| 0010680 | ParaView | Feature | public | 2010-05-05 11:22 | 2010-07-12 21:25 | ||||
| Product Version | |||||||||
| Target Version | 3.8.1 | Fixed in Version | 3.8.1 | ||||||
| Summary | 0010680: Changing filenames in state files. | ||||||||
| Description | When state files are loaded, if data filenames are no longer valid then paraview raises errors. Only solution is to manually edit the file. Two alternatives: 1> Popup a dialog showing all filenames in the state, letting the user to change any. 2> test is all referred files are valid, if not then popup a dialog allowing the user to change it. | ||||||||
| Project | |||||||||
| Topic Name | |||||||||
| Type | |||||||||
| Attached Files | |||||||||
| Relationships | |
| Relationships |
| Notes | |
(0021096) Utkarsh Ayachit (administrator) 2010-06-19 00:24 |
commit 8f3fe99a23c9fdb74cff7d3c2a374fa157239c68 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Fri Jun 18 15:38:12 2010 -0400 Fixed BUG 0010680. Added dialog to prompt to change filenames. Whenever a state file with filenames is loaded, ParaView prompts a dialog which allows the user to change filenames in the state file. |
(0021097) Utkarsh Ayachit (administrator) 2010-06-19 00:24 |
Need to move this to release branch. |
(0021319) Utkarsh Ayachit (administrator) 2010-07-08 10:33 |
moved to release branch |
(0021368) Alan Scott (manager) 2010-07-12 21:25 |
Very nice!! Tested local server, trunk, windows. |
| Notes |
| Issue History | |||
| 2010-05-05 11:22 | Utkarsh Ayachit | New Issue | |
| 2010-06-15 09:44 | Utkarsh Ayachit | Target Version | 3.8.2 => 3.8.1 |
| 2010-06-19 00:24 | Utkarsh Ayachit | Note Added: 0021096 | |
| 2010-06-19 00:24 | Utkarsh Ayachit | Status | backlog => @80@ |
| 2010-06-19 00:24 | Utkarsh Ayachit | Fixed in Version | => 3.8.1 |
| 2010-06-19 00:24 | Utkarsh Ayachit | Resolution | open => fixed |
| 2010-06-19 00:24 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
| 2010-06-19 00:24 | Utkarsh Ayachit | Note Added: 0021097 | |
| 2010-07-07 09:55 | Utkarsh Ayachit | Fixed in Version | 3.8.1 => Development |
| 2010-07-08 10:18 | Utkarsh Ayachit | Note Added: 0021314 | |
| 2010-07-08 10:33 | Utkarsh Ayachit | Note Deleted: 0021314 | |
| 2010-07-08 10:33 | Utkarsh Ayachit | Note Added: 0021319 | |
| 2010-07-08 10:33 | Utkarsh Ayachit | Fixed in Version | Development => 3.8.1 |
| 2010-07-12 21:25 | Alan Scott | Note Added: 0021368 | |
| 2010-07-12 21:25 | Alan Scott | Status | @80@ => closed |
| 2011-06-16 13:10 | Zack Galbreath | Category | Feature Request => Feature |
| Issue History |
