| 0008489 | ParaView | (No Category) | public | 2009-02-09 10:43 | 2009-05-13 13:46 | ||||
| Reporter | Ken Moreland | ||||||||
| Priority | low | Severity | minor | Reproducibility | have not tried | ||||
| Product Version | |||||||||
| Target Version | 3.6 | Fixed in Version | |||||||
| Summary | 0008489: Setting default color for solid colors | ||||||||
| Description | Users are requesting the ability to be able to change the default color for an object with a solid color and the color of the edges when Surface with Edges is on. | ||||||||
| Project | |||||||||
| Topic Name | |||||||||
| Type | |||||||||
| Attached Files | |||||||||
| Relationships | |
| Relationships |
| Notes | |
(0014846) Ken Moreland (manager) 2009-02-09 10:44 |
Making the solid colors "sticky" (default to the last one set) would be OK, but I think a better solution would be to have entries in the ParaView setting instead. That would prevent the current behavior from changing and prevent current regression tests from breaking. In either case, the default color selection should be persistent between executions of ParaView. That is, the color selection should be saved in the ParaView settings file. |
(0015391) Utkarsh Ayachit (administrator) 2009-02-25 15:11 |
Edge color are foreground color (default solid color) can now be changed through "Application Settings" dialog. |
(0015403) Alan Scott (manager) 2009-02-25 20:23 |
Great! |
| Notes |
| Issue History | |||
| 2009-02-09 10:43 | Ken Moreland | New Issue | |
| 2009-02-09 10:44 | Ken Moreland | Note Added: 0014846 | |
| 2009-02-17 16:48 | Utkarsh Ayachit | Status | backlog => tabled |
| 2009-02-17 16:48 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
| 2009-02-17 16:48 | Utkarsh Ayachit | Priority | normal => low |
| 2009-02-25 15:11 | Utkarsh Ayachit | Note Added: 0015391 | |
| 2009-02-25 15:11 | Utkarsh Ayachit | Status | tabled => @80@ |
| 2009-02-25 15:11 | Utkarsh Ayachit | Resolution | open => fixed |
| 2009-02-25 20:23 | Alan Scott | Note Added: 0015403 | |
| 2009-02-25 20:23 | Alan Scott | Status | @80@ => closed |
| 2009-05-13 13:46 | Utkarsh Ayachit | Target Version | => 3.6 |
| 2011-06-16 13:10 | Zack Galbreath | Category | => (No Category) |
| Issue History |
