| 0012363 | ParaView | (No Category) | public | 2011-07-13 04:26 | 2012-02-08 17:24 | ||||
| Reporter | Sven Buijssen | ||||||||
| Assigned To | Sankhesh Jhaveri | ||||||||
| Product Version | 3.10.1 | ||||||||
| Target Version | Fixed in Version | 3.12 | |||||||
| Summary | 0012363: Saving as PVTI/PVTU fails if file name contains more than 1 dot | ||||||||
| Description | PV 3.10.1 official binary release and own build of git master as of now (with AutoMPI ON to be connected to at least 2 pvserver processes, otherwise saving as PVT? is not available): Sources - Wavelet File - Save Data - File name: "foo.bar.pvti" => ERROR: .../ParaViewCore/ServerManager/vtkSMWriterFactory.cxx, line 361 vtkSMWriterFactory (0x1420b30): No matching writer found. Failed to create writer for: ".../foo.bar.pvti" Use "foobar.pvti" as file name instead and everything works smoothly. The same error occurs when trying to save to PVTU file format (squeeze in a "Filters - Clean to Grid" before trying to save). | ||||||||
| Project | TBD | ||||||||
| Topic Name | 12181-Writer-Failure | ||||||||
| Attached Files | |||||||||
| Relationships | ||||||
| Relationships |
| Notes | |
(0027524) Sankhesh Jhaveri (developer) 2011-09-26 09:08 |
7a41f44 FIX: Find Last period in the filename to get extension |
(0027525) David Partyka (developer) 2011-09-26 09:16 |
Merged into master via 12181-Writer-failure |
(0028142) Utkarsh Ayachit (administrator) 2012-02-08 17:24 |
Closing bugs sitting in "customer review" for a long time. |
| Notes |
| Issue History | |||
| 2011-07-13 04:26 | Sven Buijssen | New Issue | |
| 2011-09-02 12:59 | Utkarsh Ayachit | Assigned To | => Sankhesh Jhaveri |
| 2011-09-26 09:08 | Sankhesh Jhaveri | Topic Name | => 12181-Writer-Failure |
| 2011-09-26 09:08 | Sankhesh Jhaveri | Note Added: 0027524 | |
| 2011-09-26 09:08 | Sankhesh Jhaveri | Status | backlog => gatekeeper review |
| 2011-09-26 09:08 | Sankhesh Jhaveri | Resolution | open => fixed |
| 2011-09-26 09:16 | David Partyka | Relationship added | related to 0012181 |
| 2011-09-26 09:16 | David Partyka | Note Added: 0027525 | |
| 2011-09-26 09:16 | David Partyka | Status | gatekeeper review => customer review |
| 2011-11-11 17:08 | Utkarsh Ayachit | Fixed in Version | => 3.12 |
| 2012-02-08 17:24 | Utkarsh Ayachit | Status | customer review => closed |
| 2012-02-08 17:24 | Utkarsh Ayachit | Note Added: 0028142 | |
| Issue History |
