| 0007463 | ParaView | (No Category) | public | 2008-08-06 13:11 | 2011-01-28 16:16 | ||||
| Reporter | Andy Bauer | ||||||||
| Priority | normal | Severity | minor | Reproducibility | always | ||||
| Status | closed | Resolution | won't fix | ||||||
| Product Version | |||||||||
| Target Version | Someday | Fixed in Version | 3.10 | ||||||
| Summary | 0007463: scrolling problems in the Object Inspector Display panel | ||||||||
| Description | When I try to scroll using the middle mouse button in the Display panel of the Object Inspector, the scrolling operation gets stuck in some of the panel widgets (e.g. buttons). | ||||||||
| Project | |||||||||
| Topic Name | |||||||||
| Type | |||||||||
| Attached Files | |||||||||
| Relationships | |
| Relationships |
| Notes | |
(0016631) Alan Scott (manager) 2009-06-03 22:12 |
Are you building from source code, and what version of Qt are you using? Qt 4.4.* and 4.5.* are not yet supported, and was causing these symptoms for me. |
(0025132) Utkarsh Ayachit (administrator) 2011-01-28 13:45 |
This happens when the mouse pointer is over something that takes focus like a slider. This is a Qt behavior. Not much that we can do. |
(0025153) Alan Scott (manager) 2011-01-28 16:16 |
This is correct behavior. Tested local server, Windows, trunk. |
| Notes |
| Issue History | |||
| 2008-08-06 13:11 | Andy Bauer | New Issue | |
| 2009-05-13 13:50 | Utkarsh Ayachit | Target Version | => Someday |
| 2009-06-03 10:37 | Utkarsh Ayachit | Status | backlog => @30@ |
| 2009-06-03 22:12 | Alan Scott | Note Added: 0016631 | |
| 2011-01-28 13:45 | Utkarsh Ayachit | Note Added: 0025132 | |
| 2011-01-28 13:45 | Utkarsh Ayachit | Status | @30@ => @80@ |
| 2011-01-28 13:45 | Utkarsh Ayachit | Fixed in Version | => 3.10 |
| 2011-01-28 13:45 | Utkarsh Ayachit | Resolution | open => won't fix |
| 2011-01-28 13:45 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
| 2011-01-28 16:16 | Alan Scott | Note Added: 0025153 | |
| 2011-01-28 16:16 | Alan Scott | Status | @80@ => closed |
| 2011-06-16 13:10 | Zack Galbreath | Category | => (No Category) |
| Issue History |
