| 0010864 | ParaView | Feature | public | 2010-06-22 11:37 | 2013-10-17 17:36 | ||||
| Reporter | Ken Moreland | ||||||||
| Product Version | |||||||||
| Summary | 0010864: Setting for interactive rendering delay | ||||||||
| Description | Thanks to the resolution of 0010232, there is a two second pause from the time you start interacting and the time a still render starts. (Awesome feature, BTW.) There should also be a settings option (under Render View -> General) that allows you to set the length of this pause. If set down to 0, then there would be no pause (i.e. the old behavior). I don't know what the maximum wait should be. 5 sec? 10? 30? | ||||||||
| Project | |||||||||
| Topic Name | |||||||||
| Type | |||||||||
| Attached Files | |||||||||
| Relationships | |||||||||||
| Relationships |
| Notes | |
(0031693) Alan Scott (manager) 2013-10-17 17:35 |
This was resolved a while ago. On the Settings dialog, Render View, General, is the option to "Lock Interactive Render" to a time. Default is 0 seconds - which is correct for 99 percent of use cases. |
| Notes |
| Issue History | |||
| 2010-06-22 11:37 | Ken Moreland | New Issue | |
| 2010-06-22 11:37 | Ken Moreland | Relationship added | related to 0010232 |
| 2010-06-22 11:38 | Ken Moreland | Target Version | => 3.10 |
| 2010-06-22 11:38 | Ken Moreland | Status | backlog => tabled |
| 2010-06-22 11:38 | Ken Moreland | Assigned To | => Utkarsh Ayachit |
| 2010-08-05 20:37 | Ken Moreland | Relationship added | has duplicate 0011100 |
| 2011-06-16 13:10 | Zack Galbreath | Category | Feature Request => Feature |
| 2013-10-17 17:35 | Alan Scott | Note Added: 0031693 | |
| 2013-10-17 17:35 | Alan Scott | Status | expired => closed |
| 2013-10-17 17:36 | Alan Scott | Resolution | open => fixed |
| Issue History |
