| 0012180 | ParaView | Bug | public | 2011-05-11 05:14 | 2012-02-08 17:25 | ||||
| Reporter | Jerome Velut | ||||||||
| Priority | normal | Severity | minor | Reproducibility | always | ||||
| Platform | Intel x64 | OS | Linux | OS Version | Fedora-14 | ||||
| Product Version | Development | ||||||||
| Target Version | 3.12 | Fixed in Version | 3.12 | ||||||
| Summary | 0012180: Lookup table messed when source representation is 'Volume' | ||||||||
| Description | When the representation of a source is set to 'Volume', the following filters are not able to get a 'good' lookup table. Instead, a weird 'blue to red' color map is provided and is uneditable. Moreover, the 'Volume' and 'slice' representation do not follow this color map. | ||||||||
| Steps To Reproduce | - add a Wavelet source - set representation to 'Volume' - add an 'Extract Subset' filter and click apply - Go to 'Edit Color Map' -> you will see the uneditable color map - Set 'ExtractSubset1' representation to 'Volume': the representation show a B&W surface of the volume... | ||||||||
| Additional Information | Occurs on git-master and pv3.10.1, standalone and pvserver. | ||||||||
| Project | TBD | ||||||||
| Topic Name | 12180_fix_lut | ||||||||
| Attached Files | |||||||||
| Relationships | |
| Relationships |
| Notes | |
(0026519) Jerome Velut (reporter) 2011-05-17 15:42 |
I reproduced the bug with the ParaView-3.10.1 binaries provided on the paraview website (Linux x86_64). |
(0027413) Utkarsh Ayachit (administrator) 2011-08-22 14:35 |
commit e7e0ba02fcc7f929d0998399c34cef54db9467b1 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Mon Aug 22 14:34:17 2011 -0400 Fixed BUG 0012180. LUT was getting messed up. The problem was that the ColorArrayName was being inherited when "ExtractSubset" was created even though the representation type was set to Outline. That confused the GUI to no ends. Fixed that by ensuring that the ColorArrayName is cleared for Outline. |
(0028149) Utkarsh Ayachit (administrator) 2012-02-08 17:25 |
Closing bugs sitting in "customer review" for a long time. |
| Notes |
| Issue History | |||
| 2011-05-11 05:14 | Jerome Velut | New Issue | |
| 2011-05-17 15:42 | Jerome Velut | Note Added: 0026519 | |
| 2011-07-01 09:26 | Utkarsh Ayachit | Project | => TBD |
| 2011-07-01 09:26 | Utkarsh Ayachit | Type | => incorrect functionality |
| 2011-07-01 09:26 | Utkarsh Ayachit | Target Version | => 3.12 |
| 2011-07-12 13:01 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
| 2011-07-12 13:01 | Utkarsh Ayachit | Status | backlog => todo |
| 2011-08-22 14:35 | Utkarsh Ayachit | Topic Name | => 12180_fix_lut |
| 2011-08-22 14:35 | Utkarsh Ayachit | Note Added: 0027413 | |
| 2011-08-22 14:35 | Utkarsh Ayachit | Status | todo => gatekeeper review |
| 2011-08-22 14:35 | Utkarsh Ayachit | Fixed in Version | => 3.12 |
| 2011-08-22 14:35 | Utkarsh Ayachit | Resolution | open => fixed |
| 2011-08-26 15:57 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
| 2012-02-08 17:25 | Utkarsh Ayachit | Status | customer review => closed |
| 2012-02-08 17:25 | Utkarsh Ayachit | Note Added: 0028149 | |
| Issue History |
