utkarsh Ayachit | Topic Name | => point-sprite-plugin-crash |
| 2014-03-09 13:24 | Utkarsh Ayachit | Fixed in Version | => git-master |
| 2014-03-09 13:24 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
| 2014-03-09 13:24 | Utkarsh Ayachit | Note Added: 0032466 | |
| 2014-03-20 21:42 | Alan Scott | Note Added: 0032514 | |
| 2014-03-20 21:42 | Alan Scott | Status | customer review => todo |
| 2014-03-20 22:06 | Utkarsh Ayachit | Note Added: 0032518 | |
| 2014-03-20 22:06 | Utkarsh Ayachit | Status | todo => gatekeeper review |
| 2014-03-20 22:06 | Utkarsh Ayachit | Resolution | open => fixed |
| 2014-03-20 23:59 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
| 2014-03-21 15:12 | Alan Scott | Note Added: 0032526 | |
| 2014-03-21 15:12 | Alan Scott | Status | customer review => closed |
| 2014-06-17 09:22 | Utkarsh Ayachit | Target Version | => 4.2 |
| 2014-08-29 11:00 | Utkarsh Ayachit | Fixed in Version | git-master => 4.2 |
| 2016-08-24 08:25 | Kitware Robot | View Status | private => public |
| Issue History |
