0011012 | ParaView | Bug | public | 2010-07-19 22:01 | 2010-08-04 16:43 | ||||
Assigned To | Marcus D. Hanwell | ||||||||
Priority | urgent | Severity | crash | Reproducibility | sometimes | ||||
Target Version | 3.8.1 | Fixed in Version | 3.8.1 | ||||||
Summary | 0011012: mouse movement crashes 2d plots | ||||||||
Description | There may be some randomness to replicating this bug, but here is how I have replicated it: ParaView 3.8 branch, snapshot about a week ago. Linux build. Local client. Here is the computer information: workstation01: uname -a Linux workstation01 2.6.18-194.el5 #1 SMP Tue Mar 16 21:52:39 EDT 2010 x86_64 x86_64 x86_64 GNU/Linux cat /etc/X11/xorg.conf: ... Section "Device" Identifier "Device0" Driver "nvidia" VendorName "NVIDIA Corporation" EndSection ... Let me know if you cannot replicate this, and I will do a debug build. ssh -X into the Linux box. I am using cygwin, I believe others have replicated without cygwin or ssh'ing into a linux box. Open can.exo. All variables on, apply. (I actually rotated the can so I can see it, not sure if this matters.) Plot over line. Apply. Move the cursor right, across the 3d viewport and the can, onto the 2d window. It has crashed 3 times out of 3. ERROR: In /projects/viz/paraview/src/ParaView/3.8.1_stable/ParaView3/VTK/Rendering/vtkTextureObject.cxx, line 263 vtkTextureObject (0x1f737f30): Required OpenGL extensions not supported by the context. ERROR: In /projects/viz/paraview/src/ParaView/3.8.1_stable/ParaView3/VTK/Rendering/vtkTextureObject.cxx, line 1133 vtkTextureObject (0x1f737f30): No context specified. Cannot create texture. paraview-real: /projects/viz/paraview/src/ParaView/3.8.1_stable/ParaView3/VTK/Charts/vtkOpenGLContextBufferId.cxx:102: virtual void vtkOpenGLContextBufferId::SetValues(int, int): Assertion `"pre: is_allocated" && this->IsAllocated()' failed. | ||||||||
(0021464) Marcus D. Hanwell (developer) 2010-07-22 14:48 |
Commit 8ad6e3e should fix this, I have asked Dave Partyka to pull it into the release branch. |
(0021494) Marcus D. Hanwell (developer) 2010-07-27 13:43 |
This was also pushed into the release branch. |
(0021653) Alan Scott (manager) 2010-08-04 16:43 |
Tested local server, Linux, trunk. I ssh -X'd into the Linux box from Windows, using cygwin. |
2010-07-19 22:01 | Alan Scott | New Issue | |
2010-07-21 09:44 | Utkarsh Ayachit | Assigned To | => Marcus D. Hanwell |
2010-07-21 09:44 | Utkarsh Ayachit | Status | backlog => tabled |
2010-07-22 14:48 | Marcus D. Hanwell | Note Added: 0021464 | |
2010-07-27 13:43 | Marcus D. Hanwell | Note Added: 0021494 | |
2010-07-27 13:43 | Marcus D. Hanwell | Status | tabled => @80@ |
2010-07-27 13:43 | Marcus D. Hanwell | Fixed in Version | => 3.8.1 |
2010-07-27 13:43 | Marcus D. Hanwell | Resolution | open => fixed |
2010-08-04 16:43 | Alan Scott | Note Added: 0021653 | |
2010-08-04 16:43 | Alan Scott | Status | @80@ => closed |
