| 0007109 | ParaView | (No Category) | public | 2008-05-28 08:36 | 2009-05-13 13:59 | ||||
| Reporter | Ken Moreland | ||||||||
| Product Version | |||||||||
| Target Version | 3.4 | Fixed in Version | 3.4 | ||||||
| Summary | 0007109: Component selector on toolbar does not change color bar label | ||||||||
| Description | When you are viewing a vector as colors on a surface and have the color bar visible, the label showing which component is displayed is not updated. To replicate: 1. Load disk_out_ref. Turn on all variables. 2. Select V as the scalars to color by. 3. Turn on the color bar visibility. Note the title. 4. Change the component of the vector using either the toolbar or the display panel. The colors update, but the title on the color bar does not. If you go to the color scale editor dialog box and change the component from there, the title updates properly. | ||||||||
| Project | |||||||||
| Topic Name | |||||||||
| Type | |||||||||
| Attached Files | |||||||||
| Relationships | ||||||
| Relationships |
| Notes | |
(0012137) Ken Moreland (manager) 2008-05-28 08:46 |
I also notice that the combo boxes in the toolbar and in the display panel list the components as 0, 1, 2 and the color bar title and combo box in the color scale editor dialog box list the components as X, Y, Z. These should probably be consistent. |
(0012426) Utkarsh Ayachit (administrator) 2008-06-19 16:32 |
Fixed BUG 0007110 and BUG 0007109. The component selector on the toolbar now affects the scalar bar titles as well as lut ranges correctly. /cvsroot/ParaView3/ParaView3/Qt/Components/pqColorScaleEditor.cxx,v <-- Qt/Components/pqColorScaleEditor.cxx new revision: 1.46; previous revision: 1.45 /cvsroot/ParaView3/ParaView3/Qt/Components/pqDisplayColorWidget.cxx,v <-- Qt/Components/pqDisplayColorWidget.cxx new revision: 1.32; previous revision: 1.31 /cvsroot/ParaView3/ParaView3/Qt/Core/pqScalarBarRepresentation.cxx,v <-- Qt/Core/pqScalarBarRepresentation.cxx new revision: 1.6; previous revision: 1.5 /cvsroot/ParaView3/ParaView3/Qt/Core/pqScalarsToColors.cxx,v <-- Qt/Core/pqScalarsToColors.cxx new revision: 1.17; previous revision: 1.16 /cvsroot/ParaView3/ParaView3/Qt/Core/pqScalarsToColors.h,v <-- Qt/Core/pqScalarsToColors.h new revision: 1.15; previous revision: 1.14 |
(0012487) Alan Scott (manager) 2008-06-23 21:14 |
Tested client/server |
| Notes |
| Issue History | |||
| 2008-05-28 08:36 | Ken Moreland | New Issue | |
| 2008-05-28 08:37 | Ken Moreland | Status | backlog => tabled |
| 2008-05-28 08:37 | Ken Moreland | Assigned To | => Utkarsh Ayachit |
| 2008-05-28 08:40 | Ken Moreland | Description Updated | |
| 2008-05-28 08:45 | Ken Moreland | Relationship added | related to 0007110 |
| 2008-05-28 08:46 | Ken Moreland | Note Added: 0012137 | |
| 2008-06-19 16:32 | Utkarsh Ayachit | Status | tabled => @80@ |
| 2008-06-19 16:32 | Utkarsh Ayachit | Resolution | open => fixed |
| 2008-06-19 16:32 | Utkarsh Ayachit | Note Added: 0012426 | |
| 2008-06-23 21:14 | Alan Scott | Status | @80@ => closed |
| 2008-06-23 21:14 | Alan Scott | Note Added: 0012487 | |
| 2009-05-13 13:58 | Utkarsh Ayachit | Target Version | => 3.4 |
| 2009-05-13 13:59 | Utkarsh Ayachit | Fixed in Version | => 3.4 |
| 2011-06-16 13:10 | Zack Galbreath | Category | => (No Category) |
| Issue History |
