(0011231)
Ken Moreland
2008-04-09 18:01
That's funny. Now you can't global ids for the label mode at all. You can select pedigree id mode an that works fine. |
(0011509)
Utkarsh Ayachit
2008-04-23 12:13
Waiting for VTK 5.2 branch to commit the fix. The problem was that the ExtractSelection filters didn't copy global ids over. |
(0011578)
Utkarsh Ayachit
2008-04-29 08:57
ENH: Fixes BUG # 6559. Block names are now used by all the GUI.
ENH: vtkExtractArraysOverTime names the blocks based on which cell/pt they represent.
BUG: Fixes BUG 0006262. Fixed all extract selection filters to pass global ids.
BUG: If composite dataset has no names, use default values
commitid: Z5CBZc5ycsbJl01t
/cvsroot/ParaView3/ParaView3/Qt/Components/pqProxyInformationWidget.cxx,v <-- Qt/Components/pqProxyInformationWidget.cxx
new revision: 1.18; previous revision: 1.17
/cvsroot/ParaView3/ParaView3/Qt/Components/pqSignalAdaptorCompositeTreeWidget.cxx,v <-- Qt/Components/pqSignalAdaptorCompositeTreeWidget.cxx
new revision: 1.8; previous revision: 1.7
/cvsroot/ParaView3/ParaView3/Servers/Common/vtkPVCompositeDataInformation.cxx,v <-- Servers/Common/vtkPVCompositeDataInformation.cxx
new revision: 1.14; previous revision: 1.13
/cvsroot/ParaView3/ParaView3/Servers/Common/vtkPVCompositeDataInformation.h,v <-- Servers/Common/vtkPVCompositeDataInformation.h
/cvsroot/ParaView3/ParaView3/Servers/Common/vtkPVDataInformation.cxx,v <-- Servers/Common/vtkPVDataInformation.cxx
new revision: 1.50; previous revision: 1.49
/cvsroot/ParaView3/ParaView3/Servers/Common/vtkPVDataInformation.h,v <-- Servers/Common/vtkPVDataInformation.h
new revision: 1.26; previous revision: 1.25
/cvsroot/ParaView3/ParaView3/VTK/Filtering/vtkCompositeDataSet.cxx,v <-- VTK/Filtering/vtkCompositeDataSet.cxx
new revision: 1.13; previous revision: 1.12
/cvsroot/ParaView3/ParaView3/VTK/Filtering/vtkCompositeDataSet.h,v <-- VTK/Filtering/vtkCompositeDataSet.h
/cvsroot/ParaView3/ParaView3/VTK/Graphics/vtkExtractArraysOverTime.cxx,v <-- VTK/Graphics/vtkExtractArraysOverTime.cxx
new revision: 1.20; previous revision: 1.19
/cvsroot/ParaView3/ParaView3/VTK/Graphics/vtkExtractSelectedFrustum.cxx,v <-- VTK/Graphics/vtkExtractSelectedFrustum.cxx
/cvsroot/ParaView3/ParaView3/VTK/Graphics/vtkExtractSelectedIds.cxx,v <-- VTK/Graphics/vtkExtractSelectedIds.cxx
new revision: 1.28; previous revision: 1.27
/cvsroot/ParaView3/ParaView3/VTK/Graphics/vtkExtractSelectedLocations.cxx,v <-- VTK/Graphics/vtkExtractSelectedLocations.cxx
new revision: 1.15; previous revision: 1.14
/cvsroot/ParaView3/ParaView3/VTK/Graphics/vtkExtractSelectedThresholds.cxx,v <-- VTK/Graphics/vtkExtractSelectedThresholds.cxx
/cvsroot/ParaView3/ParaView3/VTK/Graphics/vtkExtractSelection.cxx,v <-- VTK/Graphics/vtkExtractSelection.cxx
new revision: 1.24; previous revision: 1.23
/cvsroot/ParaView3/ParaView3/VTK/IO/vtkEnSight6BinaryReader.cxx,v <-- VTK/IO/vtkEnSight6BinaryReader.cxx
new revision: 1.58; previous revision: 1.57
/cvsroot/ParaView3/ParaView3/VTK/IO/vtkEnSight6Reader.cxx,v <-- VTK/IO/vtkEnSight6Reader.cxx
new revision: 1.68; previous revision: 1.67
/cvsroot/ParaView3/ParaView3/VTK/IO/vtkEnSightGoldBinaryReader.cxx,v <-- VTK/IO/vtkEnSightGoldBinaryReader.cxx
new revision: 1.77; previous revision: 1.76
/cvsroot/ParaView3/ParaView3/VTK/IO/vtkEnSightGoldReader.cxx,v <-- VTK/IO/vtkEnSightGoldReader.cxx
new revision: 1.63; previous revision: 1.62
/cvsroot/ParaView3/ParaView3/VTK/IO/vtkEnSightReader.cxx,v <-- VTK/IO/vtkEnSightReader.cxx
/cvsroot/ParaView3/ParaView3/VTK/IO/vtkEnSightReader.h,v <-- VTK/IO/vtkEnSightReader.h
new revision: 1.36; previous revision: 1.35 |
(0011637)
Alan Scott
2008-04-30 20:08
Seems to work very well locally, but freezes paraview up client/server. Just follow the steps in the bug, client/server.
XP client, 6 pvServer's.
Nightly trunk, as of the morning of April 30. |
(0011646)
Utkarsh Ayachit
2008-05-01 11:20
vtkSMDataLabelRepresentationProxy now inserts a
vtkCompositeDataToUnstructuredGridFilter to convert a composite input into an
unstructure grid, so that vtkMPIMoveData can work correctly. This was causing
the hangs when running client-server.
commitid: l6kYLQRDmTTf4h1t
/cvsroot/ParaView3/ParaView3/Servers/Filters/CMakeLists.txt,v <-- Servers/Filters/CMakeLists.txt
new revision: 1.166; previous revision: 1.165
/cvsroot/ParaView3/ParaView3/Servers/Filters/vtkCompositeDataToUnstructuredGridFilter.cxx,v <-- Servers/Filters/vtkCompositeDataToUnstructuredGridFilter.cxx
initial revision: 1.1
/cvsroot/ParaView3/ParaView3/Servers/Filters/vtkCompositeDataToUnstructuredGridFilter.h,v <-- Servers/Filters/vtkCompositeDataToUnstructuredGridFilter.h
/cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMDataLabelRepresentationProxy.cxx,v <-- Servers/ServerManager/vtkSMDataLabelRepresentationProxy.cxx
/cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMDataLabelRepresentationProxy.h,v <-- Servers/ServerManager/vtkSMDataLabelRepresentationProxy.h
/cvsroot/ParaView3/ParaView3/Servers/ServerManager/Resources/filters.xml,v <-- Servers/ServerManager/Resources/filters.xml
new revision: 1.280; previous revision: 1.279
/cvsroot/ParaView3/ParaView3/Servers/ServerManager/Resources/rendering.xml,v <-- Servers/ServerManager/Resources/rendering.xml
new revision: 1.281; previous revision: 1.280 |
(0011715)
Alan Scott
2008-05-05 19:45
