0006262 | ParaView | (No Category) | public | 2008-01-21 12:44 | 2011-01-13 17:00 | ||||
Summary | 0006262: Selection Inspector cannot display Cell Label GlobalElementId | ||||||||
Description | ParaView 3.2.1, XP. Open can.exo. Make Selection Inspector visible. Select Cells On - rubber band select some cells. On the Selection Inspector/Display Style/ Cell Label, check Visible. Label Mode: GlobalElementId. Lots of output messages, from vtkLabeledDataMapper.cxx, line 289 "Deed input data to render labels". This functionality/bug fix is needed by a user. Should be fixed for 3.4. | ||||||||
(0011231) Ken Moreland (manager) 2008-04-09 18:01 |
That's funny. Now you can't global ids for the label mode at all. You can select pedigree id mode an that works fine. |
(0011509) Utkarsh Ayachit (administrator) 2008-04-23 12:13 |
Waiting for VTK 5.2 branch to commit the fix. The problem was that the ExtractSelection filters didn't copy global ids over. |
(0011578) Utkarsh Ayachit (administrator) 2008-04-29 08:57 |
ENH: Fixes BUG # 6559. Block names are now used by all the GUI. ENH: vtkExtractArraysOverTime names the blocks based on which cell/pt they represent. BUG: Fixes BUG 0006262. Fixed all extract selection filters to pass global ids. BUG: If composite dataset has no names, use default values ---------------------------- commitid: Z5CBZc5ycsbJl01t ---------------------------- /cvsroot/ParaView3/ParaView3/Qt/Components/pqProxyInformationWidget.cxx,v <-- Qt/Components/pqProxyInformationWidget.cxx new revision: 1.18; previous revision: 1.17 /cvsroot/ParaView3/ParaView3/Qt/Components/pqSignalAdaptorCompositeTreeWidget.cxx,v <-- Qt/Components/pqSignalAdaptorCompositeTreeWidget.cxx new revision: 1.8; previous revision: 1.7 /cvsroot/ParaView3/ParaView3/Servers/Common/vtkPVCompositeDataInformation.cxx,v <-- Servers/Common/vtkPVCompositeDataInformation.cxx new revision: 1.14; previous revision: 1.13 /cvsroot/ParaView3/ParaView3/Servers/Common/vtkPVCompositeDataInformation.h,v <-- Servers/Common/vtkPVCompositeDataInformation.h new revision: 1.7; previous revision: 1.6 /cvsroot/ParaView3/ParaView3/Servers/Common/vtkPVDataInformation.cxx,v <-- Servers/Common/vtkPVDataInformation.cxx new revision: 1.50; previous revision: 1.49 /cvsroot/ParaView3/ParaView3/Servers/Common/vtkPVDataInformation.h,v <-- Servers/Common/vtkPVDataInformation.h new revision: 1.26; previous revision: 1.25 /cvsroot/ParaView3/ParaView3/VTK/Filtering/vtkCompositeDataSet.cxx,v <-- VTK/Filtering/vtkCompositeDataSet.cxx new revision: 1.13; previous revision: 1.12 /cvsroot/ParaView3/ParaView3/VTK/Filtering/vtkCompositeDataSet.h,v <-- VTK/Filtering/vtkCompositeDataSet.h new revision: 1.14; previous revision: 1.13 /cvsroot/ParaView3/ParaView3/VTK/Graphics/vtkExtractArraysOverTime.cxx,v <-- VTK/Graphics/vtkExtractArraysOverTime.cxx new revision: 1.20; previous revision: 1.19 /cvsroot/ParaView3/ParaView3/VTK/Graphics/vtkExtractSelectedFrustum.cxx,v <-- VTK/Graphics/vtkExtractSelectedFrustum.cxx new revision: 1.13; previous revision: 1.12 /cvsroot/ParaView3/ParaView3/VTK/Graphics/vtkExtractSelectedIds.cxx,v <-- VTK/Graphics/vtkExtractSelectedIds.cxx new revision: 1.28; previous revision: 1.27 /cvsroot/ParaView3/ParaView3/VTK/Graphics/vtkExtractSelectedLocations.cxx,v <-- VTK/Graphics/vtkExtractSelectedLocations.cxx new revision: 1.15; previous revision: 1.14 /cvsroot/ParaView3/ParaView3/VTK/Graphics/vtkExtractSelectedThresholds.cxx,v <-- VTK/Graphics/vtkExtractSelectedThresholds.cxx new revision: 1.14; previous revision: 1.13 /cvsroot/ParaView3/ParaView3/VTK/Graphics/vtkExtractSelection.cxx,v <-- VTK/Graphics/vtkExtractSelection.cxx new revision: 1.24; previous revision: 1.23 /cvsroot/ParaView3/ParaView3/VTK/IO/vtkEnSight6BinaryReader.cxx,v <-- VTK/IO/vtkEnSight6BinaryReader.cxx new revision: 1.58; previous revision: 1.57 /cvsroot/ParaView3/ParaView3/VTK/IO/vtkEnSight6Reader.cxx,v <-- VTK/IO/vtkEnSight6Reader.cxx new revision: 1.68; previous revision: 1.67 /cvsroot/ParaView3/ParaView3/VTK/IO/vtkEnSightGoldBinaryReader.cxx,v <-- VTK/IO/vtkEnSightGoldBinaryReader.cxx new revision: 1.77; previous revision: 1.76 /cvsroot/ParaView3/ParaView3/VTK/IO/vtkEnSightGoldReader.cxx,v <-- VTK/IO/vtkEnSightGoldReader.cxx new revision: 1.63; previous revision: 1.62 /cvsroot/ParaView3/ParaView3/VTK/IO/vtkEnSightReader.cxx,v <-- VTK/IO/vtkEnSightReader.cxx new revision: 1.77; previous revision: 1.76 /cvsroot/ParaView3/ParaView3/VTK/IO/vtkEnSightReader.h,v <-- VTK/IO/vtkEnSightReader.h new revision: 1.36; previous revision: 1.35 |
(0011637) Alan Scott (manager) 2008-04-30 20:08 |
Seems to work very well locally, but freezes paraview up client/server. Just follow the steps in the bug, client/server. XP client, 6 pvServer's. Nightly trunk, as of the morning of April 30. |
(0011646) Utkarsh Ayachit (administrator) 2008-05-01 11:20 |
vtkSMDataLabelRepresentationProxy now inserts a vtkCompositeDataToUnstructuredGridFilter to convert a composite input into an unstructure grid, so that vtkMPIMoveData can work correctly. This was causing the hangs when running client-server. ---------------------------- commitid: l6kYLQRDmTTf4h1t ---------------------------- /cvsroot/ParaView3/ParaView3/Servers/Filters/CMakeLists.txt,v <-- Servers/Filters/CMakeLists.txt new revision: 1.166; previous revision: 1.165 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkCompositeDataToUnstructuredGridFilter.cxx,v <-- Servers/Filters/vtkCompositeDataToUnstructuredGridFilter.cxx initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Servers/Filters/vtkCompositeDataToUnstructuredGridFilter.h,v <-- Servers/Filters/vtkCompositeDataToUnstructuredGridFilter.h initial revision: 1.1 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMDataLabelRepresentationProxy.cxx,v <-- Servers/ServerManager/vtkSMDataLabelRepresentationProxy.cxx new revision: 1.14; previous revision: 1.13 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/vtkSMDataLabelRepresentationProxy.h,v <-- Servers/ServerManager/vtkSMDataLabelRepresentationProxy.h new revision: 1.8; previous revision: 1.7 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/Resources/filters.xml,v <-- Servers/ServerManager/Resources/filters.xml new revision: 1.280; previous revision: 1.279 /cvsroot/ParaView3/ParaView3/Servers/ServerManager/Resources/rendering.xml,v <-- Servers/ServerManager/Resources/rendering.xml new revision: 1.281; previous revision: 1.280 |
(0011715) Alan Scott (manager) 2008-05-05 19:45 |
Tested client/server |
2008-01-21 12:44 | Alan Scott | New Issue | |
2008-04-09 18:01 | Ken Moreland | Note Added: 0011231 | |
2008-04-09 18:01 | Ken Moreland | Status | backlog => tabled |
2008-04-09 18:01 | Ken Moreland | Assigned To | => Berk Geveci |
2008-04-09 18:01 | Ken Moreland | Category | => 3.4 |
2008-04-23 12:11 | Utkarsh Ayachit | Assigned To | Berk Geveci => Utkarsh Ayachit |
2008-04-23 12:13 | Utkarsh Ayachit | Note Added: 0011509 | |
2008-04-29 08:57 | Utkarsh Ayachit | Status | tabled => @80@ |
2008-04-29 08:57 | Utkarsh Ayachit | Resolution | open => fixed |
2008-04-29 08:57 | Utkarsh Ayachit | Note Added: 0011578 | |
2008-04-30 20:08 | Alan Scott | Status | @80@ => @20@ |
2008-04-30 20:08 | Alan Scott | Resolution | fixed => reopened |
2008-04-30 20:08 | Alan Scott | Note Added: 0011637 | |
2008-05-01 11:20 | Utkarsh Ayachit | Status | @20@ => @80@ |
2008-05-01 11:20 | Utkarsh Ayachit | Resolution | reopened => fixed |
2008-05-01 11:20 | Utkarsh Ayachit | Note Added: 0011646 | |
2008-05-05 19:45 | Alan Scott | Status | @80@ => closed |
2008-05-05 19:45 | Alan Scott | Note Added: 0011715 | |
2011-01-13 17:00 | Source_changeset_attached | => VTK master a2bd8391 | |
2011-01-13 17:00 | Source_changeset_attached | => VTK master 020ef709 | |
