| 0009705 | ParaView | Bug | public | 2009-10-12 21:42 | 2016-08-12 09:57 | ||||
| Assigned To | Kitware Robot | ||||||||
| Priority | normal | Severity | minor | Reproducibility | always | ||||
| Status | closed | Resolution | moved | ||||||
| Product Version | |||||||||
| Target Version | WhenPossible | Fixed in Version | |||||||
| Summary | 0009705: Contingency Statistics filter is SLOW | ||||||||
| Description | I ran contingency statistics on can.exo (after Merge Blocks), and it is SLOW. Either the user needs to be told that it will be slow, and/or a way to abort the calculations needs to be created. Better yet, it needs to be an order of magnitude or so faster. Also, every single time steps takes the same very large amount of time. To animate "can.exo", which is a play dataset, would take up to 1/2 hour. This is not acceptable. | ||||||||
| Project | |||||||||
| Topic Name | |||||||||
| Type | |||||||||
| Attached Files | |||||||||
| Relationships | |
| Relationships |
| Notes | |
(0036392) Alan Scott (manager) 2016-07-13 14:36 |
Still an issue. Acts like a hang. |
(0037732) Kitware Robot (administrator) 2016-08-12 09:57 |
| Notes |
| Issue History | |||
| 2009-10-12 21:42 | Alan Scott | New Issue | |
| 2009-10-12 21:46 | Alan Scott | Description Updated | |
| 2009-10-12 21:50 | Alan Scott | Summary | Contingency Statistics is SLOW => Contingency Statistics filter is SLOW |
| 2010-04-16 11:09 | Utkarsh Ayachit | Target Version | 3.8 => WhenPossible |
| 2016-07-13 14:36 | Alan Scott | Assigned To | => Alan Scott |
| 2016-07-13 14:36 | Alan Scott | Note Added: 0036392 | |
| 2016-07-13 14:36 | Alan Scott | Status | expired => backlog |
| 2016-07-13 14:36 | Alan Scott | Resolution | open => reopened |
| 2016-07-13 19:06 | Alan Scott | Assigned To | Alan Scott => |
| 2016-08-12 09:57 | Kitware Robot | Note Added: 0037732 | |
| 2016-08-12 09:57 | Kitware Robot | Status | backlog => closed |
| 2016-08-12 09:57 | Kitware Robot | Resolution | reopened => moved |
| 2016-08-12 09:57 | Kitware Robot | Assigned To | => Kitware Robot |
| Issue History |
