| 0014483 | ParaView | (No Category) | public | 2013-12-20 11:42 | 2015-01-11 08:21 | ||||
| Product Version | |||||||||
| Target Version | 4.1 | Fixed in Version | 4.1 | ||||||
| Summary | 0014483: FindData failes on certain queries | ||||||||
| Description | Try this: + open can.ex2, load all variables, hit apply + In Find Data dialog, select Cells, GlobalElementId, "is one of", 1,2,3 . It fails with errors: Traceback (most recent call last): File "<string>", line 4, in <module> File "/home/utkarsh/Kitware/ParaView3/ParaViewBin/lib/site-packages/paraview/extract_selection.py", line 145, in Exec ds = ExecData(self, iterCD.GetCurrentDataObject(), selection) File "/home/utkarsh/Kitware/ParaView3/ParaViewBin/lib/site-packages/paraview/extract_selection.py", line 120, in ExecData mask = eval(selection_node.GetQueryString(), globals(), new_locals) File "<string>", line 1, in <module> File "/usr/lib/python2.7/dist-packages/numpy/lib/arraysetops.py", line 328, in in1d ar1, rev_idx = np.unique(ar1, return_inverse=True) File "/usr/lib/python2.7/dist-packages/numpy/lib/arraysetops.py", line 182, in unique flag = np.concatenate(([True], aux[1:] != aux[:-1])) ValueError: arrays must have same number of dimensions | ||||||||
| Project | TBD | ||||||||
| Topic Name | 14483_fix_find_data | ||||||||
| Attached Files | |||||||||
| Relationships | ||||||
| Relationships |
| Notes | |
(0032043) Utkarsh Ayachit (administrator) 2013-12-20 15:19 |
commit bc8a07cf9d15a6a6d8fa02f7009c8cdc81401a47 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Fri Dec 20 15:18:04 2013 -0500 BUG 0014483. Fix issues with FindData. FindData failed to on "is one of" queries when a data array was used instead of the IDS. This hack overcomes the problem for now by adopting a potentially slower route. Change-Id: Ifd07cf2d75a87dff4b7fb42cd79aea11dc9d40d1 |
(0032045) Utkarsh Ayachit (administrator) 2013-12-22 11:12 |
Topics merged into master: 0014214_fix_python_trace_issues 14483_fix_find_data fix-warnings pvweb-doc-grammar-fix pvweb-ipython-integration (VTK) vtk-master |
(0032052) Alan Scott (manager) 2013-12-24 16:23 |
Doesn't seem to work parallel server. I asked Utkarsh for feedback. |
(0032108) Utkarsh Ayachit (administrator) 2014-01-02 11:18 |
Alan, I just verified with 8 pvservers. It does indeed work for me. Remember this needs numpy on the server side to work. Can you try with just 1 pvserver to see if it works at all for you? |
(0032291) Alan Scott (manager) 2014-02-05 16:56 |
Happens with only one pvservers. I "think" I have numpy working properly server side. Is there a way to check? |
(0032419) Alan Scott (manager) 2014-02-26 22:26 |
Works on a nightly download from Kitware on my Mac. I will try Linux next. |
(0032452) Alan Scott (manager) 2014-03-03 17:46 |
Found. I didn't have numpy properly installed into the Python directories on the server side. I did so, and now it works. I talked to Kitware about getting some indication of numpy is on the server side, maybe putting in Help. Wrote up bug 14614. Tested Linux, remote server, master. |
| Notes |
| Issue History | |||
| 2013-12-20 11:42 | Utkarsh Ayachit | New Issue | |
| 2013-12-20 11:42 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
| 2013-12-20 11:42 | Utkarsh Ayachit | Target Version | => 4.1 |
| 2013-12-20 15:19 | Utkarsh Ayachit | Topic Name | => 14483_fix_find_data |
| 2013-12-20 15:19 | Utkarsh Ayachit | Note Added: 0032043 | |
| 2013-12-20 15:19 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
| 2013-12-20 15:19 | Utkarsh Ayachit | Fixed in Version | => git-next |
| 2013-12-20 15:19 | Utkarsh Ayachit | Resolution | open => fixed |
| 2013-12-22 11:12 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
| 2013-12-22 11:12 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
| 2013-12-22 11:12 | Utkarsh Ayachit | Note Added: 0032045 | |
| 2013-12-24 16:23 | Alan Scott | Note Added: 0032052 | |
| 2014-01-02 11:18 | Utkarsh Ayachit | Note Added: 0032108 | |
| 2014-01-11 08:39 | Utkarsh Ayachit | Fixed in Version | git-master => 4.1 |
| 2014-01-16 13:44 | Utkarsh Ayachit | Relationship added | has duplicate 0013040 |
| 2014-02-05 16:56 | Alan Scott | Note Added: 0032291 | |
| 2014-02-26 22:26 | Alan Scott | Note Added: 0032419 | |
| 2014-03-03 17:46 | Alan Scott | Note Added: 0032452 | |
| 2014-03-03 17:46 | Alan Scott | Status | customer review => closed |
| 2015-01-11 08:21 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master ad060cd9 |
| 2015-01-11 08:21 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master bc8a07cf |
| Issue History |
