| 0012238 | ParaView | Bug | public | 2011-05-30 09:29 | 2015-01-11 08:21 | ||||
| Product Version | |||||||||
| Target Version | 3.12 | Fixed in Version | 3.12 | ||||||
| Summary | 0012238: ParaView should auto-load server-side plugins before firing serverAdded signal | ||||||||
| Description | As reported on mailing list: ".... plugins on the client, receive serverAdded, before plugins on the server have been loaded, so if they try to create proxies via the proxymanager - they fail because the server doesn't have them yet and can't create them. This is a problem. I'm looking around to see if there is some other way I can destroy and recreate proxies when the gui starts up and then the user makes a new connection. Ideally I need a pluginsLoaded (on the server) rather than a serverAdded event." | ||||||||
| Project | |||||||||
| Topic Name | |||||||||
| Type | |||||||||
| Attached Files | |||||||||
| Relationships | |
| Relationships |
| Notes | |
(0026665) Utkarsh Ayachit (administrator) 2011-06-03 14:09 |
commit 57c34b277a85ff3a9d97b5e4a1b2fc0b62c9a6d1 Merge: 8926339 924a415 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Tue May 31 10:40:41 2011 -0400 Merge topic '12240_cleanup_proxy_definition_manager' 924a415 Ensuring that plugin status is updated as plugins are loaded. 23728e6 Fixed BUG 0012238. Load plugins before server-added is noted. 11fb702 Making ProxyDefinitionManager a Remote Object. 9fb7062 Mark this plugin as required on server alone. c784bbc Incorrect 'if' resulted in plugins reported required on client. |
(0026668) Alan Scott (manager) 2011-06-03 17:04 |
Trusting Utkarsh. |
| Notes |
| Issue History | |||
| 2011-05-30 09:29 | Utkarsh Ayachit | New Issue | |
| 2011-05-30 09:29 | Utkarsh Ayachit | Status | backlog => tabled |
| 2011-05-30 09:29 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
| 2011-06-03 14:09 | Utkarsh Ayachit | Note Added: 0026665 | |
| 2011-06-03 14:09 | Utkarsh Ayachit | Status | tabled => @80@ |
| 2011-06-03 14:09 | Utkarsh Ayachit | Fixed in Version | => 3.12 |
| 2011-06-03 14:09 | Utkarsh Ayachit | Resolution | open => fixed |
| 2011-06-03 17:04 | Alan Scott | Note Added: 0026668 | |
| 2011-06-03 17:04 | Alan Scott | Status | @80@ => closed |
| 2015-01-11 08:21 | Sebastiennn Jourdain | Source_changeset_attached | => ParaView master 8637fffc |
| Issue History |
