| 0001411 | VTK | (No Category) | public | 2004-12-08 22:50 | 2016-08-12 09:54 | ||||
| Reporter | Andrew Maclean | ||||||||
| Assigned To | Dave DeMarle | ||||||||
| Priority | high | Severity | major | Reproducibility | always | ||||
| Status | closed | Resolution | moved | ||||||
| Product Version | |||||||||
| Summary | 0001411: vtkImageViewer2 - Render() problem. | ||||||||
| Description | Taken from one of Will's exercises (reorganized exercises, exercise3b_answer.cxx): Any code like this executes once only if the viewer is of type vtkImageViewer2: for (i = 1; i < 93; ++i) { viewer->SetZSlice(i); // compute the string sprintf(tstr,"Slice: %i",i); tactor->SetInput(tstr); // we must reset the clipping range for each slice or set it ahead of // time because they are positioned in world coordinates viewer->GetRenderer()->ResetCameraClippingRange(); viewer->Render(); } What happens is that after the first render the next call to Render() hangs. If the viewer is of type vtkImageViewer the code works OK. The problem is in both Windows XP and Linux. Using .NET under XP or gcc3.3 under Linux. | ||||||||
| Project | |||||||||
| Type | |||||||||
| Attached Files | |||||||||
| Relationships | |
| Relationships |
| Notes | |
(0001789) Mathieu Malaterre (developer) 2004-12-09 18:42 |
I cannot reproduce the problem on Linux, gcc3.3. What version of VTK are you using ? BTW the CVS version of VTK doesn't need anymore the line: viewer->GetRenderer()->ResetCameraClippingRange(); Because by default the vtkImageViewer2 is: AutoResetCameraClippingRangeOn HTH |
(0001836) Mathieu Malaterre (developer) 2004-12-22 22:37 |
Closing the bug as author did not respond. |
(0001845) Andrew Maclean (reporter) 2004-12-23 18:18 |
please don't close this. This fails under VTK 4.5, VC 7.1 and gcc-3.3.4. While Will was over here in Sydney, he was also able to see the problem. I responded by e-mail a few weeks ago to your enquiries. |
(0001847) Andrew Maclean (reporter) 2004-12-23 18:26 |
Fails in the development version of VTK, namely VTK4.5. Will Schroeder, while he was out here also saw this behaviour. Compilers used: Windows XP/VC7.1, Lunix - Debian gcc-3.3.4 Thanks Andrew |
(0030943) Jean-Christophe Fillion-Robin (manager) 2013-06-05 17:13 |
Does the problem still occur with VTK 5.10 ? VTK 6 ? |
(0031213) Dave DeMarle (administrator) 2013-07-22 19:10 |
If the bug persists in 6.0.0, please reopen. |
(0036756) Kitware Robot (administrator) 2016-08-12 09:54 |
Resolving issue as `moved`. This issue tracker is no longer used. Further discussion of this issue may take place in the current VTK Issues page linked in the banner at the top of this page. |
| Notes |
| Issue History | |||
| 2008-11-30 09:20 | Mathieu Malaterre | Status | @30@ => tabled |
| 2008-11-30 09:20 | Mathieu Malaterre | Assigned To | Mathieu Malaterre => David Cole |
| 2011-01-19 10:09 | David Cole | Assigned To | David Cole => |
| 2011-06-16 13:11 | Zack Galbreath | Category | => (No Category) |
| 2013-06-05 17:13 | Jean-Christophe Fillion-Robin | Note Added: 0030943 | |
| 2013-07-22 19:10 | Dave DeMarle | Note Added: 0031213 | |
| 2013-07-22 19:10 | Dave DeMarle | Status | backlog => expired |
| 2013-07-22 19:10 | Dave DeMarle | Assigned To | => Dave DeMarle |
| 2015-01-11 08:24 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 1f7cf89a |
| 2016-08-12 09:54 | Kitware Robot | Note Added: 0036756 | |
| 2016-08-12 09:54 | Kitware Robot | Status | expired => closed |
| 2016-08-12 09:54 | Kitware Robot | Resolution | open => moved |
| Issue History |
