| 0007387 | ParaView | (No Category) | public | 2008-07-22 00:46 | 2010-12-13 17:06 | ||||
| Reporter | Mengda Wu | ||||||||
| Assigned To | Dave DeMarle | ||||||||
| Priority | normal | Severity | feature | Reproducibility | always | ||||
| Status | closed | Resolution | won't fix | ||||||
| Product Version | |||||||||
| Target Version | Someday | Fixed in Version | |||||||
| Summary | 0007387: Transform Filter does not transform vectors in point data | ||||||||
| Description | I have latest cvs version of Paraview running. I am using transform filter to transform the data set. I works fine with the point coordinates. But the vectors in point data do not transform at all. I am wondering if this filter uses vtkTransformFilter or vtkTransformPolyDataFilter. From VTK nightly document, these filters should transform "associated point normals and vectors" as well. | ||||||||
| Project | |||||||||
| Topic Name | |||||||||
| Type | |||||||||
| Attached Files | |||||||||
| Relationships | |
| Relationships |
| Notes | |
(0012800) Ken Moreland (manager) 2008-07-22 11:06 |
The transform filter will only transform the "active" normals and "active" vectors. The active normals are still used by ParaView and they appear to be transformed correctly. (To verify, create a sphere source, apply a rotate and/or asymmetric scale, and then add glyphs on the normals to see that they still point perpendicular to the surface.) The concept of active vectors is largely abandoned by ParaView. Instead, filters are expected to accept the names of variables to process. Automatically transforming every field variable that happens to be a 3-tuple as a vector is a bad idea. There is no guarantee that each such variable is in fact a vector with meaning in the same space as the point coordinates. Thus, to properly implement this request, the transform filter should accept zero or more field variables to transform instead of just grabbing the active vectors. As a workaround, one could use the calculator filter to apply the transform. Translates and scales are quite simple to implement, and rotations that are a factor of 90 degrees around any axis are pretty easy, too. |
(0023881) Dave DeMarle (administrator) 2010-12-10 14:05 |
See Ken's comment for rationale of why we are keeping this behavior. |
(0023940) Alan Scott (manager) 2010-12-13 17:06 |
I agree with Ken's comments. Closed. |
| Notes |
| Issue History | |||
| 2008-07-22 00:46 | Mengda Wu | New Issue | |
| 2008-07-22 11:06 | Ken Moreland | Note Added: 0012800 | |
| 2008-07-22 11:06 | Ken Moreland | Severity | major => feature |
| 2008-07-22 11:06 | Ken Moreland | Category | Development => Someday |
| 2009-05-13 13:49 | Utkarsh Ayachit | Target Version | => Someday |
| 2010-12-10 14:05 | Dave DeMarle | Note Added: 0023881 | |
| 2010-12-10 14:05 | Dave DeMarle | Status | backlog => @80@ |
| 2010-12-10 14:05 | Dave DeMarle | Resolution | open => won't fix |
| 2010-12-10 14:05 | Dave DeMarle | Assigned To | => Dave DeMarle |
| 2010-12-13 17:06 | Alan Scott | Note Added: 0023940 | |
| 2010-12-13 17:06 | Alan Scott | Status | @80@ => closed |
| 2011-06-16 13:10 | Zack Galbreath | Category | => (No Category) |
| Issue History |
