| 0012601 | ParaView | (No Category) | public | 2011-09-16 18:57 | 2014-08-29 10:59 | ||||
| Product Version | 3.10.1 | ||||||||
| Target Version | 4.2 | Fixed in Version | 4.2 | ||||||
| Summary | 0012601: Color range should have an option to update every time step | ||||||||
| Description | The color range should have an option to rescale every timestep Windows, 3.10.1, local server. Open Can.exo. Play. - feature request - We should have an option to update the min and max every timestep. This would be useful if you don't care the size of an event, but where the min and max is. | ||||||||
| Project | Sandia | ||||||||
| Topic Name | |||||||||
| Type | feature | ||||||||
| Attached Files | |||||||||
| Relationships | ||||||||||||||||
| Relationships |
| Notes | |
(0029821) Alan Scott (manager) 2012-11-30 14:00 |
This is the default behavior for VisIt. Although I don't want this to be the default, it should be available. |
(0030639) Sebastien Jourdain (manager) 2013-04-30 16:29 |
Are you looking for a true rescale or just a growing behavior ? By a true rescale I mean that the min value can increase while moving along the time. |
(0030640) Alan Scott (manager) 2013-04-30 17:08 |
True rescale. The reason is that a user may not care about the range, but is actually looking for areas of change. For instance, in an engine cylinder, you may want to watch the swirl of gasses, colored by pressure. Even though the pressure changes by 10X, you may want each frame to be colored by the full range from this frames min to this frames max. In other words, if I have three frames as follows: frame 1 pressure 1 to 1000 frame 2 pressure 10 to 100 frame 3 pressure 50 to 60 I want three frames, as follows: frame 1 min 1, max 1000 frame 2 min 10, max 100 frame 3 min 50, max 60 Please make this NOT be the default. |
(0032640) Utkarsh Ayachit (administrator) 2014-05-16 06:53 |
Fixed. There's a new option under "Settings" dialog, under Transfer Function Options. |
(0032844) Alan Scott (manager) 2014-06-10 22:07 |
Tested local server, master, Linux. |
| Notes |
| Issue History | |||
| 2011-09-16 18:57 | Alan Scott | New Issue | |
| 2012-11-30 14:00 | Alan Scott | Note Added: 0029821 | |
| 2012-11-30 14:00 | Alan Scott | Assigned To | => Alan Scott |
| 2012-11-30 14:01 | Alan Scott | Assigned To | Alan Scott => |
| 2012-11-30 14:01 | Alan Scott | Status | backlog => todo |
| 2013-04-30 16:29 | Sebastien Jourdain | Note Added: 0030639 | |
| 2013-04-30 17:08 | Alan Scott | Note Added: 0030640 | |
| 2013-07-30 10:07 | Utkarsh Ayachit | Target Version | => 4.1 |
| 2014-01-16 16:47 | Utkarsh Ayachit | Target Version | 4.1 => 4.2 |
| 2014-02-15 12:07 | Utkarsh Ayachit | Relationship added | child of 0014578 |
| 2014-02-24 12:52 | Utkarsh Ayachit | Relationship added | related to 0007564 |
| 2014-02-27 10:24 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
| 2014-02-27 10:24 | Utkarsh Ayachit | Status | todo => active development |
| 2014-05-16 06:53 | Utkarsh Ayachit | Note Added: 0032640 | |
| 2014-05-16 06:53 | Utkarsh Ayachit | Status | active development => gatekeeper review |
| 2014-05-16 06:53 | Utkarsh Ayachit | Fixed in Version | => git-master |
| 2014-05-16 06:53 | Utkarsh Ayachit | Resolution | open => fixed |
| 2014-05-16 06:53 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
| 2014-06-10 22:07 | Alan Scott | Note Added: 0032844 | |
| 2014-06-10 22:07 | Alan Scott | Status | customer review => closed |
| 2014-07-31 18:29 | Alan Scott | Relationship added | related to 0014901 |
| 2014-08-29 10:59 | Utkarsh Ayachit | Fixed in Version | git-master => 4.2 |
| Issue History |
