| 0012241 | ParaView | Bug | public | 2011-06-03 10:00 | 2011-06-24 20:26 | ||||
| Product Version | |||||||||
| Target Version | Fixed in Version | 3.12 | |||||||
| Summary | 0012241: Connecting/Disconnecting to pvservers multiple times doesn't work | ||||||||
| Description | PV git master, OS X 10.6.7, Qt 4.7.2. Connecting/Disconnecting to pvservers multiple times doesn't work but crashes ParaView. Steps to Reproduce: File->Connect... Choose a properly configured entry from the "Choose a servrer:" list File->Disconnect File->Connect... Choose a properly configured entry from the "Choose a servrer:" list Then the pvservers don't start up but ParaView crashes. Attached the complete console log in Additional Information. Additional Information: Multiple server connections not supported yet. Requesting to remove a non-added server. ERROR: In /Volumes/RAID0data/paraview/ParaView/ParaViewCore/ServerImplementation/vtkPVSessionCore.cxx, line 317 vtkPVSessionCore (0x12003eea0): Attempt to assign existing ID 1. while processing Message 0 = Assign Argument 0 = id_value {1} Argument 1 = vtk_object_pointer {vtkPVSessionCoreInterpreterHelper (0x120031220)} ERROR: In /Volumes/RAID0data/paraview/ParaView/ParaViewCore/ServerImplementation/vtkPVSessionCore.cxx, line 318 vtkPVSessionCore (0x12003eea0): Aborting execution for debugging purposes. | ||||||||
| Project | |||||||||
| Topic Name | |||||||||
| Type | |||||||||
| Attached Files | |||||||||
| Relationships | |
| Relationships |
| Notes | |
(0026662) Utkarsh Ayachit (administrator) 2011-06-03 10:04 |
commit c722aabd71054536924f0ba0b66bcdb69275e2e3 Merge: 43b53b3 441ad1a Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Fri Jun 3 10:04:14 2011 -0400 Merge topic '12241_multiple_connects_failed' 441ad1a Fixed BUG 0012241. Multiple connects was causing issues. commit 441ad1a1cfa481305808f9cca2bc025c06da9ba9 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Fri Jun 3 10:00:28 2011 -0400 Fixed BUG 0012241. Multiple connects was causing issues. The problem was that the queued-connection was causing the newly connected server to be disconnected as well. In general this server-connection code is very hard to debug. The complication exists due to the fact that when we originally wrote this code, we didn't allow modal dialogs in ParaView. That resulted in very hard to read code and bugs keep on creeping in. We need to bite the bullet and clean it up at some point. |
(0026891) Alan Scott (manager) 2011-06-24 20:26 |
Tested Linux, trunk. |
| Notes |
| Issue History | |||
| 2011-06-03 10:00 | Utkarsh Ayachit | New Issue | |
| 2011-06-03 10:04 | Utkarsh Ayachit | Note Added: 0026662 | |
| 2011-06-03 10:04 | Utkarsh Ayachit | Status | backlog => @80@ |
| 2011-06-03 10:04 | Utkarsh Ayachit | Fixed in Version | => 3.12 |
| 2011-06-03 10:04 | Utkarsh Ayachit | Resolution | open => fixed |
| 2011-06-03 10:04 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
| 2011-06-24 20:26 | Alan Scott | Note Added: 0026891 | |
| 2011-06-24 20:26 | Alan Scott | Status | customer review => closed |
| Issue History |
