| 0009652 | ParaView | Bug | public | 2009-10-03 03:11 | 2012-02-20 13:23 | ||||
| Reporter | Sven Buijssen | ||||||||
| Priority | normal | Severity | minor | Reproducibility | always | ||||
| Product Version | 3.6 | ||||||||
| Target Version | Someday | Fixed in Version | 3.14 | ||||||
| Summary | 0009652: Manage Custom filters resets list of applicable filters | ||||||||
| Description | Create two sources that produce different kind of mesh types, e.g. Disk and Hierarchical Fractal Select both objects => The alphabetical filter list will have almost all items grayed out as they are not applicable. Manage Custom Filters and add or remove a custom filter => The two objects are still selected, but the alphabetical filter list will have all items enabled. This one is probably related to 8621. Reproduced with PV 32-bit Linux 2009-Oct-03 CVS and PV 3.6.1 XP (official release). | ||||||||
| Project | |||||||||
| Topic Name | |||||||||
| Type | |||||||||
| Attached Files | |||||||||
| Relationships | |
| Relationships |
| Notes | |
(0020600) Sven Buijssen (reporter) 2010-05-05 16:28 |
Tested with PV 3.8.0 RC2: It does not suffice any more to remove a custom filter to trigger the bug. But importing a custom filter still resets the list of applicable filters: all items in the alphabetical filter list are enabled for the multiselection disk + hierarchical fractal |
(0020642) Utkarsh Ayachit (administrator) 2010-05-07 13:24 |
I could not reproduce this no matter what I tried: * create a new custom filter -- filters still disabled. * remove a custom filter -- filters still disabled. * export -- filters still disabled. * import -- filters still disabled. |
(0020810) Alan Scott (manager) 2010-05-21 14:22 |
I also cannot replicate this on the trunk. If it is still a bug, please give us really basic steps on how to replicate. For instance, "Manage Custom Filters" - add what custom filter? I tried with create custom filter, and once again, it seemed to work correctly. |
(0021155) Sven Buijssen (reporter) 2010-06-24 05:19 |
I'd like to attach a screen capture plus the custom filter definition I used to trigger the bug in a virtual machine using Debian 5.0.4. So, could an administrator please re-open this bug such that it is possible again to upload files? Thanks. |
(0028312) Sven Buijssen (reporter) 2012-02-20 13:23 |
Fixed since ParaView 3.14.0 |
(0028313) Sven Buijssen (reporter) 2012-02-20 13:23 |
| Notes |
| Issue History | |||
| 2009-10-03 03:11 | Sven Buijssen | New Issue | |
| 2010-05-05 16:28 | Sven Buijssen | Note Added: 0020600 | |
| 2010-05-07 13:24 | Utkarsh Ayachit | Note Added: 0020642 | |
| 2010-05-07 13:24 | Utkarsh Ayachit | Status | backlog => @80@ |
| 2010-05-07 13:24 | Utkarsh Ayachit | Fixed in Version | => 3.8 |
| 2010-05-07 13:24 | Utkarsh Ayachit | Resolution | open => unable to reproduce |
| 2010-05-07 13:24 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
| 2010-05-21 14:22 | Alan Scott | Note Added: 0020810 | |
| 2010-05-21 14:22 | Alan Scott | Status | @80@ => closed |
| 2010-06-24 05:19 | Sven Buijssen | Note Added: 0021155 | |
| 2010-06-24 05:19 | Sven Buijssen | Status | closed => @20@ |
| 2010-06-24 05:19 | Sven Buijssen | Resolution | unable to reproduce => reopened |
| 2010-06-24 09:19 | Utkarsh Ayachit | Status | @20@ => tabled |
| 2010-06-24 09:20 | Utkarsh Ayachit | Fixed in Version | 3.8 => |
| 2010-06-24 09:20 | Utkarsh Ayachit | Target Version | => 3.10 |
| 2010-06-24 09:44 | Sven Buijssen | File Added: SB.Plot.Number.of.Points.and.Cells.over.Time.xml | |
| 2010-06-24 10:10 | Sven Buijssen | File Added: bug9652.wmv | |
| 2010-07-28 16:39 | Utkarsh Ayachit | Target Version | 3.10 => Someday |
| 2012-02-20 13:23 | Sven Buijssen | Note Added: 0028312 | |
| 2012-02-20 13:23 | Sven Buijssen | Note Added: 0028313 | |
| 2012-02-20 13:23 | Sven Buijssen | Status | expired => closed |
| 2012-02-20 13:23 | Sven Buijssen | Resolution | reopened => fixed |
| 2012-02-20 13:23 | Sven Buijssen | Fixed in Version | => 3.14 |
| Issue History |
