| 0010625 | ParaView | Feature | public | 2010-04-27 20:43 | 2015-06-17 17:07 | ||||
| Priority | high | Severity | minor | Reproducibility | always | ||||
| Product Version | |||||||||
| Target Version | 4.4 | Fixed in Version | |||||||
| Summary | 0010625: Selecting enhancements | ||||||||
| Description | A few ideas for enhancements for picking: * Allow select to find the nearest point on the surface of an object, rather than having to go surface with edges, then rubber band select a point, then turn surface with edges back off. Turn this mode on by default. * Allow select to either select once (current behavior), or turn on and stay on. When this mode is selected, as a user moves the mouse across a surface, the selected object will change. This would be used with cell or point labels turned on. | ||||||||
| Project | Sandia | ||||||||
| Topic Name | |||||||||
| Attached Files | |||||||||
| Relationships | |||||||||||
| Relationships |
| Notes | |
(0029667) Alan Scott (manager) 2012-11-07 22:13 |
This needs to be done. A user is asking for this. |
(0034571) Utkarsh Ayachit (administrator) 2015-06-17 14:10 |
Alan, If I understand correctly, (1) as same as BUG 0015306. Correct? Also, isn't (2) same as interactive selection? That what the new interactive selection modes do. You should be able to use the "Selection Display Inspector" to choose how to label the selection. |
(0034574) Alan Scott (manager) 2015-06-17 16:09 |
Correct. The first bullet is covered by (closed) bug http://www.paraview.org/Bug/view.php?id=15306, [^] and the second is covered by interactive selection. As soon as the second bug is closed, this master one gets closed. To quote a user that just saw what we have, this is a game changer. |
(0034581) Alan Scott (manager) 2015-06-17 17:07 |
As listed in the attached two bugs, which were closed, this feature request has been implemented. Closing. |
| Notes |
| Issue History | |||
| 2010-04-27 20:43 | Alan Scott | New Issue | |
| 2010-06-10 14:41 | Utkarsh Ayachit | Target Version | 3.8.2 => 3.10 |
| 2010-09-01 11:27 | Utkarsh Ayachit | Target Version | 3.10 => 3.10.shortlist |
| 2011-06-16 13:10 | Zack Galbreath | Category | Feature Request => Feature |
| 2012-11-07 22:13 | Alan Scott | Status | expired => backlog |
| 2012-11-07 22:13 | Alan Scott | Resolution | open => reopened |
| 2012-11-07 22:13 | Alan Scott | Note Added: 0029667 | |
| 2012-11-07 22:13 | Alan Scott | Status | backlog => todo |
| 2012-11-07 22:14 | Alan Scott | Project | => Sandia |
| 2012-11-07 22:14 | Alan Scott | Type | => incorrect functionality |
| 2012-11-07 22:14 | Alan Scott | Priority | normal => high |
| 2012-12-11 09:41 | Sebastien Jourdain | Assigned To | => David Thompson (old) |
| 2013-10-31 11:28 | Utkarsh Ayachit | Assigned To | David Thompson (old) => |
| 2013-10-31 11:29 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
| 2013-10-31 11:29 | Utkarsh Ayachit | Status | todo => backlog |
| 2014-01-16 17:02 | Utkarsh Ayachit | Target Version | => 4.2 |
| 2014-11-14 22:52 | Utkarsh Ayachit | Target Version | 4.2 => 4.4 |
| 2015-06-17 14:04 | Alan Scott | Relationship added | related to 0015306 |
| 2015-06-17 14:10 | Utkarsh Ayachit | Note Added: 0034571 | |
| 2015-06-17 16:07 | Alan Scott | Relationship added | related to 0015309 |
| 2015-06-17 16:09 | Alan Scott | Note Added: 0034574 | |
| 2015-06-17 17:07 | Alan Scott | Note Added: 0034581 | |
| 2015-06-17 17:07 | Alan Scott | Status | backlog => closed |
| 2015-06-17 17:07 | Alan Scott | Resolution | reopened => fixed |
| Issue History |
