| 0009026 | ParaView | Feature | public | 2009-05-13 21:41 | 2010-12-13 16:14 | ||||
| Reporter | John Bit Surfer | ||||||||
| Assigned To | Dave DeMarle | ||||||||
| Priority | normal | Severity | feature | Reproducibility | N/A | ||||
| Product Version | 3.4 | ||||||||
| Target Version | Someday | Fixed in Version | |||||||
| Summary | 0009026: Require a mechanism to change the Qt window size to a specific size (or to view size in realtime as altering) | ||||||||
| Description | Because a scene can be composed of different forms of actors (2D & 3D) (i.e. a legend/axes indicator and a 3D contour) and that these behave differently when scaled in the "save screenshot" command it is critical that the window size is capable of being set to the correct resolution as desired. I say critical because it is ideal that the image composed in the view window resembles that which is saved. When elements of the composition scale differently then this behavior will not occur. Ideally the window size could be specified or perhaps (a compromise, but still desirable anyway) a realtime indicator could be seen, that displayed the resolution as the window size was altered using the mouse. | ||||||||
| Project | |||||||||
| Topic Name | |||||||||
| Type | |||||||||
| Attached Files | |||||||||
| Relationships | |
| Relationships |
| Notes | |
(0023886) Dave DeMarle (administrator) 2010-12-10 14:23 |
The option to set render window size is now found under: Tools->Lock View Size Custom |
(0023937) Alan Scott (manager) 2010-12-13 16:14 |
Tested Linux client, local server, trunk. |
| Notes |
| Issue History | |||
| 2009-05-13 21:41 | John Bit Surfer | New Issue | |
| 2009-05-14 09:24 | Ken Moreland | Target Version | => Someday |
| 2010-12-10 14:23 | Dave DeMarle | Note Added: 0023886 | |
| 2010-12-10 14:23 | Dave DeMarle | Status | backlog => @80@ |
| 2010-12-10 14:23 | Dave DeMarle | Resolution | open => fixed |
| 2010-12-10 14:23 | Dave DeMarle | Assigned To | => Dave DeMarle |
| 2010-12-13 16:14 | Alan Scott | Note Added: 0023937 | |
| 2010-12-13 16:14 | Alan Scott | Status | @80@ => closed |
| 2011-06-16 13:10 | Zack Galbreath | Category | Feature Request => Feature |
| Issue History |
