| 0014237 | VTK | (No Category) | public | 2013-08-19 12:18 | 2016-08-12 09:55 | ||||
| Reporter | David Thompson | ||||||||
| Assigned To | T.J. Corona | ||||||||
| Status | closed | Resolution | moved | ||||||
| Product Version | 6.0.0 | ||||||||
| Summary | 0014237: Concave polyhedron not likely to be clipped correctly. | ||||||||
| Description | Because the InternalContour method of vtkPolyhedron does not perform any refinement, it is possible to construct a concave polyhedron that, when clipped or contoured, will have self-intersecting faces. The mean-value-coordinates interpolant does not guarantee convexity except on convex planar polygonal facets. The attached example (which also appears to be incorrectly triangulated) produces self-intersecting faces when isovolumed with range [1.5,6.0]. | ||||||||
| Project | TBD | ||||||||
| Attached Files | |||||||||
| Relationships | ||||||
| Relationships |
| Notes | |
(0036061) Menno Deij (reporter) 2016-06-13 11:00 |
Tetrahedralize filter also gives wrong results on this polyhedral cell (inside of U-shape also gets cells). |
(0037307) Kitware Robot (administrator) 2016-08-12 09:55 |
Resolving issue as `moved`. This issue tracker is no longer used. Further discussion of this issue may take place in the current VTK Issues page linked in the banner at the top of this page. |
| Notes |
| Issue History | |||
| 2013-08-19 12:18 | David Thompson | New Issue | |
| 2013-08-19 12:18 | David Thompson | File Added: polyhedron.vtu | |
| 2015-09-08 15:41 | T.J. Corona | Assigned To | => T.J. Corona |
| 2015-11-30 09:36 | T.J. Corona | Relationship added | related to 0015841 |
| 2015-11-30 09:37 | T.J. Corona | Assigned To | T.J. Corona => |
| 2015-11-30 15:31 | T.J. Corona | Assigned To | => T.J. Corona |
| 2015-11-30 15:31 | T.J. Corona | Status | backlog => active development |
| 2016-06-13 11:00 | Menno Deij | Note Added: 0036061 | |
| 2016-08-12 09:55 | Kitware Robot | Note Added: 0037307 | |
| 2016-08-12 09:55 | Kitware Robot | Status | active development => closed |
| 2016-08-12 09:55 | Kitware Robot | Resolution | open => moved |
| Issue History |
