| 0013000 | ParaView | (No Category) | public | 2012-03-14 16:52 | 2012-10-29 17:04 | ||||
| Assigned To | Marcus D. Hanwell | ||||||||
| Product Version | 3.14 | ||||||||
| Target Version | Fixed in Version | 3.98.0 | |||||||
| Summary | 0013000: Fix axis labeling modes | ||||||||
| Description | Currently vtkAxis has 3 "behavior" modes: - AUTO - FIXED - CUSTOM CUSTOM was added to support explicit labeling in ParaView, but that's not working correctly. A cleaner solution (as discussed) is as follows: 1> vtkAxis' "behavior" mode will only control how the axis determines its range i.e. AUTO == based on data, and FIXED == using user-specified min/max. (No CUSTOM anymore). 2> vtkAxis will have labeling mode flag that controls how labels are placed (independent of how the axis ranges are decided). This can simply be a boolean (or enum) that indicates if the labels are placed automatically or only at user-specified values. If set to use user-specified values, then the "TickLabels" are used and labels are placed at only those values. Not that as user-zooms, the axis ranges change by the labels are still shown at only the indicated locations (similar to what would was expected in pase with CUSTOM behavior). | ||||||||
| Project | TBD | ||||||||
| Topic Name | |||||||||
| Attached Files | |||||||||
| Relationships | ||||||
| Relationships |
| Notes | |
(0028359) Utkarsh Ayachit (administrator) 2012-03-14 16:53 |
Marcus, once the VTK changes are in I can fix the dialog/proxies. Right now (in charts_on_tile_displays topic) custom labels aren't working as expected. |
(0029170) Marcus D. Hanwell (developer) 2012-09-11 14:59 |
This is really a VTK issue, it is resolved in this commit, http://review.source.kitware.com/#/c/7488/ [^] A new ivar was added, along with a new test to exercise different axis configurations. This is now merged into VTK, please let me know if there is any missing API you need. The new ivar is CustomTickLabels, which is set to true when setting custom tick labels, and can be set to false if not. The TestAxes test exercises several configurations. |
(0029202) Utkarsh Ayachit (administrator) 2012-09-14 11:09 |
merged in master, if applicable. |
(0029251) Alan Scott (manager) 2012-09-20 21:19 |
Somewhat internal discussion. I also looked at axis layout for a plot over line, and it looks good. |
| Notes |
| Issue History | |||
| 2012-03-14 16:52 | Utkarsh Ayachit | New Issue | |
| 2012-03-14 16:52 | Utkarsh Ayachit | Assigned To | => Marcus D. Hanwell |
| 2012-03-14 16:53 | Utkarsh Ayachit | Note Added: 0028359 | |
| 2012-08-30 10:36 | Utkarsh Ayachit | Relationship added | related to 0013411 |
| 2012-09-11 14:59 | Marcus D. Hanwell | Note Added: 0029170 | |
| 2012-09-11 14:59 | Marcus D. Hanwell | Status | backlog => gatekeeper review |
| 2012-09-11 14:59 | Marcus D. Hanwell | Resolution | open => fixed |
| 2012-09-14 11:09 | Utkarsh Ayachit | Fixed in Version | => git-master |
| 2012-09-14 11:09 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
| 2012-09-14 11:09 | Utkarsh Ayachit | Note Added: 0029202 | |
| 2012-09-20 21:19 | Alan Scott | Note Added: 0029251 | |
| 2012-09-20 21:19 | Alan Scott | Status | customer review => closed |
| 2012-10-29 17:04 | Utkarsh Ayachit | Fixed in Version | git-master => 3.98.0 |
| Issue History |
