| 0010960 | ParaView | Feature | public | 2010-07-08 14:53 | 2010-12-08 12:38 | ||||
| Reporter | Ken Moreland | ||||||||
| Assigned To | Sebastien Jourdain | ||||||||
| Product Version | |||||||||
| Target Version | 3.10 | Fixed in Version | 3.10 | ||||||
| Summary | 0010960: Change query object in Find Data dialog box | ||||||||
| Description | When you open the Find Data dialog, it grabs the active object in the pipeline browser to perform the selection on. That is good, but then that object is fixed. You should be able to change it. Rather than display the object name in a label, it should be a combo box that allows you to change it. When you change the object in the Find Data dialog, it should probably change the active object in the pipeline browser (and vice versa). | ||||||||
| Project | |||||||||
| Topic Name | |||||||||
| Type | |||||||||
| Attached Files | |||||||||
| Relationships | ||||||
| Relationships |
| Notes | |
(0023704) Utkarsh Ayachit (administrator) 2010-12-03 16:19 |
Seb, this is fixed too right? |
(0023705) Sebastien Jourdain (manager) 2010-12-03 16:21 |
done in the merge commit |
(0023802) Alan Scott (manager) 2010-12-08 12:38 |
The first half of the bug was tested remote server, windows client, trunk. Ken and I both feel that not implementing the second half of the feature request is fine. Lets close this request with current behavior. |
| Notes |
| Issue History | |||
| 2010-07-08 14:53 | Ken Moreland | New Issue | |
| 2010-07-08 14:53 | Ken Moreland | Relationship added | child of 0010627 |
| 2010-12-03 16:18 | Utkarsh Ayachit | Assigned To | => Sebastiennn Jourdain |
| 2010-12-03 16:18 | Utkarsh Ayachit | Status | backlog => tabled |
| 2010-12-03 16:19 | Utkarsh Ayachit | Note Added: 0023704 | |
| 2010-12-03 16:21 | Sebastien Jourdain | Note Added: 0023705 | |
| 2010-12-03 16:21 | Sebastien Jourdain | Status | tabled => @80@ |
| 2010-12-03 16:21 | Sebastien Jourdain | Resolution | open => fixed |
| 2010-12-03 16:30 | Utkarsh Ayachit | Fixed in Version | => 3.10 |
| 2010-12-08 12:38 | Alan Scott | Note Added: 0023802 | |
| 2010-12-08 12:38 | Alan Scott | Status | @80@ => closed |
| 2011-06-16 13:10 | Zack Galbreath | Category | Feature Request => Feature |
| Issue History |
