| 0010815 | ParaView | Bug | public | 2010-06-10 10:34 | 2010-07-08 10:42 | ||||
| Product Version | |||||||||
| Target Version | 3.8.1 | Fixed in Version | 3.8.1 | ||||||
| Summary | 0010815: PointSpritePlugin_BUILD_EXAMPLES does not follow BUILD_EXAMPLES | ||||||||
| Description | From mailing list: ----------------------------------------------------------------------- I have the following in my log while preparing the gentoo package for paraview: -- Installing: /media/anthill/portage/sci- visualization/paraview-3.8.0/image/usr/lib/paraview-3.8/libPointSprite_Graphics.so -- Installing: /media/anthill/portage/sci- visualization/paraview-3.8.0/image/media/anthill/portage/sci- visualization/paraview-3.8.0/work/ParaView-3.8.0_build/Plugins/PointSprite/PointSpriteDemo -- Installing: /media/anthill/portage/sci- visualization/paraview-3.8.0/image/usr/lib/paraview-3.8/libPointSprite_Plugin.so PointSpriteDemo is the only one with that behaviour out of the stuff I checked so far. Also, it is an example and I have turned examples off (BUILD_EXAMPLES OFF) but this particular one is always on, from "Plugins/PointSprite/CMakeList.txt": set(PointSpritePlugin_BUILD_EXAMPLES ON CACHE BOOL "Build the example.") if(PointSpritePlugin_BUILD_EXAMPLES) add_subdirectory(Examples) endif(PointSpritePlugin_BUILD_EXAMPLES) This is not consistent, if I turn off examples at the top level I expect them to be all off. | ||||||||
| Project | |||||||||
| Topic Name | |||||||||
| Type | |||||||||
| Attached Files | |||||||||
| Relationships | |
| Relationships |
| Notes | |
(0020966) Utkarsh Ayachit (administrator) 2010-06-10 10:39 |
commit c9af0d884532cbe472993d19a2ef6327aa9be5d8 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Thu Jun 10 10:38:06 2010 -0400 Fixed BUG 0010815. PointSpritePlugin_BUILD_EXAMPLES is available only when BUILD_EXAMPLES is not. If BUILD_EXAMPLES is defined, then it is used to decide to build the point sprite examples. ------------------- TODO: Merge into "release" branch |
(0021056) Alan Scott (manager) 2010-06-16 18:19 |
Assuming Utkarsh did it correctly. |
(0021328) Utkarsh Ayachit (administrator) 2010-07-08 10:42 |
moved to release. |
| Notes |
| Issue History | |||
| 2010-06-10 10:34 | Utkarsh Ayachit | New Issue | |
| 2010-06-10 10:34 | Utkarsh Ayachit | Status | backlog => tabled |
| 2010-06-10 10:34 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
| 2010-06-10 10:39 | Utkarsh Ayachit | Note Added: 0020966 | |
| 2010-06-10 10:39 | Utkarsh Ayachit | Status | tabled => @80@ |
| 2010-06-10 10:39 | Utkarsh Ayachit | Fixed in Version | => 3.8.2 |
| 2010-06-10 10:39 | Utkarsh Ayachit | Resolution | open => fixed |
| 2010-06-15 09:44 | Utkarsh Ayachit | Target Version | 3.8.2 => 3.8.1 |
| 2010-06-15 09:45 | Utkarsh Ayachit | Fixed in Version | 3.8.2 => 3.8.1 |
| 2010-06-16 18:19 | Alan Scott | Note Added: 0021056 | |
| 2010-06-16 18:19 | Alan Scott | Status | @80@ => closed |
| 2010-07-07 09:55 | Utkarsh Ayachit | Fixed in Version | 3.8.1 => Development |
| 2010-07-07 17:16 | Utkarsh Ayachit | Note Added: 0021300 | |
| 2010-07-08 10:42 | Utkarsh Ayachit | Note Deleted: 0021300 | |
| 2010-07-08 10:42 | Utkarsh Ayachit | Note Added: 0021328 | |
| 2010-07-08 10:42 | Utkarsh Ayachit | Fixed in Version | Development => 3.8.1 |
| Issue History |
