| 0013863 | ParaView | (No Category) | public | 2013-02-06 16:26 | 2015-01-11 08:28 | ||||
| Product Version | |||||||||
| Target Version | Fixed in Version | 3.98.1 | |||||||
| Summary | 0013863: Visibility animation not working correctly | ||||||||
| Description | * Create Sphere, Apply * Create an animation track to control the visibility of the sphere. Set the visibility to go from 0 to 1. * Play. On the last frame, you'll see the sphere rendered as glyphs+outline+surface. That's wrong. We only expected to see the surface. | ||||||||
| Project | Kitware | ||||||||
| Topic Name | 13863_fix_visibility_animation | ||||||||
| Attached Files | |||||||||
| Relationships | |
| Relationships |
| Notes | |
(0030312) Utkarsh Ayachit (administrator) 2013-02-06 16:37 |
commit 2752d7e7f7a1613197b54fe2c2da81f88d611799 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Wed Feb 6 16:35:04 2013 -0500 BUG 0013863: Fix visibility animation. When animating visibility, we were turning on visibility of *all* representations, including those that were added as subproxies to some other representations. Hence all the representations ended up being visible are indicated in the BUG 0013863. This fix address that issue by skipping toggling of visibility for sub-proxies. Change-Id: Ic210b43e95669ac4d12787f2f62b461b5f2a6356 |
(0030319) Utkarsh Ayachit (administrator) 2013-02-07 10:30 |
SUMMARY --------------------------------------------- Topics merged into master: 13862-VruiTypo 13863_fix_visibility_animation |
| Notes |
| Issue History | |||
| 2013-02-06 16:26 | Utkarsh Ayachit | New Issue | |
| 2013-02-06 16:37 | Utkarsh Ayachit | Topic Name | => 13863_fix_visibility_animation |
| 2013-02-06 16:37 | Utkarsh Ayachit | Note Added: 0030312 | |
| 2013-02-06 16:37 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
| 2013-02-06 16:37 | Utkarsh Ayachit | Fixed in Version | => git-next |
| 2013-02-06 16:37 | Utkarsh Ayachit | Resolution | open => fixed |
| 2013-02-06 16:37 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
| 2013-02-07 10:29 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
| 2013-02-07 10:30 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
| 2013-02-07 10:30 | Utkarsh Ayachit | Note Added: 0030319 | |
| 2013-02-07 10:30 | Utkarsh Ayachit | Fixed in Version | git-master => 3.98.1 |
| 2013-02-11 16:02 | Utkarsh Ayachit | Status | customer review => closed |
| 2015-01-11 08:27 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 770de9ed |
| 2015-01-11 08:27 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 36396961 |
| 2015-01-11 08:28 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 2752d7e7 |
| Issue History |
