| 0013576 | ParaView | (No Category) | public | 2012-10-26 14:32 | 2012-10-31 20:09 | ||||
| Reporter | Patrick O'Leary | ||||||||
| Assigned To | Sebastien Jourdain | ||||||||
| Product Version | 3.14.1 | ||||||||
| Target Version | Fixed in Version | 3.98.0 | |||||||
| Summary | 0013576: labels don't show up or are clipped in plots. | ||||||||
| Description | I would like to put axes with labels on the figures that I am generating. I've tried clicking show cube axes under the display menu for an extract subset. I can get the tick marks and axis lines to show up. But, I cannot get the labels to show up unless I rotate the screen (see attached images). I have tried using the axes source, but I run into the same problem. It seams like there is a bounding box or something that cuts the annotation off when for example looking directly down from the top. For runs of HIGRAD/FIRETEC at LANL reported by Jesse M Canfield, jessec@lanl.gov | ||||||||
| Project | TBD | ||||||||
| Topic Name | 13469_fix_cube_axes_parallel_rendering | ||||||||
| Attached Files | ![]() | ||||||||
| Relationships | ||||||
| Relationships |
| Notes | |
(0029600) Sebastien Jourdain (manager) 2012-10-30 13:30 |
This issue is related to the bounds reported by CubeAxes which make IceT to crop labels... commit 907a59e775a94c951c38785821167009ab440cfc Author: Sebastien Jourdain <sebastien.jourdain@kitware.com> Date: Tue Oct 30 08:55:54 2012 -0400 Make sure axis label are shown when looking at a 2D plane in 3D Change-Id: Ie5e06e4f190ff5a354d863d1defd2b821059d04d [...] diff --git a/Rendering/Annotation/vtkCubeAxesActor.cxx b/Rendering/Annotation/vtkCubeAxesActor.cxx index 770d15c..8554c22 100644 --- a/Rendering/Annotation/vtkCubeAxesActor.cxx +++ b/Rendering/Annotation/vtkCubeAxesActor.cxx @@ -17,6 +17,7 @@ [...] +// -------------------------------------------------------------------------- +void vtkCubeAxesActor::GetRenderedBounds(double *b) +{ + vtkBoundingBox bbox(this->GetBounds()); // Data bounds + + // Make a heuristic on the final bounds that embed test labels + // Just inflate the box based on its max length + bbox.Inflate(bbox.GetMaxLength()); + + bbox.GetBounds(b); +} +++++++++++++++++++ diff --git a/ParaViewCore/VTKExtensions/Rendering/vtkIceTCompositePass.cxx b/ParaViewCore/VTKExtensions/Rendering/vtkIceTCompositePass.cxx index ed5a409..76016ae 100644 --- a/ParaViewCore/VTKExtensions/Rendering/vtkIceTCompositePass.cxx +++ b/ParaViewCore/VTKExtensions/Rendering/vtkIceTCompositePass.cxx @@ -59,11 +59,8 @@ namespace void MergeCubeAxesBounds(double bounds[6], const vtkRenderState* rState) { vtkBoundingBox bbox(bounds); - // scale the bounds a bit so that when showing a box we don't end up with - // clipped edges e.g. when a Mandelbrot source was shown with parallel - // rendering, the front edges would appear clipped in outline mode. - bbox.Scale(1.1, 1.1, 1.1); + // Hande CubeAxes specifically has it wrongly implement the GetBounds() for (int cc=0; cc < rState->GetPropArrayCount(); cc++) { vtkProp* prop = rState->GetPropArray()[cc]; @@ -71,13 +68,11 @@ namespace if (cubeAxes != NULL && prop->GetVisibility() && prop->GetUseBounds()) { - // cubeAxes has not clean API to give us the bounds it's using. So, we - // use a heuristic instead. Simply scale the data bounds by 1.5 and we - // call it 'even'. - bbox.Scale(1.5, 1.5, 1.5); - break; + // Use custom bounds API for cube axes to embed titles and labels + bbox.AddBounds(cubeAxes->GetRenderedBounds()); } } + bbox.GetBounds(bounds); } }; |
(0029617) Utkarsh Ayachit (administrator) 2012-10-31 10:47 |
merged into master, if applicable. |
(0029636) Alan Scott (manager) 2012-10-31 20:09 |
This has been fixed. Note that when the plane is very close to edge on that the text still disappears, but that probably makes sense. If this bug still exists, please try to replicate it with sources/ mandlebrot, add a note to this bug how to replicate it, and re-open this bug. See the related bug 13469. Tested remote server, master, Linux. |
| Notes |
| Issue History | |||
| 2012-10-26 14:32 | Patrick O'Leary | New Issue | |
| 2012-10-26 14:32 | Patrick O'Leary | File Added: Screen Shot 2012-10-26 at 8.52.27 AM.png | |
| 2012-10-26 14:32 | Patrick O'Leary | File Added: Screen Shot 2012-10-26 at 8.50.42 AM.png | |
| 2012-10-26 14:33 | Patrick O'Leary | File Added: Screen Shot 2012-10-26 at 8.53.04 AM.png | |
| 2012-10-29 11:47 | Utkarsh Ayachit | Relationship added | related to 0013469 |
| 2012-10-30 09:04 | Sebastien Jourdain | Assigned To | => Sebastien Jourdain |
| 2012-10-30 09:05 | Sebastien Jourdain | Topic Name | => 13469_fix_cube_axes_parallel_rendering |
| 2012-10-30 09:05 | Sebastien Jourdain | Status | backlog => gatekeeper review |
| 2012-10-30 09:05 | Sebastien Jourdain | Resolution | open => fixed |
| 2012-10-30 13:30 | Sebastien Jourdain | Note Added: 0029600 | |
| 2012-10-31 10:46 | Utkarsh Ayachit | Fixed in Version | => 3.98.0 |
| 2012-10-31 10:47 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
| 2012-10-31 10:47 | Utkarsh Ayachit | Note Added: 0029617 | |
| 2012-10-31 20:09 | Alan Scott | Note Added: 0029636 | |
| 2012-10-31 20:09 | Alan Scott | Status | customer review => closed |
| Issue History |
