| 0007394 | ParaView | (No Category) | public | 2008-07-23 09:11 | 2011-01-28 12:49 | ||||
| Reporter | Sven Buijssen | ||||||||
| Priority | normal | Severity | minor | Reproducibility | always | ||||
| Status | closed | Resolution | no change required | ||||||
| Product Version | |||||||||
| Target Version | Someday | Fixed in Version | 3.10 | ||||||
| Summary | 0007394: Save/Load State does not restore some view options | ||||||||
| Description | Whenever toggling the button "Show/Hide center of rotation" to hide the cross, then saving the state to a file, disconnecting and re-loading the state file, the cross will reappear. It even happens when no file is loaded and no source has been added: fire up paraview, hide the center of rotation, save, disconnect, reload: there it is again. The same holds for the orientation axes (Render View Options - Annotation - Orientation Axes). There setting is neither restored. | ||||||||
| Project | |||||||||
| Topic Name | |||||||||
| Type | |||||||||
| Attached Files | |||||||||
| Relationships | ||||||
| Relationships |
| Notes | |
(0025069) Utkarsh Ayachit (administrator) 2011-01-25 09:01 |
this has already been fixed. |
(0025130) Alan Scott (manager) 2011-01-28 12:49 |
Tested local server, trunk, Windows. |
| Notes |
| Issue History | |||
| 2008-07-23 09:11 | Sven Buijssen | New Issue | |
| 2008-07-24 14:00 | Utkarsh Ayachit | Category | 3.4 => Someday |
| 2009-05-13 13:50 | Utkarsh Ayachit | Target Version | => Someday |
| 2010-11-05 14:03 | Utkarsh Ayachit | Relationship added | has duplicate 0008722 |
| 2011-01-21 13:42 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
| 2011-01-21 13:42 | Utkarsh Ayachit | Status | backlog => tabled |
| 2011-01-21 13:43 | Utkarsh Ayachit | Note Added: 0024997 | |
| 2011-01-21 13:43 | Utkarsh Ayachit | Status | tabled => @80@ |
| 2011-01-21 13:43 | Utkarsh Ayachit | Resolution | open => won't fix |
| 2011-01-25 09:00 | Utkarsh Ayachit | Note Deleted: 0024997 | |
| 2011-01-25 09:01 | Utkarsh Ayachit | Status | @80@ => backlog |
| 2011-01-25 09:01 | Utkarsh Ayachit | Note Added: 0025069 | |
| 2011-01-25 09:01 | Utkarsh Ayachit | Status | backlog => @80@ |
| 2011-01-25 09:01 | Utkarsh Ayachit | Fixed in Version | => 3.10 |
| 2011-01-25 09:01 | Utkarsh Ayachit | Resolution | won't fix => no change required |
| 2011-01-28 12:49 | Alan Scott | Note Added: 0025130 | |
| 2011-01-28 12:49 | Alan Scott | Status | @80@ => closed |
| 2011-06-16 13:10 | Zack Galbreath | Category | => (No Category) |
| Issue History |
