| 0013061 | ParaView | (No Category) | public | 2012-04-06 11:00 | 2015-01-11 08:26 | ||||
| Product Version | |||||||||
| Target Version | 4.0 | Fixed in Version | 4.0 | ||||||
| Summary | 0013061: Add option to enable building without WebKit | ||||||||
| Description | Add option to enable building without WebKit | ||||||||
| Project | Kitware | ||||||||
| Topic Name | 13061_make_webkit_optional | ||||||||
| Type | feature | ||||||||
| Attached Files | |||||||||
| Relationships | |
| Relationships |
| Notes | |
(0030736) Utkarsh Ayachit (administrator) 2013-05-09 11:48 |
People have also had issues with running the Qt documentation generator on occasion (mostly due to incorrect Qt build/install). If possible, we should make all embedded documentation optional. |
(0030773) Utkarsh Ayachit (administrator) 2013-05-15 15:18 |
commit 477d409d7b4b6d9b6603c2f8e32f5adf5cacaeeb Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Wed May 15 15:16:31 2013 -0400 BUG 0013061: Adding ability to build ParaView without WebKit. Added a new advanced cmake option QT_WIDGETS_DISABLE_QTWEBKIT. That can be used to disable WebKit support in ParaView. Users can turn it ON to disable the dependency on QtWebKit. Change-Id: I0c40dba7f559efd5f39d86c8d7612086381c0272 |
(0030774) Utkarsh Ayachit (administrator) 2013-05-15 15:21 |
commit e0cc7fe0ed831bd52b33811cf5d1c33a59ea61b9 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Wed May 15 15:20:56 2013 -0400 BUG 0013061. Renaming QT_WIDGETS_DISABLE_QTWEBKIT Renaming QT_WIDGETS_DISABLE_QTWEBKIT to PQWIDGETS_DISABLE_QTWEBKIT to match the name of the module. Change-Id: Id2934e0d6bd58682c56e72553bd4e4e9794dc4cc |
(0030775) Utkarsh Ayachit (administrator) 2013-05-15 15:25 |
commit d60727fe5de0c0d2bdc24f6fcc3c0853a1bcbaa0 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Wed May 15 15:24:27 2013 -0400 Fixed typo in fix for BUG 0013061. Change-Id: If4c5d7ff2dedf3bac6bc41817d2243b0f99165d3 |
(0030785) Utkarsh Ayachit (administrator) 2013-05-16 08:14 |
SUMMARY --------------------------------------------- Topics merged into master: 13061_make_webkit_optional 13951_log_custom_ticks 14018_spreadsheet_spcth_crash 14027_crinkle_clip_bug 14062_test_catalyst_outputs 14064_cleanup_catalyze_script FixCrashOnHyperTreeGridSource FixMissingSTLHeaderForH5PartReader fix-benchmark-printlog-in-sym-mode fix-warnings-v4 flip-scalarbar-labels refactor_python_interpretor |
(0030827) Alan Scott (manager) 2013-05-22 19:43 |
Developer tag in Git. Closing. |
| Notes |
| Issue History | |||
| 2012-04-06 11:00 | Utkarsh Ayachit | New Issue | |
| 2012-04-06 11:00 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
| 2013-05-09 11:48 | Utkarsh Ayachit | Note Added: 0030736 | |
| 2013-05-09 11:48 | Utkarsh Ayachit | Target Version | => 4.0 |
| 2013-05-15 15:18 | Utkarsh Ayachit | Topic Name | => 13061_make_webkit_optional |
| 2013-05-15 15:18 | Utkarsh Ayachit | Note Added: 0030773 | |
| 2013-05-15 15:18 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
| 2013-05-15 15:18 | Utkarsh Ayachit | Fixed in Version | => git-next |
| 2013-05-15 15:18 | Utkarsh Ayachit | Resolution | open => fixed |
| 2013-05-15 15:21 | Utkarsh Ayachit | Note Added: 0030774 | |
| 2013-05-15 15:25 | Utkarsh Ayachit | Note Added: 0030775 | |
| 2013-05-16 08:12 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
| 2013-05-16 08:14 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
| 2013-05-16 08:14 | Utkarsh Ayachit | Note Added: 0030785 | |
| 2013-05-18 20:00 | Utkarsh Ayachit | Fixed in Version | git-master => 4.0 |
| 2013-05-22 19:43 | Alan Scott | Note Added: 0030827 | |
| 2013-05-22 19:43 | Alan Scott | Status | customer review => closed |
| 2015-01-11 08:25 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 4a04cab1 |
| 2015-01-11 08:25 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master d60727fe |
| 2015-01-11 08:25 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master e0cc7fe0 |
| 2015-01-11 08:26 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 477d409d |
| Issue History |
